4 Replies Latest reply on Sep 10, 2009 6:23 AM by Xavi Colomer
    Image in a DataGrid
    zakabalt
      Hello, I want to introduce a image in one datagrid column but I don't know why. I'm trying doing that:
      private var columns:ArrayCollection = new ArrayCollection([
                                  {headerText: 'Image', dataField: 'column1', itemRenderer:'xxxxx', width: '5' },
      private var date:ArrayCollection = new ArrayCollection([
                     {column1:'../img/clip.png',
                     {column1:'../img/clip2.png,}])
      What I have to put in itemRenderer? Or I'm doing totaly wrong
      It's better if I do
      [Embed(source="img/clip.png")] public var buzonIcon:Class;
      and then use buzenIcon in column1:.....
      What is the solution?
      Thanks!
        • 1. Re: Image in a DataGrid
          flexprad09
          IMO you can use the second option.
          cheers.
          • 2. Re: Image in a DataGrid
            ShardulSingh Level 3
            Hi, Pls find the solution of the your problem.
            MainApplication.mxml
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
            layout="vertical">
            <mx:Script>
            <![CDATA[
            import mx.collections.ArrayCollection;
            [Bindable]
            private var dgArrayCollection:ArrayCollection=
            {imgPath:'assets/img1.png', names:'John'},
            {imgPath:'assets/img2.png', names:'Alex'},
            {imgPath:'assets/img3.png', names:'Peter'},
            {imgPath:'assets/img1.png', names:'Sam'},
            {imgPath:'assets/img2.png', names:'Alis'},
            {imgPath:'assets/img3.png', names:'Robin'},
            {imgPath:'assets/img1.png', names:'Mark'},
            {imgPath:'assets/img2.png', names:'Steave'},
            {imgPath:'assets/img3.png', names:'Fill'},
            {imgPath:'assets/img1.png', names:'Abraham'},
            {imgPath:'assets/img2.png', names:'Hennery'},
            {imgPath:'assets/img3.png', names:'Luis'},
            {imgPath:'assets/img1.png', names:'Herry'},
            {imgPath:'assets/img2.png', names:'Markus'},
            {imgPath:'assets/img3.png', names:'Flip'},
            {imgPath:'assets/img1.png', names:'John_1'},
            {imgPath:'assets/img2.png', names:'Alex_1'},
            {imgPath:'assets/img3.png', names:'Peter_1'},
            {imgPath:'assets/img1.png', names:'Sam_1'},
            {imgPath:'assets/img2.png', names:'Alis_1'},
            {imgPath:'assets/img3.png', names:'Robin_1'},
            </mx:Script>
            <mx:VBox width="300" height="100%"
            horizontalAlign="center"
            verticalAlign="middle">
            <mx:DataGrid id="dg" width="50%"
            height="100%"
            borderStyle="none"
            dataProvider="{dgArrayCollection}"
            <mx:columns>
            <mx:DataGridColumn dataField="color" itemRenderer="DatagridItemRenderer"/>
            <mx:DataGridColumn dataField="names" headerText="Names"/>
            </mx:columns>
            </mx:DataGrid>
            </mx:VBox>
            </mx:Application>
            DatagridItemRenderer.mxml
            <mx:HBox xmlns:mx="http://www.adobe.com/2006/mxml"
            width="100" height="30" horizontalGap="5"
            horizontalScrollPolicy="off" verticalScrollPolicy="off"
            <mx:Script>
            <![CDATA[
            override public function set data(value:Object):void
            super.data = value;
            </mx:Script>
            <mx:Image width="75" height="30" source="{data.imgPath}"/>
            </mx:HBox>
            Let me know if you have any issue with this.
            With Regards,
            Shardul Singh Bartwal
            • 3. Re: Image in a DataGrid
              zakabalt Level 1
              Edited
              Message was edited by: zakabalt I haven't seen the last answer
              • 4. Re: Image in a DataGrid
                Xavi Colomer
                You should look at this:
                http://www.adobe.com/devnet/flex/quickstart/using_item_renderers/
                If you are using Flex 4, the information may not be right.
