3 Replies Latest reply on Sep 10, 2009 1:38 PM by MarionMacDonald
    Problem with Depths
      I've been reading about getDepths and swapDepths but can't figure out which I get -16383 in response to the following:
      _root.holder.attachMovie("button","introButton", 10);
      I've also used this in the same piece of code and get the expected response:
      this.createEmptyMovieClip("container", 5);
      I'd appreciate some pointers.
        • 1. Re: Problem with Depths
          MarionMacDonald Level 1
          Sorry, that should be 'why' not 'which'
          • 2. Re: Problem with Depths
            Rothrock Level 5
            That would be because that is the depth of the thing you asked for. Flash does what we tell it to do, not what we want.
            I can't quite tell if you are confused by the really low negative number or that you expected it to return 10?
            You are asking for the depth of _root.holder, not the depth of _root.holder.introButton. Remember that attachMovie puts the newly attached movie inside the object you tell it to put it inside of.
            Addtionally here is a great trick. attachMovie returns a reference to the newly attached movie so you can do something like this:
            var myNewClip:MovieClip=_root.holder.attachMovie("button","introButton", 10);
            trace("the attached clip is: "+myNewClip)
            trace("its depth is: "+myNewClip.getDepth());
            If your confusing is over the really negative number....My guess is that holder is something you placed on the timeline at author time, right? Here is a great article about the differences in how Flash handles depths between timeline placed and code placed objects.
            • 3. Re: Problem with Depths
              Thank you so much for your reply.  Doh, I knew it would be something obvious.
              And yYes, I had come across that article.
