6 Replies Latest reply on Sep 11, 2009 8:39 AM by Phil Leggetter
    flexunit ant triggered FlexUnitRunnerUI stops mid-test
    Phil Leggetter
      I've spent around a day stuck on a problem where I run my unit tests from my build script and they stop in the middle of executing tests. After a bit of investigation it seem that if you have muliple tests that extend TestCase (or in our actualy project MockitoTestCase) this can happen.
      I've attached a modified FlexUnit4SampleCIProject with the following:
      EchoPanelTest.as extends TestCase
      EchoPanelTest2.as original EchoPanelTest from SVN
      EchoPanelTest3.as extends TestCase
      EchoPanelTest4.as extends TestCase
      If you run ant on the build.xml the UI Runner gets as far as test:
      19/22
      Case EchoPanelTest4
      Function testBlah5
      But no further.
      If you then comment out testBlah3 to testBlah5 in EchoPanelTest4 and run the ant build it completes.
      There appears to be a problem with:
      1) Extending TestCase (or MockitoTestCase)
      2) Having a certain number of tests within one test file.
      Has anybody any idea what is causing the UI to stop mid-test?
      Phil Leggetter
      http://www.leggetter.co.uk
      http://twitter.com/leggetter
