2 Replies Latest reply on Sep 10, 2009 5:51 PM by Marc Trzepla
    Frame Blending Not Respecting "Anchor" Frames
    Marc Trzepla Level 1
      I have a QT movie.  It is 24 fps.  If I drop it into a 48 fps comp and step thru one frame at a time each frame repeats twice.. makes sense (A-A-B-B-C-C).  But if I turn on Frame Blending (both Modes) not only does the repeated frame get re-created (A-AB-B-BC-C-CD) from interpolation but the KEY frames get altered too ... what's going on?  Why is that?  Shouldn't the Key frames - the 'real' frames be unchangeable anchors?  48 is twice 24 so those shouldn't be getting blended at all in the first place.
      I've tried Time Remapping instead of a higher frame rate comp and also the Time Stretch flyout to 200% - each gives me the same results.
      Any ideas what I'm doing wrong?
      Marc
        • 1. Re: Frame Blending Not Respecting "Anchor" Frames
          No, I don't think so. Barring issues with "crooked" 24p framerates or NTSC framerates, the behavior to me is correct. The interpolation is averaged across multiple frames, forward and backward. What you want is to only interpolate forward, which I believe is a method RevisionFX' Twixtor offers.
          Mylenium
          • 2. Re: Frame Blending Not Respecting "Anchor" Frames
            Honestly, that doesn't jibe with me.  Even if it looks 'backwards'  ...  take the B for instance in my example ...  the previous frame generated would just get it's info from A making AB before B.  But I digress - it is what it is but I SWEAR I've generated 60i fields from 30P without altering the Key frames in the past.
            But something you said started me thinking.  Twixtor.  I don't have a few hundred bucks for Twixtor so that was out.  But when I picked up Mark Christiansen's book he mentions in his discussion about frame blending that while After Effects doesn't come with Twixtor it DOES come Timewarp from RE:Vision so I looked into that...
            and it worked.
            There's a teeny tiny button called, "Build From One Image" that keeps the Key frames whole and makes AB frames in between as I would expect.  (See!  I'm not the only one who thinks it should work like this. .. ... they made it a FEATURE!)
            So I got what I was looking for with Timewarp.
            Thanks to Mylenium for the Twixtor hint and Mark for his great reference book.
            Marc
