1 Reply Latest reply on Sep 10, 2009 12:04 PM by JoyceEvans
    Creating buttons in fireworks 8
    q-live
      When I make a button in fireworks 8 and do a preview the buttons work but when I export it in any format and put it on webpage using front page or dreamweaver cs4 it doesn't work at all.
        • 1. Re: Creating buttons in fireworks 8
          JoyceEvans Level 3
          How are you exporting? If you want a working button dirextly from FW with no other coding then export as HTML and images then in Dreamweaver Insert>Image objects>Fireworks HTML
          BUT the better way is to make the button with rollovers (images will be placed in frames) export images, be sure current frame only is not checked and export. In Dreamweaver insert button then use the swap image behavior for the rollover. When you exported from Fireworks the rollover image is appended with the number 2.
