1 Reply Latest reply on Sep 11, 2009 12:56 AM by bluecuraga47
    Can't access selected dates in dateChooser
    bluecuraga47
      This is my code in a flex/air applicaiton for the datechooser:
      <mx:DateChooser
      x="13" y="12" width="221" height="187" allowMultipleSelection="true" change="dateChooser_change(event)" id="dateChooserBox" />
      This is what I'm using to try to extract the chosen dates:
      trace
      ("trace"+dateChooserBox.selectedRanges[i]);
      trace("trace as string"+dateChooserBox.selectedRanges[i].toString());
      Output:
      trace[object Object]
      trace as string[object Object]
      How do I get the date instead of "object Object"? I'm trying to extract the date so I can put it back into an sqllite query. This has been giving me a lot of headaches. I tried getTime, getMonth and those produced errors too.
        • 1. Re: Can't access selected dates in dateChooser
          Andrew Rosewarn Level 3
          HI there
          The date are stored in properties called rangeStart and rangeEnd
          <?xml version="1.0"?>
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"   xmlns:ns1="*">
          <mx:Script>
          <![CDATA[
          import mx.events.DateChooserEvent;
          private function dateChooser_change(event:Event):void {
          for each ( var item:Object in  dateChooserBox.selectedRanges) {
          trace (item.rangeStart + ' : ' +item.rangeEnd);
          </mx:Script>
          <mx:DateChooser x="13" y="12" width="221" height="187" allowMultipleSelection="true" change="dateChooser_change(event)" id="dateChooserBox" />
          </mx:Application>
          Hope this helps.
          Andrew
