0 Replies Latest reply on Sep 11, 2009 6:20 AM by Mike Peterson
    [svn:fx-trunk] 10151: Modified the Channel.applySettings() ASDoc comment.
    Mike Peterson
      Revision: 10151
      Author:   peterson@adobe.com
      Date:     2009-09-11 06:20:44 -0700 (Fri, 11 Sep 2009)
      Log Message:
      Modified the Channel.applySettings() ASDoc comment. Removed the XML snippet for the method parameter, which wasn't relevant to the primary way this method is used. This method is primarily used in our channel subclasses to add settings specific to those channels and then call super to get the base channel settings. If a developer creates a custom channel class, the developer could use it in the same way, but would be setting the applySettings() method on the custom channel class with properties specific to the custom channel implementation. This change addresses bug BLZ-294.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/BLZ-294
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/Channel.as
