4 Replies Latest reply on Sep 11, 2009 8:24 AM by Chunick
    fasted way to find best color match in colors list
    Remko_van_Dokkum
      i have a list (1000+) with color values rbg() -- [rgb(34,56,78),rgb(45,23,78)......]
      what is the fastest way to find the closest match for a specific color.
      i have to scan an image 640x480 pixels, and replace all pixels in this images with the best match color from my color list.
      is it possible to have a script make a palette. and use the palette to remap the colors of an image. and then get the rgb color values of the remapped image?
        • 1. Re: fasted way to find best color match in colors list
          Chunick Level 3
          If you sort your list then you can use the list method, findPosNear()... like so:
          cList = [color( 255, 0, 0 ), color( 0, 0, 0 ), color( 127, 255, 0 ), color( 255, 255, 255 ) , color( 127, 0, 255 ), color( 127, 127, 127 )]
          cList.sort()
          put cList
          -- [color( 0, 0, 0 ), color( 127, 0, 255 ), color( 127, 127, 127 ), color( 127, 255, 0 ), color( 255, 0, 0 ), color( 255, 255, 255 )]
          put cList.findPosNear(color(124, 12, 240))
          -- 2
          put cList[2]
          -- color( 127, 0, 255 )
          This will still take a bit of time because you still have to iterate through each pixel, however, I mention it as a solution because you mention a list of 1000 entries... otherwise, I would go the route you mention of using a palette, but you cannot have 1000 colours in a palette; only a maximum of 256 colours.
          • 2. Re: fasted way to find best color match in colors list
            Remko_van_Dokkum Level 1
            thanks will give it a try.
            hope to cut down 45 min. to under 10 min.
            never thought a list of colors would listen to findPosNear.
            will check if my match result is the same as the findPosNear result.
            thanks.
            2009/9/11 Joshua Chunick <forums@adobe.com>
            like so:
            cList.sort()
            put cList
            -- 2
            put cList[2]
            This will still take a bit of time because you still have to go through
            256 colours.
            • 3. Re: fasted way to find best color match in colors list
              a=[color(0,0,1),color(30,56,0)]
              a.sort()
              put a.findPosNear(color(30,56,2))
              -- 3
              why does it find a position outside the list ?
              like so:
              cList.sort()
              put cList
              -- 2
              put cList[2]
              256 colours.
              • 4. Re: fasted way to find best color match in colors list
                Chunick Level 3
                a.sort()
                I suspect that's because findPosNear tests between two values, without going over the value.... ok, that's not very clear, but with that in mind you could cap the value like this:
                -- set a.count to a variable outside your loop, so it's not being calculated every time
                listCount = a.count
                newColorIndex = a.findPosNear(color(30,56,2))
                if newColorIndex > listCount then
                  newColorIndex = listCount
                end if
