0 Replies Latest reply on Sep 11, 2009 8:09 AM by Paul Reilly
    [svn:fx-trunk] 10154: * Two beta 2 fixes.
    Paul Reilly
      Revision: 10154
      Author:   preilly@adobe.com
      Date:     2009-09-11 08:09:18 -0700 (Fri, 11 Sep 2009)
      Log Message:
      • Two beta 2 fixes.
      QE notes: We should add a "mxunit databinding" test case for
                SDK-21101.  It might require checking that the watchers are
                correct, because due to RTTI the data binding happens to
                work at runtime even though we didn't handle "as"
                expressions correctly before.
      Doc notes:
      Bugs: SDK-21101, SDK-22549
      Reviewer: Corey
      Tests run: checkintests, mxunit databinding
      Is noteworthy for integration: No
      Code-level description of changes:
        as3/binding/DataBindingFirstPassEvaluator.java
          This fix adds support for data binding expressions like:
            {(foo as Bar).baz}
          by modifying evaluate(Context, BinaryExpression) to not reset the
          watchList when the op is AS_TOKEN and by modifying getRef() by
          adding support for MemberExpressionNode's with a
          BinaryExpressionNode base, which happens to be contained within a
          ListNode.
        mxml/ImplementationGenerator.java
          Modified generateBindingExprsFunction() by removing the casting to
          an ExpressionStatementNode when we parse a destination string from
          a Binding tag.  If the destination is valid, it should be an
          ExpressionStatementNode, but if the string contains invalid AS
          code, it might not be, so this fix allows ASC to handle the
          invalid AS code downstream.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21101
          http://bugs.adobe.com/jira/browse/SDK-22549
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassE valuator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
