0 Replies Latest reply on Sep 11, 2009 5:22 PM by xinonnet
    MessageBrokerService failed to initialize
    xinonnet Level 1
      I edited my server.xml to open up the https port, then Blaze threw this exception at initialization.
      I want to use Custom authentication for my application.  Is my server.xml set up correctly?  I tried it with vanilla tomcat, it worked perfectly.
      I also tried editing catalina.policy to include the Trace class, it didn't work.
      Thanks.
      **** MessageBrokerServlet failed to initialize due to runtime exception:   Error: java.lang.ExceptionInInitializerError
      at flex.messaging.config.FlexConfigurationManager.getConfigurationParser(FlexConfigurationMa nager.java:163)
      at flex.messaging.config.FlexConfigurationManager.getMessagingConfiguration(FlexConfiguratio nManager.java:68)
      at flex.messaging.MessageBrokerServlet.init(MessageBrokerServlet.java:106)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
      at java.lang.reflect.Method.invoke(Unknown Source)
      at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:244)
      at java.security.AccessController.doPrivileged(Native Method)
      at javax.security.auth.Subject.doAsPrivileged(Unknown Source)
      at org.apache.catalina.security.SecurityUtil.execute(SecurityUtil.java:276)
      at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:162)
      at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:115)
      at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1155)
      at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:981)
      at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4045)
      at org.apache.catalina.core.StandardContext.start(StandardContext.java:4351)
      at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
      at org.apache.catalina.core.StandardHost.start(StandardHost.java:719)
      at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
      at org.apache.catalina.core.StandardService.start(StandardService.java:516)
      at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
      at org.apache.catalina.startup.Catalina.start(Catalina.java:566)
      at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:288)
      at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
      Caused by: java.security.AccessControlException: access denied (java.util.PropertyPermission trace.config read)
      at java.security.AccessControlContext.checkPermission(Unknown Source)
      at java.security.AccessController.checkPermission(Unknown Source)
      at java.lang.SecurityManager.checkPermission(Unknown Source)
      at java.lang.SecurityManager.checkPropertyAccess(Unknown Source)
      at java.lang.System.getProperty(Unknown Source)
      at flex.messaging.util.Trace.<clinit>(Trace.java:49)
      ... 30 more
      <?xml version="1.0" encoding="UTF-8"?>
      <!-- Note:  A "Server" is not itself a "Container", so you may not
           define subcomponents such as "Valves" at this level.
           Documentation at /docs/config/server.html
      --><Server port="8005" shutdown="SHUTDOWN">
        <!--APR library loader. Documentation at /docs/apr.html -->
        <Listener SSLEngine="on" className="org.apache.catalina.core.AprLifecycleListener"/>
        <!--Initialize Jasper prior to webapps are loaded. Documentation at /docs/jasper-howto.html -->
        <Listener className="org.apache.catalina.core.JasperListener"/>
        <!-- JMX Support for the Tomcat server. Documentation at /docs/non-existent.html -->
        <Listener className="org.apache.catalina.mbeans.ServerLifecycleListener"/>
        <Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener"/>
        <!-- Global JNDI resources
             Documentation at /docs/jndi-resources-howto.html
        <GlobalNamingResources>
          <!-- Editable user database that can also be used by
               UserDatabaseRealm to authenticate users
          <Resource auth="Container" description="User database that can be updated and saved" factory="org.apache.catalina.users.MemoryUserDatabaseFactory" name="UserDatabase" pathname="conf/tomcat-users.xml" type="org.apache.catalina.UserDatabase"/>
        </GlobalNamingResources>
        <!-- A "Service" is a collection of one or more "Connectors" that share
             a single "Container" Note:  A "Service" is not itself a "Container",
             so you may not define subcomponents such as "Valves" at this level.
             Documentation at /docs/config/service.html
        <Service name="Catalina">
          <!--The connectors can use a shared executor, you can define one or more named thread pools-->
          <Executor name="tomcatThreadPool" namePrefix="catalina-exec-"
              maxThreads="150" minSpareThreads="4"/>
          <!-- A "Connector" represents an endpoint by which requests are received
               and responses are returned. Documentation at :
               Java HTTP Connector: /docs/config/http.html (blocking & non-blocking)
               Java AJP  Connector: /docs/config/ajp.html
               APR (HTTP/AJP) Connector: /docs/apr.html
               Define a non-SSL HTTP/1.1 Connector on port 8080
          <Connector connectionTimeout="20000" port="8080" protocol="HTTP/1.1" redirectPort="8443"/>
          <!-- A "Connector" using the shared thread pool-->
          <Connector executor="tomcatThreadPool"
                     redirectPort="8443" />
          <!-- Define a SSL HTTP/1.1 Connector on port 8443
               This connector uses the JSSE configuration, when using APR, the
               connector should be using the OpenSSL style configuration
               described in the APR documentation -->
          <Connector SSLEnabled="true" clientAuth="false" keystoreFile="keystore" keystorePass="changeit"
             maxThreads="150" port="8443" protocol="HTTP/1.1" scheme="https"
             secure="true" sslProtocol="TLS"/>
          <!-- Define an AJP 1.3 Connector on port 8009 -->
          <Connector port="8009" protocol="AJP/1.3" redirectPort="8443"/>
          <!-- An Engine represents the entry point (within Catalina) that processes
               every request.  The Engine implementation for Tomcat stand alone
               analyzes the HTTP headers included with the request, and passes them
               on to the appropriate Host (virtual host).
               Documentation at /docs/config/engine.html -->
          <!-- You should set jvmRoute to support load-balancing via AJP ie :
          <Engine name="Standalone" defaultHost="localhost" jvmRoute="jvm1">
          <Engine defaultHost="localhost" name="Catalina">
            <!--For clustering, please take a look at documentation at:
                /docs/cluster-howto.html  (simple how to)
                /docs/config/cluster.html (reference documentation) -->
            <Cluster className="org.apache.catalina.ha.tcp.SimpleTcpCluster"/>
            <!-- The request dumper valve dumps useful debugging information about
                 the request and response data received and sent by Tomcat.
                 Documentation at: /docs/config/valve.html -->
            <Valve className="org.apache.catalina.valves.RequestDumperValve"/>
            <!-- This Realm uses the UserDatabase configured in the global JNDI
                 resources under the key "UserDatabase".  Any edits
                 that are performed against this UserDatabase are immediately
                 available for use by the Realm.  -->
            <Realm className="org.apache.catalina.realm.UserDatabaseRealm" resourceName="UserDatabase"/>
             <Realm className="org.apache.catalina.realm.MemoryRealm"/>
            <!-- Define the default virtual host
                 Note: XML Schema validation will not work with Xerces 2.2.
            <Host appBase="webapps" autoDeploy="true" name="localhost" unpackWARs="true" xmlNamespaceAware="false" xmlValidation="false">
              <!-- SingleSignOn valve, share authentication between web applications
              <Valve className="org.apache.catalina.authenticator.SingleSignOn" />
              <!-- Access log processes all example.
              <Valve className="org.apache.catalina.valves.AccessLogValve" directory="logs"
                     prefix="localhost_access_log." suffix=".txt" pattern="common" resolveHosts="false"/>
            <Context docBase="BlazeServer" path="/BlazeServer" reloadable="true" source="org.eclipse.jst.jee.server:BlazeServer"/></Host>
          </Engine>
        </Service>
      </Server>
