0 Replies Latest reply on Sep 11, 2009 3:03 PM by Ely Greenfield
    [svn:fx-trunk] 10172:
    Ely Greenfield
      Revision: 10172
      Author:   egreenfi@adobe.com
      Date:     2009-09-11 15:02:58 -0700 (Fri, 11 Sep 2009)
      Log Message:
      Adjusted the margin of error used to decide if a component is in 3D or not.  It was an order of magnitude too low -- as a result, normal precision errors in 3D calculations were making pushing components with 2D matrices into 3D, resulting in fuzzy text.
      REviewed: Chet
      QA: none needed.
      doc: none.
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/CompoundTransform.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/TransformOffsets.as
