0 Replies Latest reply on Sep 11, 2009 3:33 PM by rfrishbe
    [svn:fx-3.x] 10177: This is a bug fix for setting AIR Window/ WindowedApplication visibility when a hideEffect is installed.
    rfrishbe Level 3
      Revision: 10177
      Author:   rfrishbe@adobe.com
      Date:     2009-09-11 15:32:47 -0700 (Fri, 11 Sep 2009)
      Log Message:
      This is a bug fix for setting AIR Window/WindowedApplication visibility when a hideEffect is installed.  We need to dispatch the HIDE event for the effect to play.  Then, when the effect is finished, we can remove that event listener and set the visibility to false.
      I also cleaned up some "effectEnd" and made them EffectEvent.EFFECT_END
      I'm going to check the fix for the Spark versions in to trunk.
      QE notes: -
      Doc notes: -
      Bugs: SDK-14615
      Reviewer: Darrell
      Tests run: checkintests, Rob helped run the mustella tests for Window/WindowedApplication
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-14615
      Modified Paths:
          flex/sdk/branches/3.x/frameworks/projects/airframework/src/mx/core/Window.as
          flex/sdk/branches/3.x/frameworks/projects/airframework/src/mx/core/WindowedApplication.as
