3 Replies Latest reply on Sep 13, 2009 2:57 AM by [Jongware]
    [JS][CS3] Applying an Object Style
    Roy Marshall Level 1
      Hi.
      This is a simple one, I am trying to apply an already made Object Style to a text frame.
      I am using a similar method as used to apply a paragraph style:
      myFrame.appliedObjectStyle.name= "GreenBox";
      and also
      myFrame.appliedObjectStyle= "GreenBox";
      But these dont work.
      I have researched the forums and found something like:
      myFrame.applyObjectStyles(GreenBox , true);
      and
      myFrame.applyObjectStyles(GreenBox);
      but these dont work either.
      Can someone give me a hand with the correct syntax please?
      Thanks in advance
      Roy
        • 1. Re: [JS][CS3] Applying an Object Style
          AdobeScripts Level 3
          and
          the problem is in S after applyObjectStyle ... should be applyObjectStyle - without S at end
          robin
          www.adobescripts.co.uk
          • 2. Re: [JS][CS3] Applying an Object Style
            I have just answered this by finding another thread...
            myFrame.applyObjectStyle(app.documents[0].objectStyles.item("GreenBox"), true);
            I would like to know what the 'True' means though.
            Any thoughts?
            Cheers
            Roy
            • 3. Re: [JS][CS3] Applying an Object Style
              void applyObjectStyle (using: ObjectStyle[, clearingOverrides: bool=true][, clearingOverridesThroughRootObjectStyle: bool=false])
              Applies the specified object style.
              ParameterTypeDescription
              usingObjectStyleThe object style to apply.
              clearingOverridesboolIf true, clears the Button's existing attributes before applying the style. (Optional) (default: true) (Optional)
              clearingOverridesThroughRootObjectStyleboolIf true, clears attributes and formatting applied to the Button that are not defined in the object style. (Optional) (default: false) (Optional)
              -- so you can use one or even two trues; it's default is 'true'.
