0 Replies Latest reply on Sep 12, 2009 10:43 AM by rfrishbe
    [svn:fx-trunk] 10200: Found a bug when I was fixing visibility issues for AIR.
    rfrishbe Level 3
      Revision: 10200
      Author:   rfrishbe@adobe.com
      Date:     2009-09-12 10:42:53 -0700 (Sat, 12 Sep 2009)
      Log Message:
      Found a bug when I was fixing visibility issues for AIR.  "windowClose" as an event name conflicts with another internal event that Window/WindowedApplication use.  To fix this, I'm changing the newly added WindowedSystemManager.WINDOW_CLOSE to "globalNotifyWindowClose".  This class (and the event) is an internal class that is only used by automation.  I've run this change by the automation team to make sure it is ok.
      QE notes: -
      Doc notes: -
      Bugs: -
      Reviewer: Darrell
      Tests run: checkintests, Rob ran WindowedApplication and Window tests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/events/WindowExistenceEvent.as
