1 Reply Latest reply on Sep 13, 2009 2:09 AM by Andrew Rosewarn
    display the rowIndex
    joeroth2010
      This should be simple, but I would like to display the rowIndex in one of the columns of a datagrid (starting with 1).  The dataprovider is of type ArrayCollection.  The datagrid has drag/drop enabled so the items can be re-arranged, but I would like to keep the rowIndex static (always 1,2,3...etc).  Think arranging songs in a music playlist.  I've stumbled across some blogs recommending using item renderers, but that just seems like overkill to me.  I also saw this (http://forums.adobe.com/message/173512#173512), but don't quite understand how to implement this.  Any help would be greatly appreciated.
      Joe
        • 1. Re: display the rowIndex
          Andrew Rosewarn
          Hi there
          Yea I don't think you need an item renderer.  You can use a label function like this to obtain the row index, which will work when you drag and reorder.
          <?xml version="1.0"?>
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"   xmlns:ns1="*">
          <mx:Script>
          <![CDATA[
          import mx.collections.ArrayCollection;
          [Bindable]
          private var ac:ArrayCollection = new ArrayCollection([
          {song: 'Song 1'},
          {song: 'Song 2'},
          {song: 'Song 3'},
          {song: 'Song 4'}
          private function lfRowNum(item:Object,col:int):String
              var index:int = ac.getItemIndex(item) + 1;
              return String(index);
          </mx:Script>
          <mx:DataGrid id="dg" dataProvider="{ac}" dragMoveEnabled="true" dragEnabled="true" dropEnabled="true">
          <mx:columns>
          <mx:DataGridColumn headerText="No" labelFunction="lfRowNum"/>
          <mx:DataGridColumn headerText="Song" dataField="song"/>
          </mx:columns>
          </mx:DataGrid>
          </mx:Application>
          Hope that helps
          Andrew
