9 Replies Latest reply on Jun 20, 2011 9:23 AM by jchunick
    send focus on the stage
    wgb14 Level 1
      Hi
      1) I have the following code
      on mouseup me
        sound(1).play( member("typewriter1"))
        tFocus = _movie.keyBoardFocusSprite
        tText = sprite(tFocus).text
        c = tText.length
        if c <> 0 then
          tText = tText & numtochar(32)
          sprite(tFocus).text = tText
        else
          beep
        end if
      end
      Everything works fine when the flash textarea component is in the same movie. However when I am trying this
      tFocus = window("stage").movie.keyBoardFocusSprite
      I am getting tfocus = - 1. Any ideas how to send the focus to the stage?
      2) Also, the following code inputs a predefined letter in the flash component. It works fine, but the inseration point (IBeam cursor) does not move at the end of each letter (as it should be). Any ideas how to fix this?
      property myKey
      property pme,displayField
      on getpropertydescriptionlist me
        a = [:]
        addprop a, #myKey, [#default : sprite(the currentspritenum).member.name, #format:#string, #comment : "what key do I put into the field?"]
        return a
      end
      on beginsprite me
        pme = sprite(me.spritenum)
      end
      on mouseUP me
        puppetSound 1, "typewriter1"
        --displayField = window("stage").movie.member(which_field)
        displayField = _movie.keyboardFocusSprite
      end
      One last question:
      3) In the same textarea I am trying to delete the last character using the code below. Again it doesn't work. Any ideas?
      global which_field
      on mousedown
        c = tText.length
        if c <> 0 then
          tText.char[c].delete()
        else
          beep
        end if
      END
        • 1. Re: send focus on the stage
          Tols (UK)
          I've never used Flash Components to be frank but I'd imagine the problem with (3) is that ttext is just a text variable and isn't an object referencing the textfield's contents indefinitely. so i would try something like
          if c <> 0 then
              sprite(tFocus).member.text=ttext.char[1..c-1]
            else
              beep
            end if
          As for 2, set the selstart and selend to the length of the field's current text.
          As for 1, i'm not sure what you mean actually.
          same movie as what?
          • 2. Re: send focus on the stage
            Sean_Wilson Adobe Community Professional
            same movie as what?
            The OP is using a MIAW - something that wasn't clearly explained.
            Also, he posted to a different forum where all of his questions were answered. Unfortunately he never bothered to get back here and flag the question as answered or update the thread - a good reason to stick to one forum at a time, since it saves this sort of confusion.
            • 3. Re: send focus on the stage
              wgb14 Level 1
              Sorry for the double posts, but I figured out 1, and 3 myself.... The answers are similar to what Tols suggests. The second still troubles me... Here is the compelte code for it... There are no selstart and selend for the textarea flash component. Any ideas?
              global accent,re1,tFocus
              property myKey
              property pme
                a = [:]
                return a
              end
              on beginsprite me
                accent = 0   --set the intial value for the accentation variable
                re1 = "(omikron)|(omega)|(ipsilon)"
              end
              on mouseUP me
                accentuation
                if sprite(53).text = "Caps:On" then
                  oString=new(xtra "mevString", RegExp_Replace(myKey, re1, "", "gi"))
                  oString.mevcToUpper()
                  window("stage").movie.sprite(tFocus).text = window("stage").movie.sprite(tFocus).text&oString.mevcGetString()
                else
                  if sprite(53).text = "Caps:Off" then
                    window("stage").movie.sprite(tFocus).text = window("stage").movie.sprite(tFocus).text & RegExp_Replace(myKey, re1, "", "gi")
                  end if
                end if
              end
              • 4. Re: send focus on the stage
                Tols (UK) Level 1
                Haven't tried this but
                try
                  window("stage").movie.sprite(tFocus).member.text
                instead of
                and put
                set the selstart to (sprite(tfocus).member.text).length
                at the end of the mouseup handler - this should put the cursor at the
                end.
                No?
                • 5. Re: send focus on the stage
                  wgb14 Level 1
                  That doesn't work either....I am searching the web for almost 3 hours now but nothign so far....
                  • 6. Re: send focus on the stage
                    Tols (UK) Level 1
                    ok due to my inexperience in flash components i just tested that code
                    I suggested and it worked fine for me.
                    by fine I mean that the cursor got put at the end of the line, after
                    the character that the mouseup inserted.
                    (Without the selstart line I suggested the cursor is left at the
                    penultimate character.)
                    What is the character that you are inserting, i just used a single
                    character 'j'
                    Perhaps stick an updatestage before the selstart line - they often fix
                    things!
                    Or maybe its a miaw issue, but you seem to referencing the stage so I
                    presume that's not the case.
                    • 7. Re: send focus on the stage
                      wgb14 Level 1
                      Here is the solution in case you need it. I had to search through the help file of Actionscript 2 to find this.
                      sprite(54).Selection.setSelection(sprite(54).text.length, sprite(54).text.length)
                      • 8. Re: send focus on the stage
                        BigDaddy
                        Since you were successful with the aid of the forum members, I hope that someone can help me with a similar situation.
                        I'm trying to get the position of the cursor 'within a string' in a field member, in order to delete characters.
                        For example, if member("text string").text = "abcdeggh", I want to delete character 6. It would be 'easier' if I knew that the cursor was
                        between characters 5-6 or characters 6-7. the difference is delete versus backspace. I don't want to backspace eliminate "h,g, and g".
                        I want to delete "g" (character 6) then type "f".
                        Thanks for any help you can give.
                        BigDaddy
