4 Replies Latest reply on Sep 14, 2009 7:44 AM by bk843746
    Property change events
    bk843746
      Hi
      I have an mxml file with a member variable (e.g. public var something:Something).
      Is it possible to setup events that can detect the following changes?
      - object change (e.g. something = aDifferentReference();)
      - object internal change (e.g. something.value = someOtherValue;)
      - object collection changes (e.g. add, remove, change)
      I'm using Flex 3.
        • 1. Re: Property change events
          _Natasha_ Level 4
          of course answer is yes for all.
          But don't write where you want to get this events.
          Usual thing for detecting changes:
          public function set someProperty(value):void
          // change data
          // generate change event
          So you need to create a set and get functions for property and do what you want.
          • 2. Re: Property change events
            bk843746 Level 1
            Hi
            Could you please provide some code samples to show how this works?
            • 3. Re: Property change events
              _Natasha_ Level 4
              For example,
              // source od DataGrid
              override public function get columns():Array
                      return _columns.slice(0);
                   *  @private
                  override public function set columns(value:Array):void
                      var n:int;
                      var i:int;
                      n = _columns.length;
                      for (i = 0; i < n; i++)
                          columnRendererChanged(_columns[i]);
                      freeItemRenderersTable = new Dictionary(false);
                      columnMap = {};
                      _columns = value.slice(0);
                      columnsInvalid = true;
                      generatedColumns = false;
                      n = value.length;
                          var column:DataGridColumn = _columns[i];
                          column.owner = this;
                          column.colNum = i;
                          if (column.cachedHeaderRenderer)
                              var item:DisplayObject = column.cachedHeaderRenderer as DisplayObject
                              if (item.parent)
                                  item.parent.removeChild(item);
                              column.cachedHeaderRenderer = null;
                      updateSortIndexAndDirection();
                      itemsSizeChanged = true;
                      invalidateDisplayList();
                     dispatchEvent(new Event("columnsChanged"));
              • 4. Re: Property change events
                bk843746 Level 1
                Hi
                Thanks but I figured it out myself.
                Flex has an ObjectProxy that allows you to detect changes to an object. It doesn't indicate what changed, it just indicates that a change occured.
                Flex also has a CollectionEvent that indicates  a collection changed and how it changed.
                Here are the links I found that helped me implement the solution:
                http://blog.flexexamples.com/2007/09/27/detecting-changes-to-an-object-using-the-flex-obje ctproxy-class/
                http://livedocs.adobe.com/flex/3/html/help.html?content=about_dataproviders_5.html
