9 Replies Latest reply: May 5, 2014 1:34 PM by P Spier RSS
    Find ALL CAPS, convert to lower case
    cbminfo Community Member
      I'm trying to use the find replace option to find words, not I or I'm, but whole words that I've capitalized, and want to make them lower case.
      I've tried building a format with ALL CAPS, and the closest thing I can find for the replace option is normal.
      But when I do this, I get the blue info icon at the top of the search form that says form already exists. This says to me it's such a common request that they have something already designed to search for ALL cap words, and convert to lower case.
      Digging thru the predefined searches, I can't find anything that even sounds like what I want to do.
      I've searched thru grep and text.
      Any clues on how to do this and not screw up the 'I'm, I've' words where the 1st character is capitalized and the rest aren't.
        • 1. Re: Find ALL CAPS, convert to lower case
          P Spier CommunityMVP
          My instinct is this needs to be scripted. It's easy enough to use GREP to find these words, but changing the case to "normal" has no effect, as far as I can tell. You need to change to Sentence Case, and that isn't an option in Find/Change. You also run some risk of changing things you don't want changed, like state abbreviations and other acronyms.
          In fact, Harbs has already written a short script that does this. You'll find it in the comments on theis page: http://indesignsecrets.com/using-grep-to-make-a-character-lowercase.php
          You'll also find some more discussion at http://forums.adobe.com/thread/329167
          • 2. Re: Find ALL CAPS, convert to lower case
            Well, it would seem there is a definite need for some sort of extended 'search for uppercase convert to lowercase' and most likely vice versa lower to upper. But the examples were pretty much specific vs global as I wan't/need.
            And you're right changing states and acronyms.
            What's needed is a script builder like is built in to Photoshop.
            The Upper to Lowercase command already exists on the type menu. The need is to import that command into a script to execute 1 by 1 as the need arises.
            Which brings me back to the blue info button that appears when I create the grep command. It says 'search format exists'. And what does that mean ?
            • 3. Re: Find ALL CAPS, convert to lower case
              Harbs. CommunityMVP
              Did you read the link Peter provided?
              The script I wrote there should do what you want.
              If you want a GREP which will not get states for sure, you can use
              \u{3,}
              But of course it will miss ANY two letter all-cap word...
              Harbs
              • 4. Re: Find ALL CAPS, convert to lower case
                As was pointed out, the only way to access the change case commands (which is waht you want to do) is through a script interface. You simply can't do it with a Find/Change. You CAN set the search parameters, though, and then run the script that Harbs so generously posted. I'm sure if you post on the scripting forum, someone would probably be willing to also help you with adding a list of states and acronyms you know you don't want to change, or perhaps adding a pause for confirmation at each hit.
                This is just too complex to have an simple all or nothing solution since there are always likely to be workd you actually DO want to have as all caps (but maybe if you add a character style to those that forces all caps, you'd get away with changing everything after all).
                • 5. Re: Find ALL CAPS, convert to lower case
                  I'm just learning indesign. I found a bunch of adobe videos on adobe.tv, but the adobe viewer claimed the videos were in the wrong format or other. This is an OLD problem with adobe viewer.
                  I just figured maybe there was a simple solution [nothing in the helps had anything on it.]
                  And it would seem my history with program problems is still true to form. Problems I find, normally don't have a solution.
                  • 6. Re: Find ALL CAPS, convert to lower case
                    We've already pointed you in the direction of a solution. If you've used styles (as you should) there's a good chance you can limit the GREP search parameters using styles and or limited search (story, selection) to eliminate a lot of the false positives you might otherwise see.
                    If you don't wnat to try what's offered, that's another story.
                    • 7. Re: Find ALL CAPS, convert to lower case
                      [Jongware] Community Member
                      Some people see only problems, others see solutions.
                      • 8. Re: Find ALL CAPS, convert to lower case
                        claidheamdanns Community Member
                        Harb, sort of along the same lines, but not exactly. I am looking for the code (if it exists) to find where the ALL CAPS style has been applied (i.e. Command+Shift+K). Your GREP code is doing a good job at catching where someone typed multiple CAPS in a row, but not if someone types lowercase and then applies ALL CAPS.
                        I have your GREP set up in the paragraph style, and it activates a character style to flag the text as pink text, and it is working well on everything but the ALL CAPS style.
                        • 9. Re: Find ALL CAPS, convert to lower case
                          What do you want to do when you find the text to which All Caps is applied?
                          Since this text is really lowercase, with the All Caps attribute added, there's probably not a lot that can be done with GREP styles that you would want to do, since it would affect all lowercase text with that paragraph style (and as before, a character style that sets the case to Normal does nothing here).
