0 Replies Latest reply on Sep 13, 2009 10:29 PM by skanthi
    Using Remote Object
    skanthi Level 1
      Hi all..
      I have a doubt using RemoteObject...
      I have a java class with a method updateClient() and returns a String..
      I used a timer in flex which invokes Java class for every one second..
      the updateClient() uses a counter variable declared globally and returns an incremented value of the counter as String..
      But each time the timer invokes the method i can only see that the string returned is only "1";
      How does this happen.Only if a new instance on Java class is created each time.
      Is this true . i mean does the lcds creates a new instance of java class each time its method is invoked.???
      thankx..
