9 Replies Latest reply on Jun 16, 2008 8:42 AM by Newsgroup_User
    Document relative paths in template
    RICH POW Level 1
      My site definition is set to document relative paths and that is how they appear in my template e.g. ../file
      but child pages save as root relative e.g. /file
      Come across this before? Any ideas?
      Rich
      Mac CS3
        • 1. Re: Document relative paths in template
          Level 7
          Never. Create a new child from this template and see how the links appear
          in that.
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "RICH POW" <webforumsuser@macromedia.com> wrote in message
          news:g2u6k3$gd9$1@forums.macromedia.com...
          > Rich
          > Mac CS3
          • 2. Re: Document relative paths in template
            RICH POW Level 1
            Here's the template and a child:
            www.adelantedesign.co.uk/test.zip
            Take a look at the scripts location,
            <link href="../SpryAssets/SpryValidationTextField.css" rel="stylesheet" type="text/css" />
            in the template
            <link href="/SpryAssets/SpryValidationTextField.css" rel="stylesheet" type="text/css" />
            in the child.
            Am I missing some thing?
            Oh and here is my site definition.
            www.adelantedesign.co.uk/Picture6.png
            • 3. Re: Document relative paths in template
              RICH POW Level 1
              I have a feeling I am having a stupid attack... Please confirm, lol and move on if this is right...
              when using document relative paths when linking to a file in a folder blow the root it will show /folder/file (not ../folder/file
              and when linking back a level (from within a sub folder) it path will be ../folder/file
              Rich
              • 4. Re: Document relative paths in template
                Level 7
                No. You STILL don't get it.
                A document relative link describes the path from the current document's
                location to the target file with no consideration for where the root of the
                site is. A root relative link describes the path from the root of the site
                to the target file with no consideration for where the current document is
                located within the site.
                > the
                If the link is in a Template file, and you are using document relative
                links, it will ALWAYS begin "../".
                > ../folder/file
                That would be true if you are using document relative links, yes.
                news:g35h50$hum$1@forums.macromedia.com...
                >move on
                > if this is right...
                > the
                > ../folder/file
                > Rich
                • 5. Re: Document relative paths in template
                  RICH POW Level 1
                  so would the document relative path to a file in the same folder be /file
                  if so I never had a problem in the first place!
                  Your patience and understanding stretched to the limit once again:)
                  • 6. Re: Document relative paths in template
                    Level 7
                    N O! You still don't understand.
                    A document relative path to a file in the same folder would be "file".
                    http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_13129&sliceId=2
                    http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_15546&sliceId=2
                    news:g35ra2$sj7$1@forums.macromedia.com...
                    • 7. Re: Document relative paths in template
                      Level 7
                      Any path that starts with a leading /slash is a SITE ROOT RELATIVE path.
                      On understanding paths- this is an old thing i posted years ago:
                      There are three link methods-
                      Relative to Document
                      Site Root Relative
                      Absolute or Full http path
                      1) RELATIVE TO DOCUMENT
                      ../folder1/page.html
                      or
                      folder1/page.html
                      or
                      page.html
                      can start with a folder name, a filename, or can use ../ which means "go up
                      one folder"   ../../../  would mean go up three folder levels from present
                      location.
                      Gives directions on how to get to the other file, based on where you are
                      now. such as go UP one folder, then find a folder named 'folder1', then in
                      the 'folder1' folder get a file called page.html
                      A real world analogy- to get to the Post Office from the high school, leave
                      the high school parking lot, go west, turn left, go south 2 blocks.
                       ( ***The directions are based on where you are now ***)
                      With Document Relative paths and links, as long as the relationship between
                      documents is kept the same and folders aren't juggled around, the links will
                      work anywhere. The most portable linking method.
                      Say a page located here:
                      http://example.com/folder1/fol der2/page.html
                      contains an image tag like this:
                      <img src="../image.jpg">
                      That means go up one level from where this page is, and find image.jpg in
                      that directory.
                      http://example.com/folder1/ima ge.jpg
                      2) RELATIVE TO SITE ROOT
                      /folder1/page.html
                      or
                      /page.html
                      A SITE ROOT relative path will ALWAYS start with a leading slash  /
                      The leading slash means "go to root first, and then follow this file path"
                      Relative to site root gives directions from the root level of the site,
                      regardless of where you are starting from.
                      This root is the domain name, when the site is on a server. If your site is
                      defined to a subfolder of a domain, do NOT use site root relative paths in
                      dreamweaver. They will come out wrong, because dreamweaver will base them on
                      what you've told it your site's folder is, not the real "root" of the site,
                      which is at the root of the domain.
                      In real world, to get to Post Office, go to the City Hall then go two blocks
                      east.  It doesn't matter where you are now- you have to go the City Hall to
                      start following the directions.
                      (***the directions are based on a ROOT or ground zero point ***)
                      Think of some cities like Anchorage, AK or Salt Lake City- all street
                      addresses there can be read as co-ordinates from a zero point. By just
                      looking at the address, you know in what corner of the city it is.
                      Site Root Relative the way we use it requires that there be a domain to be
                      relative to-- thus will not work to create a site on CD. And will not work
                      from a Hard Drive. "Root" on a CD or HD is different. Needs to be on a
                      server to work correctly. And- should not be used if your remote site is
                      hosted in a subfolder of a domain, like http://geocities.com/mysite/
                      The TMP files dreamweaver creates for a "preview in browser" convert these
                      to document relative so they work during preview- but only the document
                      that's being previewed. If you click a link on the "Preview in Browser"
                      page- you will be looking directly at a file from the hard drive- and site
                      root relative paths on that page won't work.
                      <img src="/folder1/image.jpg">
                      That means go to the site's root level on the server, http://example.com/
                      An example of site root links not working-
                      Your site is at
                      If you use a site root relative path in dreamweaver, the link will come out
                      /image.jpg
                      and the image is at:
                      http://geocities.com/mysite/im age.jpg
                      But the browser will be looking here
                      http://geocites.com/image.jpg
                      and the image isn't there...
                      3) ABSOLUTE
                      http://mydomain.com/folder1/pa ge.html
                      absolute is the full http address of the file
                      To get to the post office, go to 113 Main Street, Anytown, Your_State, USA.
                      Don't need to know anything about where you are starting from, it's an exact
                      address.
                      Almost all people who use dreamweaver use Document Relative paths, and let
                      dreamweaver manage the paths. There are exceptions but few of them. Document
                      Relative is the easiest for a new user to stay out of trouble with.
                      The other big concept is that site has to be properly defined within
                      dreamweaver, because dw makes all links based on the information it's been
                      given in the site defintion. If that info is wrong- then links can be wrong
                      (especially site root relative paths)
                      Alan
                      Adobe Community Expert, dreamweaver
                      http://www.adobe.com/communities/experts/
                      • 8. Re: Document relative paths in template
                        RICH POW Level 1
                        Got it.
                        Virtual cold one for your time!
                        • 9. Re: Document relative paths in template
                          Level 7
                          Virtual <belch>!
                          news:g35srd$16l$1@forums.macromedia.com...
                          > Got it.
