0 Replies Latest reply on Sep 14, 2009 3:57 AM by Steve_Morard
    Error while recording process using a component with a custom data type
    Steve_Morard
      Hello,
      I created a component that returns a CheckAttachmentResult object. This object contains an int named resultCode and a String named resultMessage. In the CheckAttachmentResult class, I do have a getter and a setter function for both values.
      When I use the component, I can retrieve the CheckAttachmentResult object, see the values that are set (i.e. resultMessage and resultCode) and work on them (for instance build a condition on the resultCode).
      However when the current process goes into a subprocess after having used this component, I get the following error:
      Failed evaluating outgoing routes for action=template:ReceptionDtpBriefingV2/branch:main-branch/pool:POOL/swimlane:Extraction du DTP/action:Check DTP attachments: java.lang.NullPointerException  at com.adobe.idp.auditworkflow.dsc.service.storage.ProcessRecordingStorageImpl.persistDocume ntVariables(ProcessRecordingStorageImpl.java:409)
          at com.adobe.idp.auditworkflow.dsc.service.storage.ProcessRecordingStorageImpl.serialize(Pro cessRecordingStorageImpl.java:390)
          at com.adobe.idp.auditworkflow.dsc.service.storage.ProcessRecordingStorageImpl.persist(Proce ssRecordingStorageImpl.java:151)
          at com.adobe.idp.auditworkflow.dsc.service.AuditWorkflowServiceImpl.auditEvent(AuditWorkflow ServiceImpl.java:62)
          at sun.reflect.GeneratedMethodAccessor1278.invoke(Unknown Source)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
          at java.lang.reflect.Method.invoke(Method.java:585)
          at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
          at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
          at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
          at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
          at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTr ansactionCMTAdapterBean.java:342)
          at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doRequiresNew (EjbTransactionCMTAdapterBean.java:284)
          at sun.reflect.GeneratedMethodAccessor236.invoke(Unknown Source)
          at org.jboss.invocation.Invocation.performCall(Invocation.java:345)
          at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionConta iner.java:214)
          at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionI nterceptor.java:149)
          at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstance Interceptor.java:154)
          at org.jboss.webservice.server.ServiceEndpointInterceptor.invoke(ServiceEndpointInterceptor. java:54)
          at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:48)
          at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:106)
          at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:389)
          at org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:166)
          at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:153)
          at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:192)
          at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor. java:122)
          at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:624)
          at org.jboss.ejb.Container.invoke(Container.java:873)
          at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:415)
          at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:88)
          at $Proxy169.doRequiresNew(Unknown Source)
          at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:143)
          at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
          at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStra tegyInterceptor.java:55)
          at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
          at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:109)
          at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
          at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:115)
          at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:118)
          at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessage Receiver.java:91)
          at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:21 5)
          at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:57)
          at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
          at com.adobe.workflow.audit.WorkflowAudit.invokeCallback(WorkflowAudit.java:471)
          at com.adobe.workflow.audit.WorkflowAudit.breakpointRouteEvaluationCompleted(WorkflowAudit.j ava:268)
          at com.adobe.workflow.engine.PEUtil.evaluateRules(PEUtil.java:425)
          at com.adobe.workflow.engine.SynchronousBranch.getNextActionOrStallOnFailure(SynchronousBran ch.java:801)
          at com.adobe.workflow.engine.SynchronousBranch.updateBranchInstanceStatus(SynchronousBranch. java:649)
          at com.adobe.workflow.engine.SynchronousBranch.execute(SynchronousBranch.java:887)
          at com.adobe.workflow.engine.ProcessEngineBMTBean.continueBranchAtAction(ProcessEngineBMTBea n.java:2773)
          at com.adobe.workflow.engine.ProcessEngineBMTBean.asyncInvokeProcessCommand(ProcessEngineBMT Bean.java:704)
          at sun.reflect.GeneratedMethodAccessor503.invoke(Unknown Source)
          at org.jboss.ejb.plugins.AbstractTxInterceptorBMT.invokeNext(AbstractTxInterceptorBMT.java:1 58)
          at org.jboss.ejb.plugins.TxInterceptorBMT.invoke(TxInterceptorBMT.java:62)
          at $Proxy202.asyncInvokeProcessCommand(Unknown Source)
          at com.adobe.workflow.engine.ProcessCommandControllerBean.doOnMessage(ProcessCommandControll erBean.java:156)
          at com.adobe.workflow.engine.ProcessCommandControllerBean.onMessage(ProcessCommandController Bean.java:99)
          at sun.reflect.GeneratedMethodAccessor457.invoke(Unknown Source)
          at org.jboss.ejb.MessageDrivenContainer$ContainerInterceptor.invoke(MessageDrivenContainer.j ava:475)
          at org.jboss.ejb.plugins.MessageDrivenInstanceInterceptor.invoke(MessageDrivenInstanceInterc eptor.java:101)
          at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:335)
          at org.jboss.ejb.plugins.RunAsSecurityInterceptor.invoke(RunAsSecurityInterceptor.java:94)
          at org.jboss.ejb.MessageDrivenContainer.internalInvoke(MessageDrivenContainer.java:389)
          at org.jboss.ejb.plugins.jms.JMSContainerInvoker.invoke(JMSContainerInvoker.java:1077)
          at org.jboss.ejb.plugins.jms.JMSContainerInvoker$MessageListenerImpl.onMessage(JMSContainerI nvoker.java:1379)
          at org.jboss.jms.asf.StdServerSession.onMessage(StdServerSession.java:256)
          at org.jboss.mq.SpyMessageConsumer.sessionConsumerProcessMessage(SpyMessageConsumer.java:904 )
          at org.jboss.mq.SpyMessageConsumer.addMessage(SpyMessageConsumer.java:160)
          at org.jboss.mq.SpySession.run(SpySession.java:333)
          at org.jboss.jms.asf.StdServerSession.run(StdServerSession.java:180)
          at EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(PooledExecutor.java:748)
          at java.lang.Thread.run(Thread.java:595)
      It turns out that this error is related to the recording of the process. When I stop the recording, this error disappears. Do you have any idea on what goes wrong ? Did I miss something or made something wrong ?
      I attached the component.xml file of the component to this post.
      Thank you in advance
      Steve
