3 Replies Latest reply on Sep 19, 2009 11:58 AM by ajineshravi
    Please help
    MissingGio
      hello everyone, I tried but still can't do. well I wonder how could I make a bar top or bottom which doesn't move when window resizes like that http://www.flashden.net/files/58963/index.html
        • 1. Re: Please help
          ajineshravi
          hi,
          you need to set flash height and width to 100% in html embed and object tag..
          then use action script inside flash movie to set the "y" position of "bar" movieclip = Stage.height-height of movieclip
          you need to set this on every resize of browser .. so use Stage.onResize method in action script
          see the script below...
          obj=new Object();
          alignbottom(); //align first time
          list.onResize=function() //align on every resize of browser
              alignbottom();
          function alignbottom()
               bar_mc._y=Stage.height-bar_mc._height;   //bar_mc is the movieclip you want to align at bottom
          Stage.addListener(obj);
          Stage.scaleMode="noScale";  //use this to remove scaling of flash
          Stage.align="TL" //allign flash to Top Left
          • 2. Re: Please help
            MissingGio Level 1
            thank you  very much, but with this script my black bar is centered and bottomed and it has exact size and I wanted that it was stretched on 100%
            sorry for my bad english
            • 3. Re: Please help
              ajineshravi Level 1
              hi,
              it so simple!!
              just add this two line to alignbottom() function
              bar_mc._x=0;
              bar_mc.bar_bg_mc._width=Stage.width;
              bar_bg_mc is the movieclip instance inside bar_mc which is the black background color to be stretch
              and pls correct a small mistake on previous script that i typed "list" instead of "obj" in 3rd line of script. So pls correct it to obj.onResize=function (not list.onResize)
              modified script is given below:
              obj=new Object();
              obj.onResize=function() //align on every resize of browser
                  alignbottom();
                   bar_mc._x=0;
                   bar_mc.bar_bg_mc._width=Stage.width; //bar_bg_mc is the movieclip inside bar_mc which is the black  background color to be stretch to 100%
              Check attached source file, if any doubt...
