0 Replies Latest reply on Sep 14, 2009 8:43 AM by Chet Haase
    [svn:fx-trunk] 10229: Fixes for some transform effects problems.
    Chet Haase Level 3
      Revision: 10229
      Author:   chaase@adobe.com
      Date:     2009-09-14 08:43:43 -0700 (Mon, 14 Sep 2009)
      Log Message:
      - We were not animating the postLayout properties in some cases where we should have, effectively pinning the object in place. We now animate those properties whenever applyChangesPostLayout is true.
      - A copy/paste error meant that we did not animate the scaleZ property in cases where we should have.
      - A problem in the transform code means that using a null transform center is not the same as a transform center which uses the transformX/Y/Z properties of the target object. We now force the creation/use of a transform center in all cases to avoid that problem.
      QE notes: This breaks about a dozen tests in the transform effects area, but I believe the new results are correct and the tests/bitmaps should be changed.
      Doc notes: None
      Bugs: sdk-23177
      Reviewer: Hans
      Tests run: checkintests, Mustella transform effects
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-23177
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AnimateTransform.as
