8 Replies Latest reply on Sep 17, 2009 6:18 AM by pretendermadafaka
    help with little script using grep
    pretendermadafaka
      i am a begginer but i guess this will not be a problem for somebody who is experienced...
      i am working with a lot of files that have tags. tag for italic text, tag for centered text and so on, i manage to
      get regular expression to work and to do all of these things with find/change dialog, but i would like to
      automate all of it..
      so for example i have part of the text that need to be italic that is enclosed in underscores like this _something that needs to be italic_
      and i have this regular expression that takes care of it _[A-Za-z0-9,;\-\?\(&!\):'". ]+_
      finds all the matches and applies the text style i want.
      how to do that with script? thanks in advance.
        • 2. Re: help with little script using grep
          Marc Autret Level 5
          Use FindChangeByList.jsx (with 'grep' findType).
          Marc
          • 3. Re: help with little script using grep
            pretendermadafaka Level 1
            ok, ok tried that, i opened FindChangeList.txt and changed one line and uncommented it
            here is who it looks:
            grep  {findWhat:"_[A-Za-z0-9,;\-\?\(&!\):'. ]+_"}  {applied paragraph style:paragraph style "boldanditalic"} {includeFootnotes:true}  finad and change to ita
            and it doesnt work
            i tried some of the text examples and they do work...what is going on? is there any simple test to try?
            (this regex works in find/change dialog)
            thanks again for the effort
            • 4. Re: help with little script using grep
              Marc Autret Level 5
              I think you need to escape the backslashes:
              { findWhat : "_[A-Za-z0-9,;\\-\\?\\(&!\\):'. ]+_" }
              Just a question, why not using this:
              { findWhat : "_[^_]+_" }
              Marc
              • 5. Re: help with little script using grep
                oh, you are write your expression work like a charm "_[^_]+_"
                the point is that i needed something fast and didnt know regex very well, and i am still a beginner..
                also, this works only in find/change dialog but not when i try to run a script ;( here is the line that i uncomented in the FindChangeList.txt
                grep  {findWhat : "_[^_]+_"}  {changeTo:"^_"} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:true}     description
                i am not sure do i need stuff enclosed in third pair of parethesis...
                anyhow, i save this file and ran the script from indesign...nothing happens
                maybe it is a bug...i tried some of the lines that deal with text and that worked like a charm but grep dont.
                thanks for helping me.
                • 6. Re: help with little script using grep
                  ok, i made it to work with countless tries, and it works but only first time, and i undo and run script again it doesnt work (text does but grep dont)
                  i then need to restart indesign to make it work again...what a hell is going on???
                  how to make this work as it should?? thanks guys!
                  • 7. Re: help with little script using grep
                    Going back to your first GREP, search for this
                    _([A-Za-z0-9,;\-\?\(&!\):'". ]+)_
                    and replace with
                    $1
                    (with formatting in italic and/or your style) will do the formatting and remove the underscores at the same time. Only if you are totally sure the underscores are balanced, use
                    _([^_])_
                    -- if there is only one single unbalanced one, it'll mess up your text.
                    It should work correct in the interface; to put it into the findreplace script file, double the backslashes -- that's all.
                    • 8. Re: help with little script using grep
                      thanks everybody, i manage to get it work taking into account what was written here...it all comes down to this:
                      cs3 findchangelist script messes up indesign, i am using cs4 version and it doesnt give any problems
                      line that i am using for italic is:
                      grep    {findWhat:"_[A-Za-z0-9,;\\-\\?\\(&!\\):'\".~b/]+_"}    {appliedFont:"Adobe Garamond Pro", fontStyle:"Bold Italic", pointSize:13}    {includeLockedStoriesForFind:false, includeLockedLayersForFind:false, includeHiddenLayers:false, includeMasterPages:false, includeFootnotes:true}    //Comment
                      thanks again!
                      @[Jongware]
                      thanks, i am back to the old grep!
