5 Replies Latest reply on May 4, 2010 4:18 PM by roger.gonzalez
    Nested If...Else blocks in PixelBender Kernel Don't Work in Flash Player?
    gloam
      I'm writing a kernel which has a several conditional steps.  It contains a structure like the following:
      if(condition)
      dst = outputA;
      else
         if(anotherCondition)
            dst = outputB;
         else
            if(yetAnotherCondition)
                dst = outputC;
            else
               dst = outputD
      I realize that this is a bit ugly, and that conditionals are already less than ideal for a kernel (and nested conditionals even less ideal), however, it does seem to work in the PixelBender Toolkit environment itself when I run the filter.  It will also export as a pbj for Flash without any objections from the Toolkit.  However, when I run the filter in Flash it seems to do... nothing.  When I strip out the nested conditionals, I will at least see the first if / else level working, but with nested conditionals, everything seems to be ignored and the kernel doesn't run at all within Flash Player.
      Is this a bug?  Has anyone else successfully used nested conditional blocks in a PixelBender kernel running inside Flash Player?
