5 Replies Latest reply on Sep 14, 2009 7:25 PM by Sean_Wilson
    Color Shift from Quicktime Movie
    MARKWBA Level 1
      Ok, Here is my problem.  When I do a copy and paste into director from a Quicktime movie for the first and last frame of my movie the is a noticible color shift when the movie starts to play on my command and when the movie transitions from the last frame of the QT to the still i have placed at the end of the movie.
      Any ideas?
        • 1. Re: Color Shift from Quicktime Movie
          Sean_Wilson Adobe Community Professional
          It's possibly codec related, but you don't say how you're performing this copy-and-paste so that might be impacting it too. Why not place the member on-stage, turn off DTS (so that you can grab an image), set the movieTime appropriately and snag (the stage).image.crop(sprite.rect) into a #bitmap member? That way your screen grab should have the same colours as the file played in Director.
          • 2. Re: Color Shift from Quicktime Movie
            MARKWBA Level 1
            I'm doing a apple-c in QuickTime and apple-v right into the director
            cast. The wierd thing is I have figured out that while the resizeable
            option in the movie template is checked on there is no color shift. As
            soon as I uncheck it the problem occurs again and I need to publish a
            full screen projector with no obstructions (title bar / resize
            etc...). The problem occurs no matter what codec I use (h264/
            sorenson). The only one that works is apple animation but the files
            are way to big and chug in a projector.
            Any more ideas?
            Mark
            • 3. Re: Color Shift from Quicktime Movie
              Any more ideas?
              Did you try what I suggested and do your screen capture from within Director?
              • 4. Re: Color Shift from Quicktime Movie
                MARKWBA Level 1
                My director skills are fairly basic. Any chance you can direct me to
                an online tutorial that would walk me through this process?
                I use director in a limited way. My final product is a sequence of
                about 150 QuickTime movies strung together in director that I cue with
                specific key commands.
                Thanks for your help already
                M
                • 5. Re: Color Shift from Quicktime Movie
                  Open your Director file. Locate a QuickTime member in your cast library. Open the Property Inspector and navigate it to the QuickTime tab where you should uncheck DTS. Drag this member onto the stage to create a sprite in channel 1 in an otherwise empty section of your score. Open your Message Window and execute the following lines of code, one at a time, by pressing the RETURN key at the end of each line:
                  sprite(1).movieTime = 0
                  updateStage
                  new(#bitmap).image = (the stage).image.duplicate.crop(sprite(1).rect)
                  sprite(1).movieTime = sprite(1).member.duration
                  updateStage
