0 Replies Latest reply on Sep 14, 2009 2:06 PM by Chet Haase
    [svn:fx-trunk] 10242: Fix/ workaround for use of suspendBackgroundProcessing on Flex 4 effects.
    Chet Haase Level 3
      Revision: 10242
      Author:   chaase@adobe.com
      Date:     2009-09-14 14:06:01 -0700 (Mon, 14 Sep 2009)
      Log Message:
      Fix/workaround for use of suspendBackgroundProcessing on Flex 4 effects. The new effects depend on layout validation running to update the properties of the target objects, but this flag specifically suppresses layout validation. The 'fix' is to disable setting this flag for the new effects. A longer-term fix is in the works, but in the meantime, it will at least be possible for the new effects to work if this flag has been set.
      QE notes: None
      Doc notes: None
      Bugs: sdk-22974
      Reviewer: Corey
      Tests run: checkintests, Mustella spark effects
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-22974
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Animate.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateInstance .as
