0 Replies Latest reply on Sep 14, 2009 5:08 PM by GordonSmith
    [svn:fx-trunk] 10250: Added 'direction' and 'locale' styles to TextStyles. as (the same place that defines 'textFieldClass') so that an MX component using UITLFTextField as its textFieldClass can also specify the direction and locale of the text .
    GordonSmith Level 4
      Revision: 10250
      Author:   gosmith@adobe.com
      Date:     2009-09-14 17:08:09 -0700 (Mon, 14 Sep 2009)
      Log Message:
      Added 'direction' and 'locale' styles to TextStyles.as (the same place that defines 'textFieldClass') so that an MX component using UITLFTextField as its textFieldClass can also specify the direction and locale of the text.
      UITLFTextField uses getStyle() on these styles to set its 'direction' and 'locale' properties.
      UITextFormat needs to have new fields to store these properties, just like for 'sharpness', 'thickness'. The determineTextFormatFromStyle() method of UIComponent fills these out based on the styles. The measure() method of UITextFormat then transfers them to the offscreen TLFTextField used for measurement.
      Also UIComponent's createInFontContext() method now sets the textLineCreator of the TLFTextField so that it knows which module should create its TextLines (so that they can use a font embedded in that module).
      QE notes: None
      Doc notes: None
      Bugs: SDK-23117
      Reviewer: Glenn
      Tests run: ant checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23117
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UITextFormat.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/metadata/TextStyles.as
          flex/sdk/trunk/frameworks/projects/spark/src/mx/core/UITLFTextField.as
