3 Replies Latest reply on Sep 14, 2009 10:57 PM by crissy84
    100% height does not work for Grid?
    crissy84
      Hello again,
      It seems that setting height to 100% for the Grid layout container does not work.  I would expect the bottom edge of the grid to stop before flowing off of the screen and a vertical scrollbar to appear ON THE GRID. But instead, it will flow below the bottom of the screen and a vertical scrollbar will appear on the parent container (in this case, an HBox, VBox, etc) and I have to scroll the whole parent container down to get to the bottom of the grid.
      Example:
      <mx:HBox height=100%">
           <mx:Grid  width="500" height="100%" >
                <mx:GridRow>
                     <mx:GridItem>
                          <mx:Label text="123"/>
                     </mx:GridItem>
                </mx:GridRow>
                [bunch of these repeated...]
                <mx:GridRow>
                     <mx:GridItem>
                     </mx:GridItem>
                </mx:GridRow>
           </mx:Grid>
      </mx:HBox>
      Is this a bug? Am I doing something wrong?  Or does it just not work in the same way as other containers?  Anybody know if a good workaround?  I really need my grid dimensions to be constrained (100% x 100%) and it's driving me crazy.
      Thanks!!
        • 1. Re: 100% height does not work for Grid?
          crissy84 Level 1
          As soon as posted this, I got an idea which kinda/sorta works.  But I'd still like to know if there's a better way or what the deal is.
          I set the Grid's default height to 0, then in the resize event for the parent box, I set the grid's height equal to the parent container's height (minus a little to prevent an 2nd outer scrollbar).  See below.
          <mx:HBox id="outer" height=100%" resize="inner.height = outer.height - 5">
               <mx:Grid id="inner"  width="500" height="0" >
                    <mx:GridRow>
                         <mx:GridItem>
                         </mx:GridItem>
                    </mx:GridRow>
                    <mx:GridRow>
                         <mx:GridItem>
                         </mx:GridItem>
                    </mx:GridRow>
               </mx:Grid>
          </mx:HBox>
          • 2. Re: 100% height does not work for Grid?
            _Natasha_ Level 4
            Try to add this on Canvas
            • 3. Re: 100% height does not work for Grid?
              crissy84 Level 1
              Hi Natasha,
              Thank you for the suggestion.  But unfortunately it still gives me the same behavior.  I still have to scroll down (using an outer scrollbar) to get to the grid's horizontal scrollbar at the bottom which has gone off screen.
