0 Replies Latest reply on Sep 15, 2009 12:32 AM by peddireddyss
    problem in linux with flex
    peddireddyss
                   I'm new to linux with flex,am using Eclipse 3.5 flex builder 3 installing perfectly but when i'am  creating flex application it is showin Assertion failed error.
      org.eclipse.jface.util.Assert$AssertionFailedException: Assertion failed:
          at org.eclipse.jface.util.Assert.isTrue(Assert.java:179)
          at org.eclipse.jface.util.Assert.isTrue(Assert.java:164)
          at com.adobe.flexbuilder.editors.derived.editor.FlexMultiPageEditorPart.setActivePage(FlexMu ltiPageEditorPart.java:569)
          at com.adobe.flexbuilder.editors.common.editor.CodeAndDesignEditor.setActivePage(CodeAndDesi gnEditor.java:647)
          at com.adobe.flexbuilder.editors.mxml.MXMLEditor.setActivePage(MXMLEditor.java:487)
          at com.adobe.flexbuilder.editors.derived.editor.FlexMultiPageEditorPart.createPartControl(Fl exMultiPageEditorPart.java:235)
          at com.adobe.flexbuilder.editors.common.editor.CodeAndDesignEditor.createPartControl(CodeAnd DesignEditor.java:162)
          at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:662)
          at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:462)
          at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
          at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
          at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180 )
          at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFo lder.java:270)
          at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder .java:65)
          at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStack Presentation.java:473)
          at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1256)
          at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1209)
          at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1608)
          at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
          at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
          at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
          at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
          at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
          at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
          at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
          at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:778)
          at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:677)
          at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:638)
          at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2854)
          at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2762)
          at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2754)
          at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2705)
          at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
          at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2701)
          at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2685)
          at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2676)
          at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
          at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
          at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileAction.java:99)
          at org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystemEditorAction.java:99)
          at org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAction(OpenActionGroup.java:133)
          at org.eclipse.ui.views.navigator.MainActionGroup.runDefaultAction(MainActionGroup.java:330)
          at org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen(ResourceNavigator.java:787)
          at org.eclipse.ui.views.navigator.ResourceNavigator$6.open(ResourceNavigator.java:499)
          at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHel per.java:48)
          at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:842)
          at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
          at org.eclipse.core.runtime.Platform.run(Platform.java:888)
          at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
          at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
          at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:840)
          at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1101)
          at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1205)
          at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:264)
          at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:258)
          at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:298)
          at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
          at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3493)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3112)
          at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
          at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
          at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
          at java.lang.reflect.Method.invoke(Method.java:597)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
      am unable understand this error
