1. Re: Old Homesite user needs some CS3 customizing help
zabberwan Sep 15, 2009 2:02 AM (in response to talbot)Hello,
You can save a work space after setting it up or customising it to your needs: window > workpace layout > new workspace..
On the right side, open the panel for css styles (or under window). This panel has another window for properties under it and on the statusbar of that little panel is + sign. Click on it to make a new rule. You can also right click the last css rule and then click "Edit" to go in to the css selector/properties applet or you can opt to open the css file and write the rules directly..usually you will have a tab also for the css file at the top.
You can go to: http://www.adobe.com/designcenter/video_workshop/ ( click on products | select a title | play video )
Adobe does not leave you up the creek without a paddle!
zabberwan
2. Re: Old Homesite user needs some CS3 customizing help
talbot Sep 15, 2009 11:28 AM (in response to zabberwan)Thanks zabberwan, This will get me started.
And wow on the videos! I just spent about an hour and realized that all my skills have been canned now with this application!
Really robust and will make me life way easier. Now I can concentrate on SEO stuff instead of CSS and HTML...
