2 Replies Latest reply on Sep 15, 2009 4:50 AM by harsh_hot
    how to zoom a panel
    harsh_hot Level 1
      Hi All,
      I want a zoom facility in my application i.e. if i click the zoom button then all the elements in the panel should be zoomed to that extent. I am using <mx:Zoom> and <mx:Resize> tag but they zoom only that particular element which has evoked these tags. I want a dropdown on the panel with zoom options like 100%,200%,50% etc and when i select any value, all the elements in the panel should be resized according to the value selected.
      Please guide me
        • 1. Re: how to zoom a panel
          ShardulSingh Level 3
          Pls find the solution of your problem,and let me know if you have any issue.Hope this will full fill your requirement.
          MainApplication.MXML
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
          layout="absolute">
          <mx:Script>
          <![CDATA[
          import mx.core.Container;
          import mx.core.UIComponent;
          private function doZoom(component:UIComponent,val:Number):void
          component.scaleX = val;
          component.scaleY = val;
          if(component is Container)
          var children:Array = Container(component).getChildren();
          for(var i:int = 0; i < children.length; i++)
          doZoom(children[i], val);
          public function applyZoom():void
          if(pnl == null)
          return;
          doZoom(pnl,zoomSlider.value);
          </mx:Script>
          <mx:HBox horizontalAlign="right">
          <mx:VBox width="700" height="100%">
          <mx:Panel id="pnl" width="400" height="400" title="Panel">
          <mx:HBox width="100%" height="100%">
          <mx:Button label="B1"/>
          <mx:Button label="B2"/>
          <mx:Button label="B3"/>
          </mx:HBox>
          <mx:Button label="B11"/>
          <mx:Button label="B21"/>
          <mx:Button label="B31"/>
          </mx:HBox>
          </mx:Panel>
          </mx:VBox>
          <mx:VBox>
          <mx:HSlider id="zoomSlider" minimum=".1" value="1"
          maximum="2" change="applyZoom()" width="180"/>
          <mx:Label text="Apply Zoom"/>
          </mx:VBox>
          </mx:HBox>
          </mx:Application>
          with Regards,
          Shardul Singh Bartwal
          • 2. Re: how to zoom a panel
            harsh_hot Level 1
            Thanks a ton Shardul....You have been a great help!!!
