4 Replies Latest reply on Sep 22, 2009 2:51 AM by R_Thangaraj
    how to get selection text in indesign using C#?
    R_Thangaraj
      Hi to all,
      i need to get selection content text in indesign using C#
      pls help me
      Thank you
      Thangaraj
        • 1. Re: how to get selection text in indesign using C#?
          The same as in the other scripting languages:
          alert (app.selection[0].contents);
          Thank you
          Happy to help.
          • 2. Re: how to get selection text in indesign using C#?
            R_Thangaraj Level 1
            Hi Jongware,
            This is not correct in C# you have type cast all the object to another Object and then only we can access it in required format
            for example
            if want to get font in active Document
            InDesign.Application myInDesign=  (InDesign.Application) COMCreateObject("InDesign.Application");
            InDesign myDocument = (InDesign.Document)myInDesign.ActiveDocument;
            InDesign.ParagraphStyles pStyles = (InDesign.ParagraphStyle)myDocument.ParagraphStyles
            InDesign.ParagraphStyle pSteyls = (InDesign.ParagraphStyle)myDocument.ParagraphStyle
            for(int i =0;i<pStyles.Count;i++)
                 pStyle = (InDesign.ParagraphStyle)myDocument.ParagraphStyles[i];
            public static object COMCreateObject (string sProgID)
                // We get the type using just the ProgID
                Type oType = Type.GetTypeFromProgID (sProgID);
                if (oType != null)
                    return Activator.CreateInstance( oType);
                return null;
            like above content
            for selection content u have to type cast selection object.
            InDesign.Selection = (InDesign.Selection).myDocument.Selection;
            Console.Writeline(InDesign.Selection.Contents);
            but it showing error....
            like this you have to type cast all things in C# and you cannot simply get selection contents like app.selection[0].contents
            pls help me
            Thank you for your reply....
            R. Thangaraj
            • 3. Re: how to get selection text in indesign using C#?
              O-kay. Seems a lot of stuff happens behind javascript's back.
              Why would Writeline fail? You say it 'gives an error' but you don't say what error. I would guess this: "selection" is an untyped object in ID, because it can return all kinds of objects. In this particular case, you get a return value but you have to manually cast it to the type you would expect [*] -- in this case 'text'. An additional problem may be that it's probably Unicode (wide) text, and -- as documented -- if you select just one special character, it's not text at all but a long integer code for that special character.
              [*] That's quite the opposite of what happens with JS, but I think it's the case here.
              • 4. Re: how to get selection text in indesign using C#?
                R_Thangaraj Level 1
                Hi to all,
                I tried in Vb6 to get Indesign Com object and its working
                You can get selection content like this
                and you convert this code for C#
                Dim Appl As InDesign.Application
                Dim sel As Variant
                Private Sub Command1_Click()
                On Error GoTo Err1:
                Set Appl = CreateObject("InDesign.Application.CS3")
                Set sel = Appl.Selection(1) 'selection variable should be a variant
                MsgBox (sel.AppliedFont)
                MsgBox(sel.Contents)
                Err1:
                MsgBox Err.Number & " " & Err.Description
                End Sub
