9 Replies Latest reply on Sep 15, 2009 3:31 PM by kglad
    Get URL
    Ron Colmen Level 2
      1. How to receive the browser URL? I'd like to have the AS 2.0 code.
      2. In a form - how to avoid "required fields" been sent blank (E.g. Hitting the space key)? ANy perticular script.
        • 1. Re: Get URL
          1.  use getURL() if you want to open a new browser window or change what's loaded into the current browser window.  and use the _url property of the main timeline if you want to know the swf's url.  if you want to know the embedding html's url, use javascript and the externalinterface class.
          2.  i have no idea what you're asking.
          • 2. Re: Get URL
            Ron Colmen Level 2
            1. Embedding html's url - Could you show me a sample code?
            2. In a FORM - I have several fields as "REQUIRED FIELDS". I dont want someone just pressing the space bar for those REQUIRED FIELDS and hitting the submit button. How to make sure the REQUIRED FIELDS are filled with charactors rather than *,#,%,^, spaces ?
            • 3. Re: Get URL
              1.  in your html:
              <script language="JavaScript">
              function urlF(){
              return location.href;
              </script>
              in your flash:
              import flash.external.*;
              var urlS:String = String(ExternalInterface.call("urlF"));
              trace(urlS)
              2. use testF() to test if any string contains, at least, n alpha-numeric characters by using testF(anystring,n)
              var alphaNumS:String = "0123456789abcdefghijklmnopqrstuvwxyz";
              testF(s:String,n:Number):Boolean{
              var num:Number=0;
              for(var i=0;i<s.length;i++){
              if(alphaNumS.indexOf(s.substr(i,1).toLowerCase())>-1){
              num++;
              (num<n) ? return false: return true;
              • 4. Re: Get URL
                Ron Colmen Level 2
                Could the actionscript code be asigned to a dynamic text box? I need the URL to show in a dynamic text box at runtime.
                • 5. Re: Get URL
                  then assign urlS to a textfield's text property:
                  urlTF.text=urlS;
                  and testF() should have another curly bracket:
                  var num:Number=0;
                  num++;
                  • 6. Re: Get URL
                    Ron Colmen Level 2
                    CORRECT?
                    1.  Add to html:
                    function urlF(){
                    </script>
                    in flash - main timeline:
                    trace(urlS)
                    theurl.text=urlS;
                    var num:Number=0;
                    num++;
                    • 7. Re: Get URL
                      yes
                      • 8. Re: Get URL
                        Ron Colmen Level 2
                        Thanks!!
                        • 9. Re: Get URL
                          you're welcome.
