0 Replies Latest reply on Sep 15, 2009 10:46 AM by CoreyRLucier
    [svn:fx-trunk] 10269: Changing default for -enable-runtime-design-layers to true.
    CoreyRLucier Adobe Employee
      Revision: 10269
      Author:   clucier@adobe.com
      Date:     2009-09-15 10:46:10 -0700 (Tue, 15 Sep 2009)
      Log Message:
      Changing default for -enable-runtime-design-layers to true.  The flag may still be used to disable processing of design layer instances if so desired.
      QE notes: None
      Doc notes: None
      Bugs: SDK-23238
      Reviewer: Paul
      Tests run: Checkin
      Is noteworthy for integration: Yes, runtime design layers are now enabled by default.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23238
      Modified Paths:
          flex/sdk/trunk/frameworks/tests/basicTests/BasicTests-config.xml
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
