0 Replies Latest reply on Sep 15, 2009 10:54 AM by Paul Reilly
    [svn:fx-trunk] 10270: * A beta 2 fix.
    Paul Reilly Level 1
      Revision: 10270
      Author:   preilly@adobe.com
      Date:     2009-09-15 10:54:40 -0700 (Tue, 15 Sep 2009)
      Log Message:
      • A beta 2 fix.
      QE notes:
      Doc notes:
      Bugs: SDK-21830
      Reviewer: Corey
      Cycloner: Gaurav
      Tests run: checkintests
      Is noteworthy for integration: no
      Code-level description of changes:
        frameworks/tests/basicTests/halo/views/CollectionTests.mxml
          Removed extra curly brace found by running without direct AST
          generation.  I'll be logging a bug for this.
        modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
          Modified getDescriptorDeclaration() to use new
          DescriptorGenerator.addDescriptorInitializerFragments() signature.
        modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.java
          Modified getDefinitionBody() to use new
          and pass in an empty Set for the properties to include.  This
          outputs only the children, which is what we want.
          Modified generateDefinitionBody() to do the direct AST generation
          equivalent.
        modules/compiler/src/java/flex2/compiler/mxml/gen/DescriptorGenerator.java
          Renamed getDescriptorInitializerFragments() to
          addDescriptorInitializerFragments() and added list,
          includeDesignLayer, and indent parameters to allow more control
          over the output.
        modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
          Modified generateBindingsSetupFunction() to call
          generateTwoWayPrimaryAssignment() and added
          generateTwoWayPrimaryAssignment().
          Modified addDescriptorInitializerFragments() and
          addDescriptorProperties() by adding an includeDesignLayer
          parameter.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21830
      Modified Paths:
          flex/sdk/trunk/frameworks/tests/basicTests/halo/views/CollectionTests.mxml
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/DescriptorGenerator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.ja va
