7 Replies Latest reply on Sep 18, 2009 11:03 AM by kglad
    xml file and flvplayback AS2
    jdwild
      I'm using the flvplayback component that came with Flash CS4.
      To use with an xml file, it indicates that all I need to do is to enter the name of the file in the contentPath, which I have done (videostest.xml)
      Both Flash file, html file and xml file are in the same directory, so the path name should be fine.
      When I go to view the file nothing displays. If I enter the name of the actual FLV file it works fine, but I need to use an xml file.
      XML file text follows:
      <FlvPlayer>
              <item>
                  <file>WLA_Now_Fall_2008_Introduction.flv</file>
              </item>
      </FlvPlayer>
      I gave the component on the stage the instance name of FlvPlayer, but I don't think that matters.
      Do I need any other script on this page. Adobe knowledge center does not indicate to do so.
      TIA
