1 Reply Latest reply on Sep 15, 2009 12:51 PM by _Natasha_
    Problem with icon for an itemRendrer when scroll
    xkfjvxv Level 1
      Hello,
      I hav a data grid with three columns. In the first column I have to display an icon and a text in front of it.
      For this I do an item rendrer containing the following :
      <mx: Image id ="myIcon">
      <mx: Text  text={data.label} />
      The problem is when I scroll down the datagrid the itemRendrers are recycled and icons are not conserving their order.
      Any idea ?
        • 1. Re: Problem with icon for an itemRendrer when scroll
          _Natasha_ Level 4
          if you have wrong order, this means that
          or
          there is a error in your realization
          or
          there is a misunderstanding of concept itemRenderer.
          There are two important thing:
          - all images and text should be based on data (properties, attributes and other)! Not any order.
          - when data for itemRenderer changed, always called public function set data(value:Object):void. So you MUST override it tot change icons, labels and others.
