6 Replies Latest reply on Nov 24, 2009 8:01 AM by Ereadable
    Cannot Install
    Carrol Ray
      I am trying to install onto an intel MacBook Pro but I get the message that this software can only be installed on an intel computer and it is an intel.
      I have downloaded and tried several times - could it be a snow leopard issue÷
        • 1. Re: Cannot Install
          repandey
          Hi Carrol,
          This does not seems to be a snow leopard issue.
          Could you please post the exact error message that you are getting.
          Also please post the system configuration of your machine.
          • 2. Re: Cannot Install
            Carrol Ray Level 1
            I am using a new 15 inch MacBookPro -
            OS - 10.6.1
            3.06 Intel Cure 2 Duo
            4gb memory - 250 gb solid state drive
            Running in 64 bit mode
            I go to the Adobe website - then to the Digital Edition page and click on
            the launch icon which downloads the installer which starts the download.
            Then a window pops up which says"  Adobe Digital Editions can't be installed
            on this computer.  This installation will only work with intel based macs."
            • 3. Re: Cannot Install
              repandey Level 1
              Hi Carrol,
              Please try installing Digital editions from the following link:
              http://www.adobe.com/devnet/digitalpublishing/
              Download and install the Stand alone installer and let us know if this helped or not.
              • 4. Re: Cannot Install
                Carrol Ray Level 1
                Tried your suggestion and it still displays the same message.
                I am going to stop wasting may time on this product.
                Thanks for your help.
                • 5. Re: Cannot Install
                  Carrol Ray Level 1
                  I tried one more thing - I booted into 32 bit mode instead of 64 bit mode and I was able to install the software.
                  So - it seems that if you boot into 64 bit mode, there is some kind of an issue.
                  • 6. Re: Cannot Install
                    Ereadable
                    I've just dealt with a customer with exactly the same problem - Mac OS 10.6 Snow Leopard on an iMac which is running in 64-bit mode by default, installing under 32-bit mode works but means that the customer has to reboot in order to read ebooks as they use a number of 64-bit applications. Having a better error message would be a start (ie state that the installer doesn't support 64-bit rather than saying that it requires an Intel processor when the machine does have an Intel processor!), but is there any news on a possible update to support 64-bit installation?
