11 Replies Latest reply on Sep 22, 2009 12:01 PM by SForrest96
    does LiveCycle Digital Signatures support unicode pkcs #12 file?
    Jyang257 Level 1
      I used Adobe Acrobat and OpenSSL to generated a unicode pkcs#12 file. Import to the Windows are all correct. But when I used for LiveCycle Digital Signatures, after signed, the one use Acrobat generated pkcs12 file signed only can show ASCII character,and other one used OpenSSL pkcs12 file to signed,signature character changed to  irrecognizable.
        • 1. Re: does LiveCycle Digital Signatures support unicode pkcs #12 file?
          SForrest96 Level 4
          LiveCycle Digital Signatures ES does support the use of PKCS#12 (.p12, .pfx) X509 compliant files for the creation of a digital signature.  There is most likely something wrong with the certificate that you created, can you post it for testing (along with the password)?
          Steve
          • 2. Re: does LiveCycle Digital Signatures support unicode pkcs #12 file?
            Jyang257 Level 1
            These are two unicode pkcs #12 files. one created by openssl, another one created by Acrobat.
            I used this code to sign to the PDF file.
                    try    {
                        // This example will upload an XDP file to the LiveCycle Repository
                        ServiceClientFactory myFactory = ServiceClientFactory.createInstance(LCCommonUtil.getConnectionProps());
                        // Create a SignatureServiceClient object
                        SignatureServiceClient signClient = new SignatureServiceClient(myFactory);
                        // Specify a PDF document to sign
                        FileInputStream fileInputStream = new FileInputStream(
                                "C:\\Applications\\pdfForms\\TestDigitalSign\\ConferenceReg_flatten_sf_added.pdf");
                        Document credDoc = new Document(fileInputStream);
                        // Specify the name of the signature field
                        String fieldName = "SignatureField1";
                        // Create a Credential object
                        Credential myCred = Credential.getInstance("BLC_CHINA"); // LC Server: Local Credentials
                         System.out.println("******"+myCred.getSpiName());
                        // Specify the reason to sign the document
                        String reason = "The document was reviewed";
                        // Specify the location of the signer
                        String location = "New York HQ";
                        // Specify contact information
                        String contactInfo = "Tony Blue";
                        // Create a PDFSignatureAppearanceOptions object and show date information
                        PDFSignatureAppearanceOptionSpec appear = new PDFSignatureAppearanceOptionSpec();
                        appear.setShowDate(true);
                        appear.setShowReason(true);
                        // Set revocation checking to false
                        java.lang.Boolean revCheck = new Boolean(false);
                        // Create objects to pass to the sign method
                        OCSPOptionSpec ocspSpec = new OCSPOptionSpec();
                        CRLOptionSpec crlSpec = new CRLOptionSpec();
                        TSPOptionSpec tspSpec = new TSPOptionSpec();
                        // Sign the PDF document
                        Document signedDoc = signClient.sign(
                            credDoc,
                            fieldName,
                            myCred,
                            HashAlgorithm.SHA1,
                            reason,
                            location,
                            contactInfo,
                            appear,
                            revCheck,
                            ocspSpec,
                            crlSpec,
                            tspSpec);
                        // Save the signed PDF document
                        File outFile = new File("C:\\ConferenceReg_flatten_signed.pdf");
                        signedDoc.copyToFile(outFile);
                    catch (Exception ee) {
                        ee.printStackTrace();
            • 3. Re: does LiveCycle Digital Signatures support unicode pkcs #12 file?
              Jyang257 Level 1
              checked attachment for unicode p12 files. the password is : password
              please change the .txt extension from the file name.
              • 4. Re: does LiveCycle Digital Signatures support unicode pkcs #12 file?
                SForrest96 Level 4
                I was able to install the "Acrobat.pfx" (use "password" as the password), but the "Openssl.p12" file does not seem to use "password" as the password.  What is the password got the openssl.p12 file?
                Regards
                Steve
                • 5. Re: does LiveCycle Digital Signatures support unicode pkcs #12 file?
                  Jyang257 Level 1
                  I am sorry. the openssl.p12 file password is : blc123
                  • 6. Re: does LiveCycle Digital Signatures support unicode pkcs #12 file?
                    SForrest96 Level 4
                    Well, the problem is definately due to the digital certificate.  I was able to sign a PDF using LiveCycle Digital Signatures ES with the Acrobat created certificate.  When I tried the sign a PDF with the Open SSL certificate LC threw an error.
                    If you compare the certificates (see attached - rename with .cer extension) , there are a few differences, unfortunately I don't know which "difference" is responsible for the problem.  The Openssl certificate contains some double-byte characters (Issuer and Subject attributes)... maybe this is part of the issue?
                    Hope this helps.
                    Steve
                    • 7. Re: does LiveCycle Digital Signatures support unicode pkcs #12 file?
                      Jyang257 Level 1
                      Yes. you are right. the OpenSSL certificate contains some double-byte characters( that's why I need use unicode, Cause I want to put Chinese characters into Issuer and Subject attribute) also the acrobat one include both ASCII and Unicode(double-byte Chinese characters), but when you sign it, you only can saw the Digital Signatures only use the ASCII code for sign, not the unicode. That's why I asked if LiveCycle Digital Signatures support unicode pkcs #12 file or not?
                      • 8. Re: does LiveCycle Digital Signatures support unicode pkcs #12 file?
                        SForrest96 Level 4
                        I will continue my investigation.  I'll let you know what I turn up as soon as possible.
                        Regards
                        Steve
                        • 11. Re: does LiveCycle Digital Signatures support unicode pkcs #12 file?
                          SForrest96 Level 4
                          I'm continuing to investigate.  Sorry for the delay.
                          Regards
                          Steve
