9 Replies Latest reply on Sep 18, 2009 12:27 AM by _Natasha_
    Show XML tree faher label
    zakabalt
      Hello, I have one XMl with this estructure:
      <?xml version="1.0" encoding="UTF-8"?>
      <Cuentas>
      <Cuenta id="cuenta1" label="cuenta1">
      <node label="Borrador"></node>
      <node label="Carpeta1"></node><node label="Carpeta2"></node>
      <node label="Elementos enviados"></node>
      <node label="INBOX"></node>
      <node label="Sent"></node>
      <node label="Trash"></node>
      <node label="[Gmail]">
          <node label="Bidalitako mezuak"></node>
          <node label="Izardunak"></node>
          <node label="Mezu guztiak"></node>
      </node>
      </Cuenta>
      </Cuentas>
      Now I'm only printing node labels, I can print also the Cuenta label, doing somethin not very complicate? I want something like this
      Cuenta1
      -> INBOX
      -> Sent
      No I have
      INBOX
      Sent
      Thanks!
        • 1. Re: Show XML tree faher label
          _Natasha_ Level 4
          what do you set as dataProvider for tree?
          In Tree there is an attribute "showRoot" (default true).
          So you can set Cuentas.* to dataProvider and check that showRoot = true and it should work.
          • 2. Re: Show XML tree faher label
            zakabalt Level 1
            I was searching showRoot thanks, I used one day but I didn't remember the name.
            I was searching this attribute but I'm using and doesn't work. Probably I'm giving wrong the dataprovider. I'm doing that to give the dataprovider for the tree.
            private function treeLoadedResult(event:ResultEvent):void {
                          xmlTree = XML(event.result.toString());//here I get the tree
                          var lista:XMLList= xmlTree.Cuenta;
                          for(var i:Number=0;i<lista.length(); i++)
                               var tmpTree:XMLList = xmlTree.Cuenta[i].node;
                              newTree.dataProvider = tmpTree;
                                treePanel.addChild(newTree);
                              openAllTreeNodes(newTree);
            I use this function because sometimes I put it more than one tree in the Hbox(treePanel).
            What dataprovider I have to gice to put it Cuenta1?
            Thanks for your help!
            • 3. Re: Show XML tree faher label
              _Natasha_ Level 4
              Yes, you get only a nodes to your tree without Cuenta node.
              Try this:
                            newTree.dataProvider = lista;
              • 4. Re: Show XML tree faher label
                zakabalt Level 1
                Yes, you're right, now I can see the father label.
                Thank you!
                Best regards
                • 5. Re: Show XML tree faher label
                  zakabalt Level 1
                  I have solved this problem, but if I have more than one Cuenta with different id and label, how I can show the two Cuenta in different trees? If I only put it list in the dataprovider I can show the two(or three or...) trees? Or how I have to change in my code?
                  Here the structure that I want, 3 trees in one VBox
                  Cuenta1
                  -> Inbox
                  -> Trash
                  Cuenta2
                  -> Inbox
                  -> Trash
                  Cuenta4
                  -> Inbox
                  -> Trash
                  Thanks!
                  • 6. Re: Show XML tree faher label
                    _Natasha_ Level 4
                    You can try, it should work if all Cuenta elements is in one Cuentas element.
                    • 7. Re: Show XML tree faher label
                      zakabalt Level 1
                      Have you tried? I have tried and I only show one Cuenta, not all the cuentas of my xml. I don't know if I'm doing something wrong or you forgot to tell me something. Here my xml:
                      <Cuentas>
                      <Cuenta id="cuenta1" label="prueba@xxxx.com">
                           <node label="INBOX" id="(27217)">
                                <node label="Adur" id="(2)"></node>
                                <node label="Drafts"></node>
                                     <node label="Flex" id="(49)">
                                          <node label="Codigo"></node>
                                          <node label="Documentacion"></node>
                                     </node>
                           </node>
                      </Cuenta>
                      <Cuenta id="cuenta1" label="prueba2@xxxx.com">
                           <node label="INBOX" id=27217></node>
                      </Cuenta>
                      </Cuentas>
                      How should be my tree creator? I have something like this. I have tried with for and without for and didn't work any.
                                    xmlTree = XML(event.result.toString());//here I get the XML
                                    //for(var i:Number=0;i<lista.length(); i++)
                                     //    var tmpTree:XMLList = xmlTree.Cuenta[i].node;
                                      //newTree.labelField = "@label";
                                      newTree.labelFunction = treeLabelTrad;
                                      newTree.showRoot = true;
                      If you have a better solution changing more than one thng don't worry, you can propose.
                      • 8. Re: Show XML tree faher label
                        _Natasha_ Level 4
                        In your XML:
                             <node label="INBOX" id="27217"></node>
                        </Cuenta>
                        id is the same as previous - not good.
                        Add in your function trace
                        trace(lista.toXMLString());
                        // or
                        Alert.show(lista.toXMLString());
                        // and
                        trace(event.result);
                        // or
                        Alert.show(event.result.toString());
                        • 9. Re: Show XML tree faher label
                          zakabalt Level 1
                          I'm sorry, You're right since the first moment. I had an error in my service, not in my tree creator. I'm sorry
                          Thaks!!
