3 Replies Latest reply on Sep 21, 2009 7:30 AM by Novistorm
    Javascript element content without child elements CS3
    Novistorm
      i have the following problem which i hope you guys can help me with.
      i have create the following xml structure in idesign
      <root>
      <story>
           <element1>
                <subelement>this is some content in subelement</subelement>
                this is some content in element1
           </element1>
      </story>
      </root>
      now i want to get with javascript the content of element1.
      but then i use the following code
      var xmlelement = some code to get element1
      xmlelement.contents or xmlelement.xmlContent.contents
      i get this text returned
      and not only this text
      i want only the content from element1 and not element1 and all his sub elements
        • 1. Re: Javascript element content without child elements CS3
          AdobeScripts Level 3
          but contents of element1 contains all sub-elements
          you need to get contents of element1 to variable and then get positions and length of all sub-elements and delete it from this variable ...
          ... or you can copy whole element1 to new TextFrame and then delete all sub-elements and then you will have only element1.contents
          robin
          www.adobescripts.co.uk
          • 2. Re: Javascript element content without child elements CS3
            Novistorm Level 1
            ok ty, i'll search for the method to get the positions since i need the text of the other elements aswell (not at the same time though) so retrieval must be in the same order as in the xml
            • 3. Re: Javascript element content without child elements CS3
              Novistorm Level 1
              Hmm dont get it working yet
              i want to get the data but it must be in order from the elements
              if i use this example again with a little addition
              <root>
              <story>
                   <element1>
                         <subelement2>this is some content in subelement2</subelement2>
                   </element1>
              </story>
              </root>
              i want to loop through the element1 so i can make a array like this
              array['subelement'] = 'this is some content in subelement'
              array['element1'] = ' this is some content in element1';
              array['subelement2'] = 'this is some content in subelement2';
              the element ordering is most of the time different the same it could also been this for example
              <root>
              <story>
                   <element1>
                   </element1>
              </story>
              </root>
