0 Replies Latest reply on Sep 16, 2009 8:47 AM by PrinceKheldar
    Transitions and labels
    PrinceKheldar Level 1
      Hi everybody!
      I have this small test program where I have two states, one with 2 labels and one (base state) without.
      I also have an image that makes the change from state "base" to state "withLabels".
      Good news, this simple code works just fine.
      Since I'm such a megalomaniac, I decided I wanted more Adobe goodness: I would add TRANSITIONS!
      Bad news, this doesn't work. Or, shoud I say... it works just fine, but not as I intended.
      What I thought would happen: the "transitionned sequence" would start, label1 would wipeLeft, then label2 would wipeLeft. Fine.
      That's exactly what happens! Can I has a cookie?
      But there is a catch: label2 displays while label1 does its wipeLeft. No cookie for me then.
      Now, is there some property to set such as "startTransitionHidden"? I can't believe I either have to:
      - set up one state per element I wish to sequence (THAT seems stupid)
      or
      - play with addChild/removeChild (which seems to beat the purpose of using states to me).
      Can someone with his considerable knowledge and magnanimous greatness (am I overdoing it here?) help me solve this question:
      how can I make my transition display fine?
      (For the record, the effect I had in mind when I started out, by the way, is the "Mission:Impossible" or James Bond movies effect where some action takes place and labels come typewriting over it, one at a time, as in : "Murmansk, Russia"--> label1, then "Present day, present time"-->label2)
