2 Replies Latest reply on Sep 16, 2009 11:31 AM by babo_ya
    Cannot set ComboBox selectedIndex during ComboBox creation?
    Calculoso
      Hello,
      I have an outside dataprovider that properly fills in the values in the combo box.  However, there is no "default value" of the comboBox (selectedIndex == -1) and I cannot change this for a small amount of time.  Trying to set
      myComboBox.selectedIndex = 0;
      upon creationComplete doesn't work.  When I trigger the same event through a keypress, the selectedIndex properly updates and displays in the comboBox.  Essentially, I am looking for a way to display a default value in this comboBox (which is dependent on data; i.e. it will not always be the same.
        • 1. Re: Cannot set ComboBox selectedIndex during ComboBox creation?
          derryDev
          Can you post a small code snippet for this?
          I'll have a wee look and see what advice i can give!!
          • 2. Re: Cannot set ComboBox selectedIndex during ComboBox creation?
            babo_ya
            Try this..
            package src
            import flash.events.*;
            import mx.controls.ComboBox;
            import mx.events.FlexEvent;
            public class ExtendedCombo extends ComboBox
            private var _defaultValue:String;
            public function ExtendedCombo()
            super();
            protected override function createChildren():void
            super.createChildren();
            this.addEventListener(FlexEvent.CREATION_COMPLETE, onCreateCC);
            private function onCreateCC(event:FlexEvent):void
            textInput.text = _defaultValue;
            protected override function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
            super.updateDisplayList(unscaledWidth, unscaledHeight);
            public function get defaultValue():String
            return _defaultValue;
            public function set defaultValue(value:String):void
            _defaultValue = value;
            public function updateDefaultValue(v:String):void
            textInput.text = v;
            _defaultValue = v;
            and the main.mxml
            <?xml version="1.0"?>
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
              creationComplete="init();" xmlns:src="src.*">
              <mx:Script>
                <![CDATA[
                  [Bindable]
                  public var dp:Array = new Array("1", "2", "3" , "4");
                  private function clickHandler(event:MouseEvent):void
                  cmb.updateDefaultValue("New default value");
              </mx:Script>
            <mx:Button label="update" click="clickHandler(event);" />
            <src:ExtendedCombo width="150" id="cmb" dataProvider="{dp}" defaultValue="Default" />
            </mx:Application>
            hope this helps,
            BaBo,
