1 Reply Latest reply on Sep 16, 2009 11:06 AM by the_wine_snob
    DVD --> web. How?
    doss79 Level 1
      A client sent me a DVD that they want me to edit and post clips of that on their website.
      What's my workflow for this? I have Premiere Pro CS3. Any free programs I can download to export from the DVD vob files into a format I can edit in premiere Thanks.
        • 1. Re: DVD --> web. How?
          the_wine_snob Level 9
          Here is an Encore FAQ entry with one workflow and some utility suggestions. There are many more applications that will rip from DVD.
          You might first try copying the .VOB(s) to your HDD and changing the file extension to .MPEG. This works in most cases, so long as the DVD's Menuing does not get in the way. This is normally manifested in problems with the first .VOB.
          This ARTICLE might give you some background on .VOB's.
          Another workflow would be to hook up your DVD player to the input connections on your video camera. It will need to have pass-through capabilities. You can then possibly Capture in PrPro, but you will NOT have device control. However, it's easy to manually start Capture, then start the cued up DVD player.
          PS CS4.1 will Import 100% compliant DVD's, but that upgrade is not free.
