23 Replies Latest reply on Oct 30, 2009 9:00 AM by ajz2009
    Fireworks Crashes / Freezes When Using the Text Tool
    Neil S. White
      Mac Octocore > OSX 10.6.1
      Master Collection > Fireworks CS4
      First I noticed the text box shift.Then Fireworks CS4 would freeze during any of the following:
      • Resize grouped text
      • Move text box
      • Click on text box to edit with type tool
      • Double-click on text box to edit with pointer tool
      So I started a brand new file, but encountered the same outcome. Thus, Fireworks CS4 is currently useless if text is needed. I can create vector based objects, but just clicking on the canvas (or clicking the font menu) with the text tool freezes Fireworks CS4 instantly. I've had similar issues with Fireworks CS3 edition, but if I started a new file, I was at least able to use the text tool again and type. Now, I can't even recreate the file. I have to abandon Fireworks and use a combination of Photoshop and Illustrator before my timeline becomes even further behind.
      I'm at a complete loss.
      Neil
        • 2. Re: Fireworks Crashes / Freezes When Using the Text Tool
          Neil S. White Level 1
          Deleting the FW Preference files (instructions below) worked once. Then I created another new file (just to be safe) and started all over. Worked great for an hour. And just as I felt progress and things were coming together on my layout... FRRRRRRREEEEEEZE! I keep deleting the preferences and I can move vector objects, but cannot type anything, type tool freezes the app.
          Ironic, that a product named FIREworks, would FREEZE(and NOT)work.
          Suggested names for CS5 edition of Fireworks:
          Freezefails
          Freezeloss
          Freezelazy
          Freezewrong
          Restore default preferences
          • Quit Fireworks.
          • Locate the Fireworks      Preferences file on your hard disk and delete it.
            The exact location of this file varies from system to system.
          • In Windows, preferences are      in your user-specific Fireworks configuration folder.
          •     Windows [Drive]:\Documents and Settings\[UserName]\Application Data\Adobe\Fireworks CS#\English\
          • In Mac OS, preferences are in      the Library/Preferences folder in your user folder. For information about      locating your Mac OS user folder, see Apple Help.
          • Mac              [User]/Library/Preferences/Adobe Fireworks CS#/en/Fireworks Preferences
          • Note: On Mac OS, most      Fireworks user-specific configuration files are stored in your      user-specific Application Support folder.
                    The Fireworks CS4 Preferences file is an exception.
          • 3.  Restart Fireworks.
          • The next time Fireworks is launched, a new preferences      file will be created that restores Fireworks to its original      configuration.
          • 5. Re: Fireworks Crashes / Freezes When Using the Text Tool
            Deleting Preferences does nothing now. Freezequits simply crashes on any file, new or old when using the text tool. I can't work on any Fireworks files. This is a brand new operating system, brand new install of CS4, brand new Adobe fonts, no additional fonts from any company are on my machine right now. I absolutely cannot believe this issue. I have several designer/AD/CD friends who all feel the same way about Fireworks right now. What a loss, it really is a useful app WHEN IT WORKS. Adobe, WTF Mates? How can this issue still be going on? How much time have designers lost due to this issue. I have been around since Aldus Freehand and Photoshop (1). I actually pay for the apps and tried to support Adobe, and I simply cannot believe that you would release this product with such major issues. And to let it continue without a complete resolve for so long. I just upgraded to CS4, but I had similar issues with CS3 and lost many files. Usually I was atleast able to start over. Now I can't do anything with text, period. Useless. Totally useless and disruptive to workflow and costly to our entire company.
            Distressed,
            Neil S. White
            • 6. Re: Fireworks Crashes / Freezes When Using the Text Tool
              Dave Hogue Level 2
              Unfortunately, it sounds like the problems you are encountering are more complex than perhaps a users' forum will be able to resolve. This is a public forum, and Adobe Tech Support does not monitor it for offering assistance. You might want to contact them directly:
              http://www.adobe.com/support/
              • 7. Re: Fireworks Crashes / Freezes When Using the Text Tool
                ajz2009
                Neil,
                So you know, I am having the exact problem with a similar "new" setup.
                Please post any solutions you get here and I'll do the same.
                Thanks,  Paul
                • 8. Re: Fireworks Crashes / Freezes When Using the Text Tool
                  Paul -
                  Will do. And I've seen other postings of similar instances... with no solution thus far. I've had to revert to Fireworks CS3 for the time being... which in the past has occasionally given me the same difficulties. Sometimes trashing the Fireworks Preferences did the trick in CS3 though.
                  • 9. Re: Fireworks Crashes / Freezes When Using the Text Tool
                    al j Level 1
                    Same problem here had adobe support point me to this:
                    http://kb2.adobe.com/cps/405/kb405840.html
                    which is their get out of jail free card. It basically makes you test everything, replace everything, and apparently will fix everything. If not its our fault. Please confirm if this works for you hasn't for me which left adobe support a little stuck.
                    • 10. Re: Fireworks Crashes / Freezes When Using the Text Tool
                      jerrysilverman Adobe Employee
                      Hi Neil, I’m an SE from Adobe, and I’d like to help. I’m sending you a message privately, so please check your forum Inbox.  Jerry Silverman Solutions Engineer, Adobe Technical Sales
                      • 11. Re: Fireworks Crashes / Freezes When Using the Text Tool
                        Thank you Jerry. I am checking now. Fireworks has been completely unusable. I have to switch back to CS3 on my Leopard drive to work with it.
                        • 12. Re: Fireworks Crashes / Freezes When Using the Text Tool
                          ajz2009 Level 1
                          Hi, Neil.
                          Let me know if you get a solution from Adobe.  Like you, Fireworks CS4 is unusable to me right now.
                          Thanks,  Paul
                          • 13. Re: Fireworks Crashes / Freezes When Using the Text Tool
                            al j Level 1
                            Can you lets us all know, i'm also have to work on another machine in  the meantime.
                            • 14. Re: Fireworks Crashes / Freezes When Using the Text Tool
                              All - I have been given no actual solution yet. Basically the usual "read from my script" tech support. Fireworks is still useless and more and more people are telling me similar stories. Here is the response from Adobe Tech Support to this chain, and he points to my Dual Quad (Octocore) Mac as to where the problem may lie... who knew, the fastest machine would work with slowest program. But it is an interesting suggestion.
                              What machines are you guys having issues with? Here is my basic setup:
                              (all of the suggestions in the below email I had already gone through... I have  replied three times to this email now, with no reply back - as of yet)
                              Hi Neil,
                              Sorry to hear you're having problems with your Fireworks CS4 install.
                              Curious if you've had any luck since you posted to the forum.
                              The Technote that Al J pointed you to is pretty comprehensive, and it's probably worth it to go through the list at least once.  I've got a feeling that your Octocore Mac, while awesome for video editing speed, may have some sort of architectural conflict with Fireworks that makes itself evident with the Text Tool (have you tried installing on a Quad or Dual Core Mac to compare the differences?).  There may also be an undocumented issue with Snow Leopard that you've discovered (did the Text Tool behave thus on 10.5.8?).
                              Fireworks, in the CS4 incarnation, took on the Adobe Text Engine (ATE) that Photoshop and Illustrator use to render fonts, but as you've seen, it plays differently with different hardware/software configs, sometimes well and sometimes less well.  There are many deployments in the wild that don't face these issues (at least, so far), but we're sorry that this has been so frustrating for you.
                              David's suggestion of contacting Support is correct, so that's another avenue. If you do contact Support, and you encounter less-than-excellent quality of service or interminable wait times, let me know and I'm happy to help escalate your case up the chain.
                              Best of luck --
                              Jxxxx Sxxxxxxxxx
                              • 15. Re: Fireworks Crashes / Freezes When Using the Text Tool
                                awulfa
                                I had the same problem, but it was fixed when I installed ALL of the updates in Adobe update manager.
                                • 16. Re: Fireworks Crashes / Freezes When Using the Text Tool
                                  lennil0
                                  I have the same issue on a Macbook Pro running 10.6.1. I reinstalled the entire creative suite 3 times and finally had Fireworks back up and running. Used it all day yesterday without a hitch.Today I ran the software update from Adobe (10.0.3.11) and the hang when using the text tool issue is back.
                                  Very frustrating.
                                  • 17. Re: Fireworks Crashes / Freezes When Using the Text Tool
                                    Sarthak Singhal Adobe Employee
                                    Hi all,
                                    The Fireworks team is made aware of this issue and we are working on to see where the issues lies. This issue is a high priority for us and we are working to nail this one.
                                    We are close to something and request you to be patient for a short time.
                                    ..Sarthak
                                    http://blogs.adobe.com/sarthak
                                    • 18. Re: Fireworks Crashes / Freezes When Using the Text Tool
                                      The freeze issue with text tool on Snow Leopard has been investigated by the Fireworks team and the solution has been posted on my blog at http://blogs.adobe.com/sarthak/2009/10/fireworks_cs4_text_tool_on_sno.html
                                      • 19. Re: Fireworks Crashes / Freezes When Using the Text Tool
                                        al j Level 1
                                        Thanks very much after a disappointing start Adobe really came through thanks to Sarthak. Works for me I can now use the Text Tool and get some work done. Thanks again.
                                        • 20. Re: Fireworks Crashes / Freezes When Using the Text Tool
                                          Thank you to the Adobe team, including Sarthak and Julian, who contacted me directly and found a (so far, so good) solution (replacing the "GlobalResources" file in the “/Applications/Adobe Fireworks CS4/Required/” folder with a modified version of their own.
                                          DOWNLOAD THE NEW GLOBAL RESOURCE FILE HERE
                                          • 21. Re: Fireworks Crashes / Freezes When Using the Text Tool
                                            Good news Neil.
                                            We appeal to all Fireworks users and folks browsing the forums to spread the news around of this issue and its resolution.
                                            • 22. Re: Fireworks Crashes / Freezes When Using the Text Tool
                                              Open Fireworks
                                              Open >New Document
                                              Paste > image from clipboard (copied from Safari browser)
                                              Skittles spinning wheel of unlove
                                              report below:
                                              Date/Time:       2009-10-19 11:55:48 -0400
                                              OS Version:      10.6.1 (Build 10B504)
                                              Architecture:    x86_64
                                              Report Version:  6
                                              Command:         Fireworks
                                              Path:            /Applications/Adobe Fireworks CS4/Adobe Fireworks
                                              CS4.app/Contents/MacOS/Adobe Fireworks CS4
                                              Version:         Adobe Fireworks CS4 version "10.0.3.011" (10.0.3)
                                              Parent:          launchd
                                              PID:             25588
                                              Event:           hang
                                              Duration:        6.86s (sampling started after 2 seconds)
                                              Steps:           48 (100ms sampling interval)
                                              Pageins:         0
                                              Pageouts:        0
                                              Process:         Adobe Fireworks CS4
                                              UID:             501
                                              Process:         Adobe Illustrator
                                              Path:            /Applications/Adobe Illustrator CS4/Adobe
                                              Illustrator.app/Contents/MacOS/Adobe Illustrator
                                              UID:             501
                                              Process:         Adobe InDesign CS4
                                              Path:            /Applications/Adobe InDesign CS4/Adobe InDesign
                                              CS4.app/Contents/MacOS/Adobe InDesign CS4
                                              UID:             501
                                              Process:         AdobeCrashDaemon
                                              CS4.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/
                                              Resources/AdobeCrashDaemon.app/Contents/MacOS/AdobeCrashDaemon
                                              UID:             501
                                              Path:            /Applications/Adobe Dreamweaver CS4/Adobe Dreamweaver
                                              UID:             501
                                              Illustrator.app/Contents/Frameworks/AdobeCrashReporter.framework/
                                              Versions/A/Resources/AdobeCrashDaemon.app/Contents/MacOS/
                                              AdobeCrashDaemon
                                              UID:             501
                                              UID:             501
                                              Process:         AirPort Base Station Agent
                                              Path:            /System/Library/CoreServices/AirPort Base Station
                                              Agent.app/Contents/MacOS/AirPort Base Station Agent
                                              UID:             501
                                                 Thread 179e33d4
                                                 User stack:
                                                   48 ??? (in AirPort Base Station Agent + 5344)
                                                     48 ??? (in AirPort Base Station Agent + 70666)
                                                       48 CFRunLoopRun + 70 (in CoreFoundation)
                                                         48 CFRunLoopRunSpecific + 575 (in CoreFoundation)
                                                           48 __CFRunLoopRun + 2002 (in CoreFoundation)
                                                             48 mach_msg_trap + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   48 ipc_mqueue_receive_continue + 0
                                                 Thread 179f63d4
                                                 User stack:
                                                   48 start_wqthread + 13 (in libSystem.B.dylib)
                                                     48 pthreadwqthread + 353 (in libSystem.B.dylib)
                                                       48 dispatchworker_thread2 + 244 (in libSystem.B.dylib)
                                                         48 dispatchqueue_invoke + 195 (in libSystem.B.dylib)
                                                           48 kevent + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 1d0ad7a8
                                                 User stack:
                                                   48 thread_start + 13 (in libSystem.B.dylib)
                                                     48 pthreadstart + 331 (in libSystem.B.dylib)
                                                       48 ??? (in AirPort Base Station Agent + 71314)
                                                         48 ??? (in AirPort Base Station Agent + 13712)
                                                           48 ??? (in AirPort Base Station Agent + 71484)
                                                             48 __semwait_signal + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   48 semaphore_wait_continue + 0
                                                 Thread 1d0adb7c
                                                 User stack:
                                                       48 select$DARWIN_EXTSN + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Binary Images:
                                                        0x100000000 -        0x100016fff
                                              com.apple.AirPortBaseStationAgent 1.5.4 (154.2) <73DF13C1-AF86-
                                              EC2C-9056-8D1946E607CF> /System/Library/CoreServices/AirPort Base
                                              Station Agent.app/Contents/MacOS/AirPort Base Station Agent
                                                     0x7fff82fd6000 -     0x7fff83149fef  com.apple.CoreFoundation
                                              6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/
                                              Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                                     0x7fff85e67000 -     0x7fff86025ff7  libSystem.B.dylib ???
                                              (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylib
                                              Process:         AppleSpell
                                              Path:            /System/Library/Services/AppleSpell.service/Contents/
                                              MacOS/AppleSpell
                                              UID:             501
                                                 Thread 179eeb7c
                                                 User stack:
                                                   48 ??? (in AppleSpell + 5976)
                                                     48 ??? (in AppleSpell + 6632)
                                                       48 -[NSSpellServer run] + 72 (in Foundation)
                                                 Kernel stack:
                                                 Thread 1f3f03d4
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Binary Images:
                                                        0x100000000 -        0x1000a9fef  com.apple.AppleSpell 1.6
                                              (61) <9297064E-04F0-2CBF-0A16-6050010DAC3D> /System/Library/Services/
                                              AppleSpell.service/Contents/MacOS/AppleSpell
                                                     0x7fff84b9f000 -     0x7fff84e20fe7  com.apple.Foundation 6.6
                                              (751) <CCE98C5C-DFEA-6C80-A014-A5985437072E> /System/Library/
                                              Frameworks/Foundation.framework/Versions/C/Foundation
                                              Process:         autofsd
                                              Path:            /usr/libexec/autofsd
                                              UID:             0
                                                 Thread 1748e7a8
                                                 User stack:
                                                   48 ??? (in autofsd + 5340)
                                                     48 ??? (in autofsd + 6461)
                                                 Kernel stack:
                                                 Thread 17500000   DispatchQueue 2
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Binary Images:
                                                        0x100000000 -        0x100001ff7  autofsd ??? (???)
                                              <29276FAC-AEA8-1520-5329-C75F9D453D6C> /usr/libexec/autofsd
                                              Process:         blued
                                              Path:            /usr/sbin/blued
                                              UID:             0
                                                 Thread 1748eb7c
                                                 User stack:
                                                   48 ??? (in blued + 6232)
                                                     48 ??? (in blued + 130148)
                                                       48 -[NSRunLoop(NSRunLoop) run] + 77 (in Foundation)
                                                         48 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 270 (in
                                              Foundation)
                                                 Kernel stack:
                                                 Thread 175713d4   DispatchQueue 2
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Binary Images:
                                                        0x100000000 -        0x10003bfff  blued ??? (???)
                                              <2155B8CF-9765-0B49-3B94-1EFF788A2A2B> /usr/sbin/blued
                                              Process:         Calculator
                                              Path:            /Applications/Calculator.app/Contents/MacOS/Calculator
                                              UID:             501
                                                 Thread 1e616000
                                                 User stack:
                                                   48 ??? (in Calculator + 6464)
                                                     48 NSApplicationMain + 364 (in AppKit)
                                                       48 -[NSApplication run] + 395 (in AppKit)
                                                         48 -[NSApplication
                                              nextEventMatchingMask:untilDate:inMode:dequeue:] + 155 (in AppKit)
                                                           48 _DPSNextEvent + 718 (in AppKit)
                                                             48 BlockUntilNextEventMatchingListInMode + 59 (in
                                              HIToolbox)
                                                               48 ReceiveNextEventCommon + 310 (in HIToolbox)
        48 RunCurrentEventLoopInMode + 333 (in HIToolbox)
                                                 Kernel stack:
                                                 Thread 29fca7a8
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 2a2ba7a8
                                                 User stack:
                                                       48 startIOThread(void*) + 139 (in CoreVideo)
                                                         48 CVDisplayLink::runIOThread() + 739 (in CoreVideo)
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x100015fff  com.apple.calculator 4.5.2
                                              (97) <630F388E-CE64-0DB8-18E7-39A0D3DA0A05> /Applications/
                                                     0x7fff81fc3000 -     0x7fff829b7fe7  com.apple.AppKit 6.6.1
                                              (1038.2) <C17AD2AC-8639-D20F-CD99-36EEC619A5F0> /System/Library/
                                              Frameworks/AppKit.framework/Versions/C/AppKit
                                                     0x7fff86ebe000 -     0x7fff86ee2ff7  com.apple.CoreVideo 1.6.0
                                              (43.0) <FF5F0EEF-56BE-24DD-C8FA-CB41F126E6A8> /System/Library/
                                              Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                                                     0x7fff86fe4000 -     0x7fff872e1fef  com.apple.HIToolbox 1.6.0
                                              (???) <870B39B2-55BD-9C82-72EB-2E3470BD0E14> /System/Library/
                                              Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/
                                              Versions/A/HIToolbox
                                              Process:         configd
                                              Path:            /usr/libexec/configd
                                              UID:             0
                                                 Thread 16cb8000
                                                 User stack:
                                                   48 start + 52 (in configd)
                                                     48 main + 2051 (in configd)
                                                       48 server_loop + 72 (in configd)
                                                 Kernel stack:
                                                 Thread 16c23b7c   DispatchQueue 2
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 16c2f000
                                                 User stack:
                                                       48 plugin_exec + 1440 (in configd)
                                                 Kernel stack:
                                                 Thread 1733a7a8
                                                 User stack:
                                                       48 iopm_force_active_settings + 2266 (in PowerManagement)
                                                 Kernel stack:
                                                 Thread 1739e7a8
                                                 User stack:
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Thread 17686000
                                                 User stack:
                                                     48 __workq_kernreturn + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   48 workqueue_thread_yielded + 562
                                                 Binary Images:
                                                        0x100000000 -        0x100026ff7  configd ??? (???)
                                              <9ED4C5BD-86FA-DE9B-A948-8BE9ADE9005F> /usr/libexec/configd
                                                        0x100489000 -        0x10049afff
                                              com.apple.SystemConfiguration.PowerManagement 160.0.0 (160.0.0)
                                              <42FFC4FD-5D78-F476-2A4E-015951986425> /System/Library/
                                              SystemConfiguration/PowerManagement.bundle/Contents/MacOS/
                                              PowerManagement
                                              Process:         coreaudiod
                                              Path:            /usr/sbin/coreaudiod
                                              UID:             202
                                                 Thread 173b7000
                                                 User stack:
                                                   48 ??? (in coreaudiod + 3312)
                                                     48 ??? (in coreaudiod + 26565)
                                                 Kernel stack:
                                                 Thread 179f53d4   DispatchQueue
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 1ce0f000
                                                 User stack:
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x10001ffef  coreaudiod ??? (???)
                                              <8580E560-986B-5336-B8B7-968C3E7C22A2> /usr/sbin/coreaudiod
                                              Process:         coreservicesd
                                              Path:            /System/Library/CoreServices/coreservicesd
                                              UID:             0
                                                 Thread 175b2000
                                                 User stack:
                                                   48 ??? (in coreservicesd + 3756)
                                                     48 _CoreServicesServerMain + 522 (in CarbonCore)
                                                 Kernel stack:
                                                 Thread 174407a8
                                                 User stack:
                                                   47 start_wqthread + 13 (in libSystem.B.dylib)
                                                     47 __workq_kernreturn + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   47 workqueue_thread_yielded + 562
                                                   1 thread_bootstrap_return + 0
                                                 Thread 17686b7c
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 17999000
                                                 User stack:
                                                       48 read + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   48 lo64_unix_scall + 77
                                                     48 unix_syscall64 + 617
                                                       48 read_nocancel + 158
                                                         48 write + 312
                                                           48 get_pathbuff + 3054
                                                             48 tsleep + 105
                                                               48 wakeup + 786
        48 thread_block + 33
        48 thread_block_reason + 331
        48 thread_dispatch + 1949
        48 machine_switch_context + 753
                                                 Thread 179993d4
                                                 User stack:
                                                       48 fmodWatchConsumer + 347 (in CarbonCore)
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x100000fff  coreservicesd ??? (???)
                                              <04B17F9C-7722-BE56-2850-868C11D34FF9> /System/Library/CoreServices/
                                              coreservicesd
                                                     0x7fff8338f000 -     0x7fff836c1fef
                                              com.apple.CoreServices.CarbonCore 859.1 (859.1) <5712C4C1-
                                              B18B-88EE-221F-DA04A8EDA029> /System/Library/Frameworks/
                                              CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/
                                              Versions/A/CarbonCore
                                              Process:         cvmsServ
                                              Path:            /System/Library/Frameworks/OpenGL.framework/Versions/
                                              A/Libraries/cvmsServ
                                              UID:             0
                                                 Thread 179ed3d4   DispatchQueue 1
                                                 User stack:
                                                   48 ??? (in cvmsServ + 4100)
                                                     48 ??? (in cvmsServ + 23081)
                                                       48 mach_msg_server + 597 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x100008fff  cvmsServ ??? (???)
                                              <8B29F0EA-273E-D990-D755-F64A6773BF83> /System/Library/Frameworks/
                                              OpenGL.framework/Versions/A/Libraries/cvmsServ
                                              Process:         DashboardClient
                                              Path:            /System/Library/CoreServices/Dock.app/Contents/
                                              Resources/DashboardClient.app/Contents/MacOS/DashboardClient
                                              UID:             501
                                                 Thread 208dcb7c
                                                 User stack:
                                                   48 ??? (in DashboardClient + 4992)
                                                     48 ??? (in DashboardClient + 20081)
                                                         48 -[NSApplication
                                              HIToolbox)
                                                 Kernel stack:
                                                 Thread 179f47a8
                                                 User stack:
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Thread 1e4bd7a8
                                                 User stack:
                                                       48 __NSThread__main__ + 1429 (in Foundation)
                                                         48 +[NSURLConnection(NSURLConnectionReallyInternal)
                                              _resourceLoadLoop:] + 297 (in Foundation)
                                                 Kernel stack:
                                                 Thread 20780b7c
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 29fb87a8
                                                 User stack:
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x100006fff  com.apple.dashboard.client
                                              1.7 (1.7) <C030A9A7-3A76-8829-7062-F9ACAC8B361A> /System/Library/
                                              CoreServices/Dock.app/Contents/Resources/DashboardClient.app/Contents/
                                              Process:         Dictionary
                                              Path:            /Applications/Dictionary.app/Contents/MacOS/Dictionary
                                              UID:             501
                                                 Thread 1ce307a8
                                                 User stack:
                                                   48 ??? (in Dictionary + 4916)
                                                         48 -[NSApplication
                                              HIToolbox)
                                                 Kernel stack:
                                                 Thread 1e4bdb7c
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 204263d4
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 285ddb7c
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 2a2b6b7c
                                                 User stack:
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Binary Images:
                                                        0x100000000 -        0x100034ff7  com.apple.Dictionary 2.1
                                              (80) <768C3606-D309-99B2-3B1D-EB01CB189683> /Applications/
                                              Process:         DirectoryService
                                              Path:            /usr/sbin/DirectoryService
                                              UID:             0
                                                 Thread 1733ab7c
                                                 User stack:
                                                   48 start + 52 (in DirectoryService)
                                                     48 main + 3086 (in DirectoryService)
                                                 Kernel stack:
                                                 Thread 173a57a8   DispatchQueue
                                                 User stack:
                                                       48 dispatchworker_thread2 + 231 (in libSystem.B.dylib)
                                                         48 dispatchcall_block_and_release + 15 (in
                                              libSystem.B.dylib)
                                                           48 syscall + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Thread 173b7b7c   DispatchQueue
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 173a53d4
                                                 User stack:
                                                       48 DSLThread::_RunWrapper(void*) + 67 (in
                                              DirectoryServiceCore)
                                                         48 DSCThread::Run() + 36 (in DirectoryServiceCore)
                                                           48 CPluginRunLoopThread::ThreadMain() + 150 (in
                                              DirectoryService)
                                                 Kernel stack:
                                                 Thread 1d09d3d4
                                                 User stack:
                                                 Kernel stack:
                                                   48 thread_bootstrap_return + 0
                                                 Thread 1f3e8000
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 2a2aab7c
                                                 User stack:
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x100120fff  DirectoryService ??? (???)
                                              <F6A2E16D-2B8F-DE6D-FA55-B2B21EB38B9B> /usr/sbin/DirectoryService
                                                        0x100170000 -        0x100181fff
                                              com.apple.DirectoryServiceCore.Framework 3.6 (621)
                                              <ECBA2170-0C45-2E48-64CE-22EEBA4FF07C> /System/Library/
                                              PrivateFrameworks/DirectoryServiceCore.framework/Versions/A/
                                              Process:         diskarbitrationd
                                              Path:            /usr/sbin/diskarbitrationd
                                              UID:             0
                                                 Thread 16c65b7c
                                                 User stack:
                                                   48 ??? (in diskarbitrationd + 4064)
                                                     48 ??? (in diskarbitrationd + 32876)
                                                 Kernel stack:
                                                 Thread 16cdcb7c
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Binary Images:
                                                        0x100000000 -        0x10001bfef  diskarbitrationd ??? (???)
                                              <E59D4CB3-3CC5-03AD-DE45-91F98CC6B2F2> /usr/sbin/diskarbitrationd
                                              Process:         distnoted
                                              Path:            /usr/sbin/distnoted
                                              UID:             1
                                                 Thread 1739e3d4
                                                 User stack:
                                                   48 ??? (in distnoted + 3620)
                                                     48 ??? (in distnoted + 3717)
                                                 Kernel stack:
                                                 Thread 1739e000   DispatchQueue 2
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 29fb8b7c
                                                 User stack:
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x100000fff  distnoted ??? (???)
                                              <C77F3FC4-BC9F-E5C5-D8DE-AEB00B26599A> /usr/sbin/distnoted
                                              Process:         Dock
                                              Path:            /System/Library/CoreServices/Dock.app/Contents/MacOS/
                                              Dock
                                              UID:             501
                                                 Thread 1cec87a8   DispatchQueue
                                                 User stack:
                                                   48 ??? (in Dock + 225848)
                                                     48 ??? (in Dock + 525059)
                                                 Kernel stack:
                                                 Thread 175717a8
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 204963d4
                                                 User stack:
                                                       48 ??? (in Dock + 273834)
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x10016ffe7  com.apple.dock 1.7 (751)
                                              <A16E52F6-4624-1D1A-489C-D6E7AC124239> /System/Library/CoreServices/
                                              Dock.app/Contents/MacOS/Dock
                                              Process:         Dreamweaver
                                              CS4.app/Contents/MacOS/Dreamweaver
                                              UID:             501
                                              Process:         dynamic_pager
                                              Path:            /sbin/dynamic_pager
                                              UID:             0
                                                 Thread 1746f000   DispatchQueue 1
                                                 User stack:
                                                   48 ???
                                                     48 ???
                                                       48 ???
                                                         48 ???
                                                           48 ???
                                                             48 ???
                                                 Kernel stack:
                                              Process:         Finder
                                              Path:            /System/Library/CoreServices/Finder.app/Contents/
                                              MacOS/Finder
                                              UID:             501
                                                 Thread 179e3b7c   DispatchQueue
                                                 User stack:
                                                   48 ??? (in Finder + 22172)
                                                     48 ??? (in Finder + 22233)
                                                           48 -[NSApplication
                                              HIToolbox)
                                              CoreFoundation)
                                              libSystem.B.dylib)
                                                 Kernel stack:
                                                 Thread 179aa000
                                                 User stack:
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Thread 179aab7c
                                                 User stack:
                                                       48 PrivateMPEntryPoint + 63 (in CarbonCore)
                                                         48 TSystemNotificationTask::SystemNotificationTaskProc
                                              (void*) + 514 (in DesktopServicesPriv)
                                                 Kernel stack:
                                                 Thread 17a14b7c
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 1e4d17a8
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 1f3dc7a8
                                                 User stack:
                                                       48 DRThreadObject::StartRoutine(DRThreadObject*) + 131 (in
                                              DiscRecording)
                                                         48 DRWorkLoop::WorkLoopEntry(DRWorkLoop*) + 9 (in
                                              DiscRecording)
                                                           48 DRWorkLoop::WorkLoop() + 234 (in DiscRecording)
                                                 Kernel stack:
                                                 Thread 281393d4
                                                 User stack:
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x1003a9fff  com.apple.finder 10.6
                                              (10.6) <42AD4F20-EE5F-148A-7AD9-608E11F8A8A4> /System/Library/
                                              CoreServices/Finder.app/Contents/MacOS/Finder
                                                     0x7fff807d0000 -     0x7fff808a7fef  com.apple.DiscRecording
                                              5.0 (5000.4.6) <34DF0AA3-916C-811D-A32E-0CD8D0C51FFC> /System/Library/
                                              Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                                                     0x7fff83266000 -     0x7fff8334aff7  com.apple.DesktopServices
                                              1.5.1 (1.5.1) <65D7E707-DBCA-5752-78EC-351DC88F3AE8> /System/Library/
                                              PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/
                                              DesktopServicesPriv
                                              Process:         firefox-bin
                                              Path:            /Applications/Firefox.app/Contents/MacOS/firefox-bin
                                              UID:             501
                                              Process:         Firewall
                                              Path:            /usr/libexec/ApplicationFirewall/Firewall
                                              UID:             501
                                                 Thread 179b1000
                                                 User stack:
                                                   48 ??? (in Firewall + 2296)
                                                     48 ??? (in Firewall + 2844)
                                                       48 ??? (in Firewall + 2812)
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x100000ff7  Firewall ??? (???)
                                              <CDEA4141-5D0F-A363-52FD-580FF056D82D> /usr/libexec/
                                              Process:         FNPLicensingService
                                              Path:            /Library/Application Support/FLEXnet Publisher/
                                              Service/11.5.0/FNPLicensingService
                                              UID:             0
                                              Process:         fontd
                                              ApplicationServices.framework/Frameworks/ATS.framework/Support/fontd
                                              UID:             501
                                                 Thread 17500b7c   DispatchQueue
                                                 User stack:
                                                   48 ??? (in fontd + 16156)
                                                     48 main_handler + 3893 (in libATSServer.dylib)
                                                 Kernel stack:
                                                 Thread 16d47b7c
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Binary Images:
                                                        0x100000000 -        0x100003fff  fontd ??? (???)
                                              <BF749549-5B12-6F9A-2778-3997AECC05E2> /System/Library/Frameworks/
                                                     0x7fff84ac1000 -     0x7fff84b75fff  libATSServer.dylib ???
                                              (???) <0D056144-BCD2-6806-E69E-B94A99054783> /System/Library/
                                              Frameworks/ApplicationServices.framework/Versions/A/Frameworks/
                                              ATS.framework/Versions/A/Resources/libATSServer.dylib
                                              Process:         fseventsd
                                              Path:            /System/Library/Frameworks/CoreServices.framework/
                                              Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/fseventsd
                                              UID:             0
                                                 Thread 1746f7a8
                                                 User stack:
                                                   48 ??? (in fseventsd + 5580)
                                                     48 ??? (in fseventsd + 8784)
                                                 Kernel stack:
                                                 Thread 179e3000   DispatchQueue
                                                 User stack:
                                                       48 ??? (in fseventsd + 28956)
                                                 Kernel stack:
                                                 Thread 175677a8   DispatchQueue 2
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 1745a3d4
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 17557000
                                                 User stack:
                                                 Kernel stack:
                                                         48 write + 312
                                                             48 tsleep + 105
                                                               48 wakeup + 786
                                                 Thread 175573d4
                                                 User stack:
                                                       48 ??? (in fseventsd + 26019)
                                                 Kernel stack:
                                                 Thread 175577a8
                                                 User stack:
                                                       48 ??? (in fseventsd + 39181)
                                                         48 ??? (in fseventsd + 38436)
                                                 Kernel stack:
                                                 Thread 17567b7c
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 17a2fb7c
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 1cf0f000
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 1d01f3d4
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 1dab0b7c
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 1e4d13d4
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 1e513000
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 207803d4
                                                 User stack:
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x10000ffff  fseventsd ??? (???)
                                              <4C5AA39F-F2D2-F6EB-5A3B-AF38B8000DE9> /System/Library/Frameworks/
                                              Process:         hidd
                                              Path:            /usr/libexec/hidd
                                              UID:             0
                                                 Thread 1746fb7c   DispatchQueue 1
                                                 User stack:
                                                   48 ??? (in hidd + 3756)
                                                     48 ??? (in hidd + 3822)
                                                 Kernel stack:
                                                 Thread 17552000   DispatchQueue 2
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Binary Images:
                                                        0x100000000 -        0x100000fff  hidd ??? (???)
                                              <E7A5611C-525B-8D58-3A12-C059A13F914A> /usr/libexec/hidd
                                              Process:         iCal
                                              Path:            /Applications/iCal.app/Contents/MacOS/iCal
                                              UID:             501
                                                 Thread 29fc07a8
                                                 User stack:
                                                   48 ??? (in iCal + 665592)
                                                     48 ??? (in iCal + 9648)
                                                           48 -[NSApplication
                                              HIToolbox)
                                              CoreFoundation)
                                              libSystem.B.dylib)
                                                 Kernel stack:
                                                 Thread 208dc000
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Binary Images:
                                                        0x100000000 -        0x1002c5fef  com.apple.iCal 4.0 (1362)
                                              <BCA7EBEA-D524-C83D-4A88-B16C15B091C2> /Applications/iCal.app/Contents/
                                              MacOS/iCal
                                              Process:         iChat
                                              Path:            /Applications/iChat.app/Contents/MacOS/iChat
                                              UID:             501
                                                 Thread 28427000
                                                 User stack:
                                                   48 ??? (in iChat + 11548)
                                                         48 -[NSApplication
                                              HIToolbox)
        47 __CFRunLoopRun + 2002 (in CoreFoundation)
        47 mach_msg_trap + 10 (in libSystem.B.dylib)
        1 __CFRunLoopRun + 468 (in CoreFoundation)
        1 __CFRunLoopDoObservers + 519 (in
                                              CoreFoundation)
        1 _handleWindowNeedsDisplay + 678 (in
                                              AppKit)
        1 -[NSView displayIfNeeded] + 969 (in
                                              AppKit)
        1 -[NSView
                                              _displayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] +
                                              2683 (in AppKit)
        1 -[NSThemeFrame
                                              _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVie w
                                              :] + 254 (in AppKit)
        1 -[NSView
                                              :] + 4555 (in AppKit)
        1 -[NSView
        1 -[NSView
        1 -[NSView
        1 -[NSView
        1 -[NSView
                                              :] + 2112 (in AppKit)
        1 -[NSView
                                              _drawRect:clip:] + 3566 (in AppKit)
        1 ??? (in iChat +
                                              123341)
        1 -[NSTableView
                                              drawRect:] + 1302 (in AppKit)
        1 -[NSTableView
                                              drawRowIndexes:clipRect:] + 369 (in AppKit)
        1 ??? (in iChat
                                              + 133407)
        1 ??? (in
                                              iChat + 134584)
        1 -
                                              NSTableView drawRow:clipRect: + 1311 (in AppKit)
        1 ??? (in
                                              iChat + 100818)
        1 ???
                                              (in iChat + 101137)
        1 ???
                                              (in iChat + 102540)
        1 +
                                              NSString stringWithFormat: + 187 (in Foundation)
        1
                                              -[NSPlaceholderString initWithFormat:locale:arguments:] + 140 (in
                                              Foundation)
                                              1 _CFStringCreateWithFormatAndArgumentsAux + 109 (in CoreFoundation)
        1
                                                _CFStringAppendFormatAndArgumentsAux + 6431 (in CoreFoundation)
        1
                                                snprintf_l + 507 (in libSystem.B.dylib)
        1
                                                __sfvwrite + 0 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   40 ipc_mqueue_receive_continue + 0
                                                   7 lo64_mach_scall + 77
                                                     7 thread_setuserstack + 405
                                                       7 mach_msg_overwrite_trap + 586
                                                         7 ipc_mqueue_receive + 89
                                                           7 thread_block + 33
                                                             7 thread_block_reason + 309
                                                               7 thread_go + 1985
        7 thread_setrun + 1340
        7 machine_idle + 254
                                                   1 lo_allintrs + 302
                                                     1 interrupt + 171
                                                       1 lapic_interrupt + 126
                                                         1 intel_startCPU + 375
                                                           1 sync_iss_to_iks + 124
                                                 Thread 2a2b63d4   DispatchQueue
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 1e4d1b7c
                                                 User stack:
                                                       48 CAPThread::Entry(CAPThread*) + 140 (in
                                              CoreMediaIOServices)
                                                         48 MIO::DAL::RunLoop::OwnThread(void*) + 147 (in
                                                 Kernel stack:
                                                 Thread 1e61c000
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 29f9ab7c
                                                 User stack:
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x100280ff7  com.apple.iChat 5.0 (741)
                                              <19D03934-849B-3AED-23FB-8B797335892E> /Applications/iChat.app/
                                                     0x7fff8561f000 -     0x7fff8565aff7
                                              com.apple.CoreMediaIOServices 101.0 (715) <7B93206A-FEC5-
                                              FCC3-3587-91E3CEC61797> /System/Library/PrivateFrameworks/
                                              CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
                                              Process:         iChatAgent
                                              Path:            /System/Library/Frameworks/IMCore.framework/
                                              iChatAgent.app/Contents/MacOS/iChatAgent
                                              UID:             501
                                                 Thread 1ce67000
                                                 User stack:
                                                   48 start + 52 (in iChatAgent)
                                                     48 main + 286 (in iChatAgent)
                                              Foundation)
                                                 Kernel stack:
                                                 Thread 1e516b7c
                                                 User stack:
                                                       48 XPRT::_ThreadProc(void*) + 31 (in AIM)
                                                         48 XPRT::TTimer::ThreadProc(void*) + 357 (in AIM)
                                                           48 XPRT::TCondVar::Wait(int) + 150 (in AIM)
                                                 Kernel stack:
                                                 Thread 1e6313d4
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 1f3d6b7c
                                                 User stack:
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Binary Images:
                                                        0x100000000 -        0x10000ffff  com.apple.iChatAgent 5.0
                                              (741) <121018FA-D3CA-0415-636D-F978AC8C7524> /System/Library/
                                              Frameworks/IMCore.framework/iChatAgent.app/Contents/MacOS/iChatAgent
                                                        0x104200000 -        0x104384fff  com.apple.iChat.AIM 5.0
                                              (710) <7DF58FA0-86FC-EF59-44C5-F0F21CEB4141> /System/Library/
                                              Frameworks/IMCore.framework/iChatAgent.app/Contents/PlugIns/
                                              AIM.imservice/Contents/MacOS/AIM
                                              Process:         Image Capture Extension
                                              Path:            /System/Library/Image Capture/Support/Image Capture
                                              Extension.app/Contents/MacOS/Image Capture Extension
                                              UID:             501
                                                 Thread 2814db7c
                                                 User stack:
                                                   48 start + 52 (in Image Capture Extension)
                                                         48 -[NSApplication
                                              HIToolbox)
                                                 Kernel stack:
                                                 Thread 29fcab7c
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Binary Images:
                                                        0x100000000 -        0x100054fff
                                              com.apple.ImageCaptureExtension2 6.0 (6.0) <A0942B75-1616-3296-0D34-
                                              C666028E2400> /System/Library/Image Capture/Support/Image Capture
                                              Process:         iPhoto
                                              Path:            /Volumes/Big Daddy/Applications/iPhoto.app/Contents/
                                              MacOS/iPhoto
                                              UID:             501
                                                 Thread 29c62000
                                                 User stack:
                                                   48 ??? (in iPhoto + 40225)
                                                     48 ??? (in iPhoto + 40454)
                                                       48 NSApplicationMain + 574 (in AppKit)
                                                         48 -[NSApplication run] + 821 (in AppKit)
                                                           48 -[NSApplication
                                              nextEventMatchingMask:untilDate:inMode:dequeue:] + 156 (in AppKit)
                                                             48 _DPSNextEvent + 847 (in AppKit)
                                                               48 BlockUntilNextEventMatchingListInMode + 81 (in
                                              HIToolbox)
        48 ReceiveNextEventCommon + 354 (in HIToolbox)
        48 RunCurrentEventLoopInMode + 392 (in HIToolbox)
        48 CFRunLoopRunInMode + 97 (in CoreFoundation)
        48 CFRunLoopRunSpecific + 452 (in
                                              CoreFoundation)
        48 __CFRunLoopRun + 2447 (in
                                              CoreFoundation)
                                              libSystem.B.dylib)
                                                 Kernel stack:
                                                 Thread 1746f3d4
                                                 User stack:
                                                   48 start_wqthread + 30 (in libSystem.B.dylib)
                                                     48 pthreadwqthread + 390 (in libSystem.B.dylib)
                                                       48 dispatchworker_thread2 + 234 (in libSystem.B.dylib)
                                                         48 dispatchqueue_invoke + 183 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 179b1b7c
                                                 User stack:
                                                   48 thread_start + 34 (in libSystem.B.dylib)
                                                     48 pthreadstart + 345 (in libSystem.B.dylib)
                                                       48 jpegdecompress_MPLoop + 79 (in QuickTimeComponents)
                                                         48 pthread_cond_wait + 48 (in libSystem.B.dylib)
                                                           48 semaphore_wait_signal_trap + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                 Thread 179ecb7c
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 179ef7a8
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 1cec8000
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 1d01f000
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 208d9b7c
                                                 User stack:
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Thread 284297a8
                                                 User stack:
                                                       48 ReadSchedulerThreadEntryPoint + 4698 (in
                                                         48 TSWaitOnSemaphoreCommon + 511 (in CarbonCore)
                                                           48 TSWaitOnConditionTimedRelative + 242 (in CarbonCore)
                                                             48 pthread_cond_timedwait_relative_np + 47 (in
                                              libSystem.B.dylib)
                                                               48 semaphore_timedwait_signal_trap + 10 (in
                                              libSystem.B.dylib)
                                                 Kernel stack:
                                                 Thread 29f88000
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 2a2c3b7c
                                                 User stack:
                                                 Kernel stack:
                                                 Binary Images:
                                                     0x1000 -   0x4791c7  com.apple.iPhoto 6.0.6 (6.0.6)
                                              <00010203-0405-0607-0809-0A0B0C0D0E0F> /Volumes/Big Daddy/Applications/
                                              iPhoto.app/Contents/MacOS/iPhoto
                                                 0x93bfe000 - 0x93f1dfe7  com.apple.CoreServices.CarbonCore 859.1
                                              (859.1) <2E72AF56-4BE6-294A-7372-19C360688B8B> /System/Library/
                                              Frameworks/CoreServices.framework/Versions/A/Frameworks/
                                              CarbonCore.framework/Versions/A/CarbonCore
                                                 0x93f87000 - 0x940fefef  com.apple.CoreFoundation 6.6 (550)
                                              <193E33D6-2E92-3452-773B-60A1A9CCC573> /System/Library/Frameworks/
                                                 0x94e78000 - 0x9519bfef  com.apple.HIToolbox 1.6.0 (???)
                                              <6F95AF67-678A-D8BC-FFC2-029C9AA2F44A> /System/Library/Frameworks/
                                              Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/
                                              HIToolbox
                                                 0x95320000 - 0x95bfdff7  com.apple.AppKit 6.6.1 (1038.2)
                                              <27C304F6-0045-160B-7591-E57ECF19BDDB> /System/Library/Frameworks/
                                                 0x96020000 - 0x961c4feb  libSystem.B.dylib ??? (???) <E58B649F-FFDC-
                                              AB09-2028-8B706BEF7C0F> /usr/lib/libSystem.B.dylib
                                                 0x96cb0000 - 0x97c3eff7  com.apple.QuickTimeComponents.component
                                              7.6.3 (1584) <00010203-0405-0607-0809-0A0B0C0D0E0F> /System/Library/
                                              QuickTime/QuickTimeComponents.component/Contents/MacOS/
                                              QuickTimeComponents
                                              Process:         iTunesHelper
                                              Path:            /Applications/iTunes.app/Contents/Resources/
                                              iTunesHelper.app/Contents/MacOS/iTunesHelper
                                              UID:             501
                                                 Thread 179b0b7c   DispatchQueue 1
                                                 User stack:
                                                   48 ??? (in iTunesHelper + 3816)
                                                     48 ??? (in iTunesHelper + 5234)
                                                 Kernel stack:
                                                 Thread 17571b7c   DispatchQueue 2
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 173beb7c
                                                 User stack:
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Binary Images:
                                                        0x100000000 -        0x10001cffb  com.apple.iTunesHelper
                                              9.0.1 (9.0.1) <3FA311F1-6380-6FB0-B6D6-CF9F3A9C4847> /Applications/
                                              iTunes.app/Contents/Resources/iTunesHelper.app/Contents/MacOS/
                                              iTunesHelper
                                              Process:         KernelEventAgent
                                              Path:            /usr/sbin/KernelEventAgent
                                              UID:             0
                                                 Thread 174673d4   DispatchQueue 1
                                                 User stack:
                                                   48 start + 52 (in KernelEventAgent)
                                                     48 main + 1130 (in KernelEventAgent)
                                                 Kernel stack:
                                                 Thread 175527a8   DispatchQueue 2
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 17552b7c
                                                 User stack:
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Binary Images:
                                                        0x100000000 -        0x100006ff7  KernelEventAgent ??? (???)
                                              <20952F40-244C-DE8B-B7BA-05B8118647CF> /usr/sbin/KernelEventAgent
                                              Process:         kextd
                                              Path:            /usr/libexec/kextd
                                              UID:             0
                                                 Thread 16cb83d4   DispatchQueue 1
                                                 User stack:
                                                   48 ??? (in kextd + 5608)
                                                     48 ??? (in kextd + 9541)
                                                 Kernel stack:
                                                 Thread 16cd2b7c   DispatchQueue 2
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Binary Images:
                                                        0x100000000 -        0x10001afff  kextd ??? (???)
                                              <F96F048C-5025-0EC0-A921-96218BCD0124> /usr/libexec/kextd
                                              Process:         launchd
                                              Path:            /sbin/launchd
                                              UID:             501
                                                 Thread 175b27a8
                                                 User stack:
                                                   48 start + 52 (in launchd)
                                                     48 main + 1841 (in launchd)
                                                       48 launchd_runtime + 450 (in launchd)
                                                 Kernel stack:
                                                 Thread 179ee000
                                                 User stack:
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Binary Images:
                                                        0x100000000 -        0x100029fe7  launchd ??? (???)
                                              <AED4A707-E3DE-4836-9343-90D184AF0438> /sbin/launchd
                                              Process:         launchd
                                              Path:            /sbin/launchd
                                              UID:             0
                                                 Thread 16cb8b7c
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 16c13000
                                                 User stack:
                                                       48 update_thread + 22 (in launchd)
                                                         48 sleep + 61 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                 Thread 16cd8b7c
                                                 User stack:
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Binary Images:
                                              Process:         loginwindow
                                              Path:            /System/Library/CoreServices/loginwindow.app/Contents/
                                              MacOS/loginwindow
                                              UID:             501
                                                 Thread 174677a8
                                                 User stack:
                                                   48 ??? (in loginwindow + 18412)
                                                     48 ??? (in loginwindow + 19842)
                                                       43 -[NSApplication run] + 395 (in AppKit)
                                                         43 -[NSApplication
                                                           43 _DPSNextEvent + 718 (in AppKit)
                                                             43 BlockUntilNextEventMatchingListInMode + 59 (in
                                              HIToolbox)
                                                               43 ReceiveNextEventCommon + 310 (in HIToolbox)
        43 RunCurrentEventLoopInMode + 333 (in HIToolbox)
        43 CFRunLoopRunSpecific + 575 (in CoreFoundation)
        43 __CFRunLoopRun + 2002 (in CoreFoundation)
        43 mach_msg_trap + 10 (in libSystem.B.dylib)
                                                       5 -[NSApplication run] + 474 (in AppKit)
                                                         5 ??? (in loginwindow + 43663)
                                                           5 -[NSApplication sendEvent:] + 4717 (in AppKit)
                                                             5 -[NSWindow sendEvent:] + 5409 (in AppKit)
                                                               5 -[NSControl mouseDown:] + 624 (in AppKit)
        5 -[NSButtonCell
                                              trackMouse:inRect:ofView:untilMouseUp:] + 555 (in AppKit)
        4 -[NSCell
                                              trackMouse:inRect:ofView:untilMouseUp:] + 1715 (in AppKit)
        4 -[NSControl sendAction:to:] + 94 (in AppKit)
        4 -[NSApplication sendAction:to:from:] + 95
                                              (in AppKit)
        2 ??? (in loginwindow + 202666)
        1 -[NSApplication
                                              _commonBeginModalSessionForWindow:relativeToWindow:modalDelegate:didEndSelector:contextInf o
                                              :] + 714 (in AppKit)
        1 -[NSApplication
                                              _orderFrontModalWindow:relativeToWindow:] + 734 (in AppKit)
        1 -[NSWindow
                                              _reallyDoOrderWindow:relativeTo:findKey:forCounter:force:isModal:] +
                                              1291 (in AppKit)
        1 -[NSWindow(NSSheets)
                                              _orderFrontRelativeToWindow:] + 200 (in AppKit)
        1 -[NSMoveHelper(NSSheets)
                                              _moveParent:andOpenSheet:] + 1753 (in AppKit)
        1 -[NSMoveHelper _doAnimation]
                                              + 1117 (in AppKit)
        1 CFRunLoopRunSpecific + 575
                                              (in CoreFoundation)
        1 __CFRunLoopRun + 2002 (in
                                              CoreFoundation)
        1 mach_msg_trap + 10 (in
                                              libSystem.B.dylib)
        1 -[NSApplication
                                              :] + 983 (in AppKit)
        1 -[NSWindow
                                              _changeKeyAndMainLimitedOK:] + 892 (in AppKit)
        1 -[NSWindow _setFrameNeedsDisplay:]
                                              + 67 (in AppKit)
        1 objc_msgSend + 62 (in
                                              libobjc.A.dylib)
        2 -[NSApplication endSheet:returnCode:] +
                                              321 (in AppKit)
        2 ??? (in loginwindow + 202732)
        2 -[NSWindow orderWindow:relativeTo:] +
                                              94 (in AppKit)
        2 -[NSWindow
                                              1581 (in AppKit)
        2 -[NSWindow(NSSheets)
                                              _orderOutRelativeToWindow:] + 115 (in AppKit)
        2 -[NSMoveHelper(NSSheets)
                                              _closeSheet:andMoveParent:] + 532 (in AppKit)
        2 -[NSMoveHelper _doAnimation]
                                              + 1117 (in AppKit)
        2 CFRunLoopRunSpecific + 575
                                              (in CoreFoundation)
        1 __CFRunLoopRun + 5480 (in
                                              CoreFoundation)
        1
                                              _NSMoveHelperTimerCallBack + 631 (in AppKit)
        1 CGSReenableUpdate +
                                              25 (in CoreGraphics)
        1
                                              CGSReenableUpdateForConnections + 359 (in CoreGraphics)
        1
                                              _CGSReenableUpdateForConnections + 186 (in CoreGraphics)
        1 mach_msg_trap +
                                              CoreFoundation)
                                              libSystem.B.dylib)
        1 -[NSCell
                                              trackMouse:inRect:ofView:untilMouseUp:] + 1129 (in AppKit)
        1 -[NSApplication
        1 _DPSNextEvent + 718 (in AppKit)
        1 BlockUntilNextEventMatchingListInMode +
                                              59 (in HIToolbox)
        1 ReceiveNextEventCommon + 310 (in
                                              HIToolbox)
        1 RunCurrentEventLoopInMode + 333 (in
                                              HIToolbox)
        1 CFRunLoopRunSpecific + 575 (in
                                              CoreFoundation)
                                              CoreFoundation)
                                              libSystem.B.dylib)
                                                 Kernel stack:
                                                   46 ipc_mqueue_receive_continue + 0
                                                   1 lo_allintrs + 302
                                                     1 interrupt + 171
                                                   1 lo64_mach_scall + 77
                                                     1 thread_setuserstack + 405
                                                       1 mach_msg_overwrite_trap + 586
                                                         1 ipc_mqueue_receive + 89
                                                           1 thread_block + 33
                                                             1 thread_block_reason + 309
                                                               1 thread_go + 1985
        1 thread_setrun + 1340
        1 machine_idle + 254
                                                 Thread 17999b7c
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 29fc2b7c
                                                 User stack:
                                                         43 -[NSUIHeartBeat _heartBeatThread:] + 1540 (in AppKit)
                                                           43 usleep + 57 (in libSystem.B.dylib)
                                                             43 __semwait_signal + 10 (in libSystem.B.dylib)
                                                         3 -[NSUIHeartBeat _heartBeatThread:] + 455 (in AppKit)
                                                           3 -[NSLock lock] + 175 (in Foundation)
                                                             3 semaphore_wait_signal_trap + 10 (in
                                              libSystem.B.dylib)
                                                         2 -[NSUIHeartBeat _heartBeatThread:] + 698 (in AppKit)
                                                           2 -[NSWindow(NSWindow_Theme) heartBeat:] + 282 (in
                                              AppKit)
                                                             2 -[NSButtonCell(NSDefaultButtonIndicatorPrivate)
                                              heartBeat:] + 1476 (in AppKit)
                                                               1 -[NSView _lightWeightRecursiveDisplayInRect:] + 688
                                              (in AppKit)
        1 CFArrayApplyFunction + 222 (in CoreFoundation)
        1 _lightWeightRecursiveDisplayInRect2 + 312 (in
                                              AppKit)
                                              + 688 (in AppKit)
                                              CoreFoundation)
                                              (in AppKit)
        1 -[NSView
                                              _lightWeightRecursiveDisplayInRect:] + 624 (in AppKit)
        1 -[NSView _drawRect:clip:] + 3390 (in
                                              AppKit)
        1 -[NSControl drawRect:] + 405 (in
                                              AppKit)
        1 -[NSButtonCell
                                              drawWithFrame:inView:] + 497 (in AppKit)
        1 CUIRenderer::Draw(CGRect,
                                              CGContext, __CFDictionary const, __CFDictionary const**) + 3287 (in
                                              CoreUI)
        1 CUIRenderer::DrawPushButton
                                              (CUIDescriptor const*) + 757 (in CoreUI)
        1 CGContextDrawImages + 228
                                              (in CoreGraphics)
        1 ripc_DrawImages + 7964
                                              (in libRIP.A.dylib)
        1 ripc_RenderImage + 323
                                              (in libRIP.A.dylib)
        1 ripl_BltImage + 1389
                                              (in libRIP.A.dylib)
        1 ripl_Mark + 23 (in
                                              libRIP.A.dylib)
        1 argb32_image +
                                              421 (in CoreGraphics)
        1
                                              argb32_image_mark + 1239 (in CoreGraphics)
        1
                                              argb32_sample_argb32 + 1072 (in CoreGraphics)
                                                               1 -[NSView _lightWeightRecursiveDisplayInRect:] + 624
                                              (in AppKit)
        1 -[NSView _drawRect:clip:] + 3390 (in AppKit)
        1 -[NSThemeFrame drawRect:] + 109 (in AppKit)
        1 -[NSFrameView drawThemeContentFill:inView:] +
                                              2135 (in AppKit)
        1 -[NSThemeFrame drawWindowBackgroundRect:] +
                                              179 (in AppKit)
        1 NSDrawWindowBackground + 252 (in AppKit)
        1 NSRectFillUsingOperation + 241 (in
                                              AppKit)
        1 CGContextFillRect + 18 (in
                                              CoreGraphics)
        1 CGContextFillRects + 143 (in
                                              CoreGraphics)
        1 ripc_DrawRects + 732 (in
                                              libRIP.A.dylib)
        1 ripc_Render + 375 (in
                                              libRIP.A.dylib)
        1 ripl_BltShape + 1980 (in
                                              libRIP.A.dylib)
        1 argb32_mark + 563 (in
                                              CoreGraphics)
        1 argb32_mark_constshape +
                                              680 (in CoreGraphics)
        1 sseCGSFill8by1 + 229
                                              (in CoreGraphics)
                                                 Kernel stack:
                                                   43 semaphore_wait_continue + 0
                                                   3 lo64_unix_scall + 77
                                                     3 unix_syscall64 + 617
                                                       3 __semwait_signal_nocancel + 241
                                                         3 semaphore_timedwait_trap_internal + 190
                                                           3 semaphore_destroy + 703
                                                             3 thread_block + 33
                                                               3 thread_block_reason + 309
        3 thread_go + 1985
        3 thread_setrun + 1340
        3 machine_idle + 254
                                                   2 lo_allintrs + 302
                                                     2 interrupt + 171
                                                       2 lapic_interrupt + 126
                                                         2 intel_startCPU + 375
                                                           2 sync_iss_to_iks + 124
                                                 Thread 208de3d4
                                                 User stack:
                                                   24 start_wqthread + 13 (in libSystem.B.dylib)
                                                     24 __workq_kernreturn + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   24 workqueue_thread_yielded + 562
                                                 Thread 175b2b7c
                                                 User stack:
                                                   23 start_wqthread + 13 (in libSystem.B.dylib)
                                                     23 __workq_kernreturn + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   23 workqueue_thread_yielded + 562
                                                 Thread 29fb97a8
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 1ce3b000
                                                 User stack:
                                                   22 start_wqthread + 13 (in libSystem.B.dylib)
                                                     22 __workq_kernreturn + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   22 workqueue_thread_yielded + 562
                                                 Binary Images:
                                                        0x100000000 -        0x100077fef  com.apple.loginwindow 6.0
                                              (6.0) <14922E77-F6C2-5EE0-9BE0-94C3016CC5B9> /System/Library/
                                              CoreServices/loginwindow.app/Contents/MacOS/loginwindow
                                                     0x7fff82f86000 -     0x7fff82fc9ff7  libRIP.A.dylib ??? (???)
                                              <8D7113D2-71A7-A205-D2D0-2DB0F37FFBB3> /System/Library/Frameworks/
                                              CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
                                                     0x7fff8744d000 -     0x7fff87494ff7  com.apple.coreui 0.2 (112)
                                              <E64F7594-7829-575F-666A-0B16875FC644> /System/Library/
                                              PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                                                     0x7fff874ca000 -     0x7fff87bbc5d7  com.apple.CoreGraphics
                                              1.535.5 (???) <6599C41F-2D50-5E04-44E4-44FA90E022B5> /System/Library/
                                              CoreGraphics.framework/Versions/A/CoreGraphics
                                                     0x7fff889a4000 -     0x7fff88a5afe7  libobjc.A.dylib ??? (???)
                                              <261D97A3-225B-8A00-56AA-F9F27973063F> /usr/lib/libobjc.A.dylib
                                              Process:         Mail
                                              Path:            /Applications/Mail.app/Contents/MacOS/Mail
                                              UID:             501
                                                 Thread 242e13d4
                                                 User stack:
                                                   48 ??? (in Mail + 5756)
                                                         48 -[NSApplication
                                              HIToolbox)
                                                 Kernel stack:
                                                 Thread 179b07a8
                                                 User stack:
                                                         48 + + 78 (in Message)
                                              (in Foundation)
                                                 Kernel stack:
                                                 Thread 1e61c3d4
                                                 User stack:
                                                         48 -[RSSInterchange _runManager] + 1445 (in Message)
                                              (in Foundation)
                                                 Kernel stack:
                                                 Thread 2041e3d4
                                                 User stack:
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Thread 204387a8
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 2814d000
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 2a32c000
                                                 User stack:
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x100336ff7  com.apple.mail 4.1 (1076)
                                              <C6C651FE-C706-1B61-3D43-116621DAB9C8> /Applications/Mail.app/Contents/
                                              MacOS/Mail
                                                     0x7fff84778000 -     0x7fff84ab5fe7  com.apple.MessageFramework
                                              4.1 (1076) <5F5E9539-3443-F692-47C1-1B0567F9ECEE> /System/Library/
                                              Frameworks/Message.framework/Versions/B/Message
                                              Process:         mDNSResponder
                                              Path:            /usr/sbin/mDNSResponder
                                              UID:             65
                                                 Thread 17467b7c   DispatchQueue 1
                                                 User stack:
                                                   48 start + 33 (in mDNSResponder)
                                                     48 _start + 224 (in mDNSResponder)
                                                       48 main + 2910 (in mDNSResponder)
                                                 Kernel stack:
                                                 Thread 179d9b7c   DispatchQueue 2
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 17440000
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Binary Images:
                                                        0x100000000 -        0x100062fff  mDNSResponder ??? (???)
                                              <19DA34FA-0F7B-4F4A-8443-83F8BD382450> /usr/sbin/mDNSResponder
                                              Process:         mds
                                              Frameworks/Metadata.framework/Support/mds
                                              UID:             0
                                                 Thread 1745a000
                                                 User stack:
                                                   48 ??? (in mds + 16676)
                                                     48 ??? (in mds + 48462)
                                                 Kernel stack:
                                                 Thread 179f43d4   DispatchQueue -1862270976
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 1d0b33d4
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 1d0a6000
                                                 User stack:
                                                   12 start_wqthread + 13 (in libSystem.B.dylib)
                                                     12 __workq_kernreturn + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   12 workqueue_thread_yielded + 562
                                                 Binary Images:
                                                        0x100000000 -        0x1000ccfef  mds ??? (???) <A39CF0D3-
                                              C64E-0660-5BDE-ADC62793EF8E> /System/Library/Frameworks/
                                              CoreServices.framework/Frameworks/Metadata.framework/Support/mds
                                              Process:         mdworker
                                              Frameworks/Metadata.framework/Versions/A/Support/mdworker
                                              UID:             501
                                                 Thread 2a2afb7c
                                                 User stack:
                                                   48 ??? (in mdworker + 4620)
                                                     48 ??? (in mdworker + 34192)
                                                 Kernel stack:
                                                 Thread 29f9d3d4
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 2a32cb7c
                                                 User stack:
                                                       48 ??? (in mdworker + 41872)
                                                         48 ??? (in mdworker + 42763)
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x10003bfef  mdworker ??? (???)
                                              <E59B2EC4-291E-8F1C-70FE-4C5D9152D8F1> /System/Library/Frameworks/
                                              CoreServices.framework/Frameworks/Metadata.framework/Versions/A/
                                              Support/mdworker
                                              Process:         Microsoft Database Daemon
                                              Path:            /Volumes/Big Daddy/Applications/Microsoft Office 2008/
                                              Office/Microsoft Database Daemon.app/Contents/MacOS/Microsoft Database
                                              Daemon
                                              UID:             501
                                              Process:         Microsoft Excel
                                              Microsoft Excel.app/Contents/MacOS/Microsoft Excel
                                              UID:             501
                                              Process:         Microsoft PowerPoint
                                              Microsoft PowerPoint.app/Contents/MacOS/Microsoft PowerPoint
                                              UID:             501
                                              Process:         Microsoft Word
                                              Microsoft Word.app/Contents/MacOS/Microsoft Word
                                              UID:             501
                                              Process:         notifyd
                                              Path:            /usr/sbin/notifyd
                                              UID:             0
                                                 Thread 16ad43d4   DispatchQueue 1
                                                 User stack:
                                                   48 ???
                                                     48 ???
                                                       48 ???
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 16c327a8
                                                 User stack:
                                                   48 ???
                                                     48 ???
                                                       48 ???
                                                         48 ???
                                                 Kernel stack:
                                              Process:         ntpd
                                              Path:            /usr/sbin/ntpd
                                              UID:             0
                                                 Thread 173b77a8   DispatchQueue 1
                                                 User stack:
                                                   48 ??? (in ntpd + 6356)
                                                     48 ??? (in ntpd + 36998)
                                                       48 __sigsuspend + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Binary Images:
                                                        0x100000000 -        0x100056fef  ntpd ??? (???) <3BCDB850-
                                              F8F7-CF24-9E18-61AAE7668E14> /usr/sbin/ntpd
                                              Process:         pboard
                                              Path:            /usr/sbin/pboard
                                              UID:             501
                                                 Thread 222793d4   DispatchQueue 1869771886
                                                 User stack:
                                                   48 ??? (in pboard + 5860)
                                                     48 ??? (in pboard + 6062)
                                                       48 mach_msg_server + 468 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x100001fff  pboard ??? (???)
                                              <712EA371-6B97-F49F-CB77-6544A11BB82A> /usr/sbin/pboard
                                              Process:         Preview
                                              Path:            /Applications/Preview.app/Contents/MacOS/Preview
                                              UID:             501
                                                 Thread 1e6167a8
                                                 User stack:
                                                   48 start + 52 (in Preview)
                                                         48 -[NSApplication
                                              HIToolbox)
                                                 Kernel stack:
                                                 Thread 29f9a3d4
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 175383d4
                                                 User stack:
                                                   33 start_wqthread + 13 (in libSystem.B.dylib)
                                                     33 __workq_kernreturn + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   33 workqueue_thread_yielded + 562
                                                 Binary Images:
                                                        0x100000000 -        0x100168ff7  com.apple.Preview 5.0
                                              (501) <5463A728-B439-FE70-BCBA-011B5C6B9A0F> /Applications/Preview.app/
                                              Process:         PTPCamera
                                              Path:            /System/Library/Image Capture/Devices/PTPCamera.app/
                                              Contents/MacOS/PTPCamera
                                              UID:             501
                                                 Thread 22107b7c
                                                 User stack:
                                                   48 start + 52 (in PTPCamera)
                                                     48 ICAApplicationMain + 366 (in ICADevices)
                                                         48 -[NSApplication
                                              HIToolbox)
                                                 Kernel stack:
                                                 Thread 1cee77a8
                                                 User stack:
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Thread 20914000
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Binary Images:
                                                        0x100000000 -        0x100025ff7  com.apple.PTPCamera 6.0
                                              (6.0) <FC16A59F-A546-7574-4367-1724C7F6113C> /System/Library/Image
                                              Capture/Devices/PTPCamera.app/Contents/MacOS/PTPCamera
                                                        0x100041000 -        0x10006dfe7  com.apple.ICADevices 6.0
                                              (6.0) <6BF87780-BE82-506D-C03C-8C82FAF2D62D> /System/Library/
                                              Frameworks/ICADevices.framework/Versions/A/ICADevices
                                              Process:         Safari
                                              Path:            /Applications/Safari.app/Contents/MacOS/Safari
                                              UID:             501
                                                 Thread 284277a8
                                                 User stack:
                                                   48 ??? (in Safari + 7436)
                                                         48 ??? (in Safari + 48368)
                                                           48 -[NSApplication
                                              HIToolbox)
        47 RunCurrentEventLoopInMode + 333 (in HIToolbox)
        47 CFRunLoopRunSpecific + 575 (in
                                              CoreFoundation)
                                              libSystem.B.dylib)
        1 RunCurrentEventLoopInMode + 179 (in HIToolbox)
        1 CFStringCompareWithOptionsAndLocale + 270 (in
                                              CoreFoundation)
        1 __CFStringFillCharacterSetInlineBuffer + 20
                                              (in CoreFoundation)
                                                 Kernel stack:
                                                   43 ipc_mqueue_receive_continue + 0
                                                   4 lo64_mach_scall + 77
                                                     4 thread_setuserstack + 405
                                                       4 mach_msg_overwrite_trap + 586
                                                         4 ipc_mqueue_receive + 89
                                                           4 thread_block + 33
                                                             4 thread_block_reason + 309
                                                               4 thread_go + 1985
        4 thread_setrun + 1340
        4 machine_idle + 254
                                                   1 lo_allintrs + 302
                                                     1 interrupt + 171
                                                 Thread 17437000
                                                 User stack:
                                                       48 WebCore::IconDatabase::iconDatabaseSyncThread() + 170 (in
                                              WebCore)
                                                         48 WebCore::IconDatabase::syncThreadMainLoop() + 249 (in
                                              WebCore)
                                                 Kernel stack:
                                                 Thread 1747f7a8
                                                 User stack:
                                                       48 thread_fun + 34 (in QuartzCore)
                                                         48 CA::Render::Server::server_thread(void*) + 177 (in
                                              QuartzCore)
                                                 Kernel stack:
                                                 Thread 1ce303d4
                                                 User stack:
                                                       48 ??? (in Safari + 153091)
                                                         48 ??? (in Safari + 153203)
                                                 Kernel stack:
                                                 Thread 20426b7c
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 20438000
                                                 User stack:
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Thread 2814d3d4
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 29fab000
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 2a2c37a8
                                                 User stack:
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x10024ffff  com.apple.Safari 4.0.3
                                              (6531.9) <85520F41-6D13-C548-9D3F-A3013EFB1D8D> /Applications/
                                                     0x7fff819db000 -     0x7fff81d6fff7  com.apple.QuartzCore 1.6.0
                                              (226.0) <66E14771-C5F0-1415-0B7B-C45EE00C51A1> /System/Library/
                                              Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                                                     0x7fff87c7a000 -     0x7fff8869dfe7  com.apple.WebCore 6531
                                              (6531.9) <6DEBA397-4369-A8B1-1757-40FD454F6B51> /System/Library/
                                              Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/
                                              Versions/A/WebCore
                                              Process:         securityd
                                              Path:            /usr/sbin/securityd
                                              UID:             0
                                                 Thread 1745a7a8
                                                 User stack:
                                                   48 ??? (in securityd + 5608)
                                                     48 ??? (in securityd + 7953)
                                                       48 ??? (in securityd + 27083)
                                                         48 ??? (in securityd + 28091)
                                                           48 mach_msg_overwrite_trap + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                 Thread 1d0227a8
                                                 User stack:
                                                       48 ??? (in securityd + 33454)
                                                         48 ??? (in securityd + 33606)
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x1000e5fef  securityd ??? (???)
                                              <D22357C3-1D0B-A697-2539-3CD2DF430006> /usr/sbin/securityd
                                              Process:         socketfilterfw
                                              Path:            /usr/libexec/ApplicationFirewall/socketfilterfw
                                              UID:             0
                                                 Thread 1748e000   DispatchQueue 1
                                                 User stack:
                                                   48 ??? (in socketfilterfw + 3052)
                                                     48 ??? (in socketfilterfw + 26400)
                                                       48 ??? (in socketfilterfw + 16032)
                                                 Kernel stack:
                                                 Thread 179f67a8   DispatchQueue 2
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 179f6000
                                                 User stack:
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Binary Images:
                                                        0x100000000 -        0x10000eff7  socketfilterfw ??? (???)
                                              <0A3C1DA2-B11E-BAF8-0A19-91CE38B5AC3C> /usr/libexec/
                                              Process:         spindump
                                              Path:            /usr/sbin/spindump
                                              UID:             0
                                                 Thread 208dc3d4
                                                 User stack:
                                                   48 ??? (in spindump + 3752)
                                                     48 ??? (in spindump + 6427)
                                                           1 __CFRunLoopRun + 2864 (in CoreFoundation)
                                                             1 dispatchmain_queue_callback_4CF + 37 (in
                                              libSystem.B.dylib)
                                                               1 dispatchqueue_serial_drain_till_empty + 9 (in
                                              libSystem.B.dylib)
        1 dispatchqueue_drain + 251 (in
                                              libSystem.B.dylib)
        1 dispatchcall_block_and_release + 15 (in
                                              libSystem.B.dylib)
        1 ??? (in spindump + 10090)
        1 ??? (in spindump + 10652)
        1 AudioObjectGetPropertyDataSize + 143 (in
                                              CoreAudio)
        1 HALSystem::CheckOutInstance() + 364 (in
                                              CoreAudio)
        1 HALSystem::InitializeDevices() + 9
                                              (in CoreAudio)
        1 HALPlugInManagement::Initialize() +
                                              362 (in CoreAudio)
        1
                                              HALPlugInManagement::CreateHALPlugIn(HALCFPlugIn const*) + 1031 (in
                                              CoreAudio)
        1
                                              HP_HardwarePlugIn_InitializeWithObjectID
                                              (AudioHardwarePlugInInterface**, unsigned int) + 66 (in CoreAudio)
        1
                                              IOA_HWDeviceManager::Initialize() + 208 (in CoreAudio)
        1
                                              IOA_HWDeviceManager::IOServiceMatchingHandler(IOA_HWDeviceManager*,
                                              unsigned int) + 333 (in CoreAudio)
        1 IOA_PlugIn::HWDevicesAdded
                                              (std::vector<IOA_HWDevice, std::allocator<IOA_HWDevice> > const&) +
                                              73 (in CoreAudio)
        1
                                              IOA_SingleDeviceManager::CreateDevice(IOA_HWDevice*) + 159 (in
                                              CoreAudio)
        1
                                              IOA_SingleDevice::Initialize() + 130 (in CoreAudio)
        1
                                              HP_HogMode::HP_HogMode(HP_Device*) + 211 (in CoreAudio)
        1
                                              CFNotificationCenterAddObserver + 294 (in CoreFoundation)
        1
                                              _CFXNotificationRegister + 1397 (in CoreFoundation)
        1
                                              mach_wait_until + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   47 ipc_mqueue_receive_continue + 0
                                                   1 mach_wait_until_trap + 81
                                                 Thread 175007a8
                                                 User stack:
                                                     1 pthreadwqthread + 353 (in libSystem.B.dylib)
                                                       1 dispatchworker_thread2 + 244 (in libSystem.B.dylib)
                                                         1 dispatchqueue_invoke + 61 (in libSystem.B.dylib)
                                                           1 dispatchqueue_drain + 261 (in libSystem.B.dylib)
                                                             1 dispatchqueue_invoke + 195 (in libSystem.B.dylib)
                                                               1 dispatchsource_invoke + 273 (in
                                              libSystem.B.dylib)
        1 ??? (in spindump + 16000)
        1 syscall + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   1 lo64_unix_scall + 77
                                                     1 unix_syscall64 + 617
                                                       1 stack_snapshot + 85
                                                         1 stack_snapshot2 + 147
                                                 Thread 176863d4
                                                 User stack:
                                                 Kernel stack:
                                                       1 workq_kernreturn + 1013
                                                         1 proc_settargetconc + 4341
                                                           1 thread_block + 33
                                                               1 thread_go + 1985
                                                 Thread 1f3dcb7c
                                                 User stack:
                                                       48 ??? (in spindump + 8819)
                                                 Kernel stack:
                                                 Thread 208dc7a8
                                                 User stack:
                                                     47 pthreadwqthread + 353 (in libSystem.B.dylib)
                                                       47 dispatchworker_thread2 + 244 (in libSystem.B.dylib)
                                                         47 dispatchqueue_invoke + 61 (in libSystem.B.dylib)
                                                           47 dispatchqueue_drain + 261 (in libSystem.B.dylib)
                                                             47 dispatchqueue_invoke + 195 (in libSystem.B.dylib)
                                                               47 dispatchsource_invoke + 273 (in
                                              libSystem.B.dylib)
        47 ??? (in spindump + 16000)
        47 syscall + 10 (in libSystem.B.dylib)
                                                     1 __workq_kernreturn + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   47 lo64_unix_scall + 77
                                                     47 unix_syscall64 + 617
                                                       47 stack_snapshot + 85
                                                         47 stack_snapshot2 + 147
                                                   1 workqueue_thread_yielded + 562
                                                 Thread 29fad000
                                                 User stack:
                                                 Kernel stack:
                                                   40 lo64_unix_scall + 77
                                                     40 unix_syscall64 + 617
                                                       40 kevent + 95
                                                         40 kqueue_scan + 1643
                                                           40 kqueue_scan + 415
                                                             40 thread_block_parameter + 32
                                                               40 thread_block_reason + 309
        40 thread_go + 1985
        40 thread_setrun + 1340
        40 machine_idle + 254
                                                   8 kevent + 97
                                                 Binary Images:
                                                        0x100000000 -        0x100010ff7  spindump ??? (???)
                                              <085A350B-140A-7032-9863-78646EABC2D7> /usr/sbin/spindump
                                                     0x7fff85960000 -     0x7fff859defef  com.apple.audio.CoreAudio
                                              3.2.0 (3.2) <51E4AA76-3A8A-2B78-95D2-582501421A4E> /System/Library/
                                              Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                                              Process:         spindump_symbolicator
                                              Path:            /usr/libexec/spindump_symbolicator
                                              UID:             0
                                                 Thread 29c62b7c
                                                 User stack:
                                                   48 ??? (in spindump_symbolicator + 5772)
                                                     48 ??? (in spindump_symbolicator + 6159)
                                                 Kernel stack:
                                                 Thread 285dd7a8
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 1d0a63d4
                                                 User stack:
                                                   2 thread_start + 13 (in libSystem.B.dylib)
                                                     2 pthreadstart + 331 (in libSystem.B.dylib)
                                                       2 cleaner_thread_main(void*) + 36 (in CoreSymbolication)
                                                         2 __semwait_signal + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   2 semaphore_wait_continue + 0
                                                 Binary Images:
                                                        0x100000000 -        0x100001fff  spindump_symbolicator ???
                                              (???) <F714C29C-0C17-94A8-F8D0-6F88DD990C71> /usr/libexec/
                                                     0x7fff8008f000 -     0x7fff80101fef
                                              com.apple.CoreSymbolication 2.0 (23)
                                              <06F8561E-4B36-7BF6-31BA-64091B3D8058> /System/Library/
                                              PrivateFrameworks/CoreSymbolication.framework/Versions/A/
                                              CoreSymbolication
                                              Process:         syslogd
                                              Path:            /usr/sbin/syslogd
                                              UID:             0
                                                 Thread 16d473d4
                                                 User stack:
                                                   48 ??? (in syslogd + 2460)
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Thread 16cbd7a8
                                                 User stack:
                                                       48 ??? (in syslogd + 35838)
                                                         48 vprocmgrlog_drain + 80 (in libSystem.B.dylib)
                                                           48 vproc_mig_log_drain + 95 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                 Thread 16d47000
                                                 User stack:
                                                       48 ??? (in syslogd + 46323)
                                                         48 ??? (in syslogd + 36771)
                                                 Kernel stack:
                                                 Thread 16d477a8
                                                 User stack:
                                                       48 ??? (in syslogd + 45247)
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x100013fff  syslogd ??? (???)
                                              <72261A58-D9C8-558F-A6F5-BCC33F0EE52D> /usr/sbin/syslogd
                                              Process:         SystemUIServer
                                              Path:            /System/Library/CoreServices/SystemUIServer.app/
                                              Contents/MacOS/SystemUIServer
                                              UID:             501
                                                 Thread 17a147a8
                                                 User stack:
                                                   48 ??? (in SystemUIServer + 72464)
                                                     48 ??? (in SystemUIServer + 74120)
                                                         48 -[NSApplication
                                              HIToolbox)
                                                 Kernel stack:
                                                 Thread 175387a8   DispatchQueue -14868697
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 20438b7c
                                                 User stack:
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Binary Images:
                                                        0x100000000 -        0x100066fef  com.apple.systemuiserver
                                              1.6 (298.5) <78B49BCC-904B-33E1-97FA-708093DD6504> /System/Library/
                                              CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
                                              Process:         TextEdit
                                              Path:            /Applications/TextEdit.app/Contents/MacOS/TextEdit
                                              UID:             501
                                                 Thread 1d0ad000
                                                 User stack:
                                                   48 ??? (in TextEdit + 4024)
                                                         48 -[NSApplication
                                              HIToolbox)
                                                 Kernel stack:
                                                 Thread 222657a8
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Binary Images:
                                                        0x100000000 -        0x100019fff  com.apple.TextEdit 1.6
                                              (264) <8D896028-3313-84D8-1FC9-A4412739AEF4> /Applications/
                                              Process:         usbmuxd
                                              Path:            /System/Library/PrivateFrameworks/
                                              MobileDevice.framework/Versions/A/Resources/usbmuxd
                                              UID:             213
                                                 Thread 174403d4   DispatchQueue 100
                                                 User stack:
                                                   48 ??? (in usbmuxd + 3977)
                                                     48 ??? (in usbmuxd + 4188)
                                                       48 ??? (in usbmuxd + 8846)
                                                         48 CFRunLoopRun + 84 (in CoreFoundation)
                                                           48 CFRunLoopRunSpecific + 452 (in CoreFoundation)
                                                             48 __CFRunLoopRun + 2447 (in CoreFoundation)
                                                 Kernel stack:
                                                 Thread 179d93d4   DispatchQueue 1634545000
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 179d97a8
                                                 User stack:
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Binary Images:
                                                     0x1000 -     0xafff  usbmuxd ??? (???) <7862D312-C4E2-B170-
                                              E74E-395F177BB858> /System/Library/PrivateFrameworks/
                                              Process:         UserEventAgent
                                              Path:            /usr/libexec/UserEventAgent
                                              UID:             501
                                                 Thread 1f3e1b7c
                                                 User stack:
                                                   48 ??? (in UserEventAgent + 3740)
                                                     48 ??? (in UserEventAgent + 6152)
                                                 Kernel stack:
                                                 Thread 1ce67b7c   DispatchQueue
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 1f32b000
                                                 User stack:
                                                         48 RegisterAppTracker + 8174 (in ACRRDaemon)
                                              (in Foundation)
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x100001fff  UserEventAgent ??? (???)
                                              <D7E00D4C-D72A-B658-5BA2-3E0B9A6FA3EA> /usr/libexec/UserEventAgent
                                                        0x100042000 -        0x100047fff
                                              com.apple.CrashReporter.ACRRDaemonPlugin 10.6 (237)
                                              <BE8A8843-15A3-6840-214C-7CF69CF8E7CD> /System/Library/
                                              UserEventPlugins/ACRRDaemon.plugin/Contents/MacOS/ACRRDaemon
                                              Process:         WebKitPluginAgent
                                              Path:            /System/Library/Frameworks/WebKit.framework/
                                              WebKitPluginAgent
                                              UID:             501
                                                 Thread 29fb23d4
                                                 User stack:
                                                         48 __sigsuspend_nocancel + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   48 sleep + 52
                                                 Thread 208dd000
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Binary Images:
                                              Process:         WebKitPluginHost
                                              WebKitPluginHost.app/Contents/MacOS/WebKitPluginHost
                                              UID:             501
                                                 Thread 29f9a000
                                                 User stack:
                                                   48 ??? (in WebKitPluginHost + 6213)
                                                     48 ??? (in WebKitPluginHost + 23049)
                                                         48 -[NSApplication
                                              HIToolbox)
                                              CoreFoundation)
        29 __CFRunLoopRun + 2447 (in CoreFoundation)
        29 mach_msg_trap + 10 (in
                                              libSystem.B.dylib)
        16 __CFRunLoopRun + 4588 (in CoreFoundation)
        16 __CFRunLoopDoObservers + 1186 (in
                                              CoreFoundation)
        16 CA::Transaction::commit() + 316 (in
                                              QuartzCore)
        16 CA::Context::commit_transaction
                                              (CA::Transaction*) + 362 (in QuartzCore)
        16 CALayerDisplayIfNeeded + 621 (in
                                              QuartzCore)
        16 -[CALayer _display] + 958 (in
                                              QuartzCore)
        16 CABackingStoreUpdate + 2326
                                              (in QuartzCore)
        16 backing_callback(CGContext*,
                                              void*) + 77 (in QuartzCore)
        16 ??? (in WebKitPluginHost +
                                              57159)
        16
                                              Flash_EnforceLocalSecurity + 610 (in Flash Player)
        16
                                              Flash_EnforceLocalSecurity + 688419 (in Flash Player)
        16
                                              Flash_EnforceLocalSecurity + 672922 (in Flash Player)
        16
                                              Flash_EnforceLocalSecurity + 670719 (in Flash Player)
        16 ??? (in Flash
                                              Player + 1804603)
        16 ??? (in Flash
                                              Player + 1087781)
        9 ??? (in Flash
                                              Player + 1074212)
        9 ??? (in
                                              Flash Player + 1391189)
        9 ??? (in
                                              Flash Player + 1393405)
        9 ??? (in
        9 ???
                                              (in Flash Player + 1393405)
        9 ???
                                              (in Flash Player + 1390888)
                                              9 ??? (in Flash Player + 691549)
                                              9 ??? (in Flash Player + 695768)
                                              4 ??? (in Flash Player + 658435)
                                              3 ??? (in Flash Player + 658438)
                                              2 ??? (in Flash Player + 658432)
        5 ??? (in Flash
                                              Player + 1074641)
        5 ??? (in
                                              Flash Player + 1005204)
        5 ??? (in
                                              Flash Player + 1003873)
        5 ??? (in
                                              Flash Player + 978725)
        5 ???
                                              (in Flash Player + 977206)
        3 ???
                                              (in Flash Player + 891495)
        2 ???
                                              (in Flash Player + 891318)
        2 ??? (in Flash
                                              Player + 1073634)
        2 ??? (in
        2 ??? (in
        2 ??? (in
        2 ???
        2 ???
                                              (in Flash Player + 1391189)
                                              2 ??? (in Flash Player + 1393405)
                                              2 ??? (in Flash Player + 1391189)
        1
        1
        1
        1
        1
        1
        1
        1
        1
        1
                                                ??? (in Flash Player + 1393716)
        1
                                                ??? (in Flash Player + 1377824)
        1
                                                ??? (in Flash Player + 1329167)
        1
                                                ??? (in Flash Player + 1056193)
        1
                                                ??? (in Flash Player + 1388942)
        1
                                                ??? (in Flash Player + 582354)
        3 __CFRunLoopRun + 6846 (in CoreFoundation)
        3 Flash_EnforceLocalSecurity + 686794 (in
                                              Flash Player)
        1 ??? (in Flash Player + 1838068)
        1 ??? (in Flash Player + 605513)
        1 ??? (in Flash Player + 599456)
        1 ??? (in Flash Player + 607495)
        1 ??? (in Flash Player + 607040)
                                              1642241)
        1 ??? (in Flash Player + 1836848)
        1 ??? (in Flash Player + 3004011)
        1 swtch_pri + 0 (in
                                              libSystem.B.dylib)
        1 ??? (in Flash Player + 1838116)
        1 ??? (in Flash Player + 1134077)
        1 ??? (in Flash Player + 1760398)
        1 ??? (in Flash Player + 1170347)
                                                 Kernel stack:
                                                   25 ipc_mqueue_receive_continue + 0
                                                   14 lo_allintrs + 302
                                                     14 interrupt + 171
                                                       14 lapic_interrupt + 126
                                                         14 intel_startCPU + 375
                                                           14 sync_iss_to_iks + 124
                                                   5 lo_alltraps + 298
                                                     5 user_trap + 671
                                                       3 vm_fault + 464
                                                         3 vm_map_lookup_locked + 3061
                                                           3 lck_rw_lock_exclusive_gen + 380
                                                             3 thread_block + 33
                                                               2 thread_block_reason + 331
        2 thread_dispatch + 1949
        2 machine_switch_context + 753
                                                               1 thread_block_reason + 395
        1 ml_set_interrupts_enabled + 47
                                                       1 vm_fault + 1787
                                                         1 vm_fault_enter + 24
                                                       1 vm_fault + 704
                                                         1 vm_page_lookup + 215
                                                           1 hw_lock_to + 28
                                                   4 lo_mach_scall + 280
                                                     4 get_user_regs + 548
                                                           4 thread_block + 33
                                                               4 thread_go + 1985
                                                 Thread 16cbdb7c
                                                 User stack:
                                                       48 ??? (in Flash Player + 3005167)
                                                         48 Flash_EnforceLocalSecurity + 45743 (in Flash Player)
                                                           48 ??? (in Flash Player + 3003967)
                                              libSystem.B.dylib)
                                                 Kernel stack:
                                                 Thread 17437b7c
                                                 User stack:
                                                         43 Flash_EnforceLocalSecurity + 45743 (in Flash Player)
                                                           43 ??? (in Flash Player + 3003967)
                                                             43 pthread_cond_wait + 48 (in libSystem.B.dylib)
                                                               43 semaphore_wait_signal_trap + 10 (in
                                              libSystem.B.dylib)
                                                         5 Flash_EnforceLocalSecurity + 46010 (in Flash Player)
                                                           4 ??? (in Flash Player + 1003873)
                                                             4 ??? (in Flash Player + 988265)
                                                               4 ??? (in Flash Player + 903453)
        4 ??? (in Flash Player + 917722)
                                                           1 ??? (in Flash Player + 1003862)
                                                             1 ??? (in Flash Player + 972242)
                                                               1 ??? (in Flash Player + 967540)
                                                 Kernel stack:
                                                   42 semaphore_wait_continue + 0
                                                   4 lo_alltraps + 298
                                                     4 user_trap + 671
                                                       4 vm_fault + 464
                                                         4 vm_map_lookup_locked + 3061
                                                             3 thread_block + 33
                                                               1 thread_block_reason + 331
        1 thread_dispatch + 1949
        1 machine_switch_context + 753
        1 thread_go + 1985
                                                           1 lck_rw_lock_exclusive_gen + 267
                                                   1 lo_allintrs + 302
                                                     1 interrupt + 171
                                                   1 lo_mach_scall + 280
                                                     1 get_user_regs + 548
                                                       1 semaphore_wait_signal_trap + 34
                                                         1 semaphore_wait_signal_trap_internal + 96
                                                           1 semaphore_destroy + 703
                                                             1 thread_block + 33
        1 thread_go + 1985
                                                 Thread 175003d4
                                                 User stack:
                                                       48 Flash_EnforceLocalSecurity + 2207588 (in Flash Player)
                                                 Kernel stack:
                                                 Thread 17557b7c
                                                 User stack:
                                              libSystem.B.dylib)
                                                               3 ??? (in Flash Player + 903453)
        3 ??? (in Flash Player + 917722)
                                                               1 ??? (in Flash Player + 890113)
                                                           1 ??? (in Flash Player + 1003286)
                                                             1 ??? (in Flash Player + 973384)
                                                 Kernel stack:
                                                   4 lo_alltraps + 298
                                                     4 user_trap + 671
                                                       3 vm_fault + 464
                                                           2 lck_rw_lock_exclusive_gen + 380
                                                             2 thread_block + 33
                                                           1 lck_rw_lock_exclusive_gen + 288
                                                             1 mach_absolute_time + 34
                                                               1 rtcnanotime_read + 28
                                                       1 vm_fault + 1787
                                                         1 vm_fault_enter + 836
                                                           1 pmap_enter + 2879
                                                             1 pmap_flush_tlbs + 500
                                                   1 lo_allintrs + 302
                                                     1 interrupt + 171
                                                 Thread 1ce6a3d4
                                                 User stack:
                                              libSystem.B.dylib)
                                                           5 ??? (in Flash Player + 1003873)
                                                             5 ??? (in Flash Player + 988265)
                                                               5 ??? (in Flash Player + 903453)
        5 ??? (in Flash Player + 917722)
                                                 Kernel stack:
                                                   5 lo_alltraps + 298
                                                     5 user_trap + 671
                                                       4 vm_fault + 464
                                                             3 thread_block + 33
        1 thread_go + 1985
                                                               1 rtcnanotime_read + 26
                                                       1 lck_rw_done + 103
                                                         1 lck_rw_done_gen + 59
                                                           1 thread_wakeup_prim + 126
                                                             1 wait_queue_wakeup_all + 150
                                                 Thread 1cee7b7c
                                                 User stack:
                                              libSystem.B.dylib)
                                                 Kernel stack:
                                                   5 lo_alltraps + 298
                                                     5 user_trap + 671
                                                       5 vm_fault + 464
                                                         5 vm_map_lookup_locked + 3061
                                                             3 thread_block + 33
                                                               2 thread_block_reason + 309
        1 thread_go + 1985
        1 thread_go + 1975
                                                           2 lck_rw_lock_exclusive_gen + 288
                                                             2 mach_absolute_time + 34
                                                               2 rtcnanotime_read + 28
                                                             1 thread_block + 33
        1 thread_go + 1985
                                                 Thread 1d0b4000
                                                 User stack:
                                                         47 Flash_EnforceLocalSecurity + 290507 (in Flash Player)
                                                           47 ??? (in Flash Player + 3003761)
                                                             47 pthread_cond_timedwait + 47 (in libSystem.B.dylib)
                                                               47 semaphore_timedwait_signal_trap + 10 (in
                                              libSystem.B.dylib)
                                                         1 Flash_EnforceLocalSecurity + 294209 (in Flash Player)
                                                           1 Flash_EnforceLocalSecurity + 276237 (in Flash Player)
                                                             1 ??? (in Flash Player + 2956435)
                                                               1 FSReadFork + 59 (in CarbonCore)
        1 PBReadForkSync + 117 (in CarbonCore)
        1 pread$UNIX2003 + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                   45 semaphore_wait_continue + 0
                                                   2 lo_mach_scall + 280
                                                     2 get_user_regs + 548
                                                       2 semaphore_timedwait_signal_trap + 48
                                                         2 semaphore_timedwait_signal_trap_internal + 226
                                                           2 semaphore_destroy + 703
                                                             2 thread_block + 33
        2 thread_go + 1985
        2 thread_setrun + 1340
        2 machine_idle + 254
                                                   1 lo_unix_scall + 266
                                                 Thread 20421000
                                                 User stack:
                                                       48 CAPThread::Entry(CAPThread*) + 140 (in CoreAudio)
                                                         48 HP_IOThread::ThreadEntry(HP_IOThread*) + 17 (in
                                              CoreAudio)
                                                           48 HP_IOThread::WorkLoop() + 1892 (in CoreAudio)
                                                             48 CAGuard::WaitUntil(unsigned long long) + 289 (in
                                              CoreAudio)
                                                               48 CAGuard::WaitFor(unsigned long long) + 219 (in
                                              CoreAudio)
                                              libSystem.B.dylib)
                                              libSystem.B.dylib)
                                                 Kernel stack:
                                                   3 lo_mach_scall + 280
                                                     3 get_user_regs + 548
                                                       3 semaphore_timedwait_signal_trap + 48
                                                         3 semaphore_timedwait_signal_trap_internal + 226
                                                             3 thread_block + 33
        3 thread_go + 1985
                                                 Thread 281397a8
                                                 User stack:
                                              libSystem.B.dylib)
                                                 Kernel stack:
                                                   5 lo_alltraps + 298
                                                     5 user_trap + 671
                                                       5 vm_fault + 464
                                                           4 lck_rw_lock_exclusive_gen + 380
                                                             4 thread_block + 33
        1 thread_go + 1985
        1 thread_go + 1975
                                                 Thread 29f883d4
                                                 User stack:
                                              libSystem.B.dylib)
                                                           3 ??? (in Flash Player + 1003873)
                                                             3 ??? (in Flash Player + 988265)
                                                               2 ??? (in Flash Player + 890074)
                                                           1 ??? (in Flash Player + 1003478)
                                                             1 ??? (in Flash Player + 973356)
                                                             1 ??? (in Flash Player + 971396)
                                                               1 ??? (in Flash Player + 967577)
                                                 Kernel stack:
                                                   3 lo_alltraps + 298
                                                     3 user_trap + 671
                                                       2 vm_fault + 464
                                                         2 vm_map_lookup_locked + 3061
                                                             1 mach_absolute_time + 12
                                                           1 lck_rw_lock_exclusive_gen + 380
                                                             1 thread_block + 33
                                                       1 vm_fault + 1844
                                                         1 memory_object_recover_named + 9171
                                                             1 hw_lock_to + 28
                                                   2 lo_allintrs + 302
                                                     2 interrupt + 171
                                                             1 thread_block + 33
        1 thread_go + 1985
                                                 Thread 29fac000
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 29fadb7c
                                                 User stack:
                                              libSystem.B.dylib)
                                                 Kernel stack:
                                                   5 lo_alltraps + 298
                                                     5 user_trap + 671
                                                       4 vm_fault + 464
                                                             4 thread_block + 33
                                                               2 thread_block_reason + 395
        2 ml_set_interrupts_enabled + 47
        1 thread_go + 1985
        1 thread_go + 1975
                                                       1 vm_fault + 1787
                                                           1 pmap_enter + 2879
                                                             1 pmap_flush_tlbs + 240
                                                               1 i386_signal_cpu + 36
                                                 Thread 29fc03d4
                                                 User stack:
                                                         48 ??? (in Flash Player + 2098488)
                                              libSystem.B.dylib)
                                                 Kernel stack:
                                                 Thread 29fb97a8
                                                 User stack:
                                                       8 TimerThread + 97 (in CarbonCore)
                                              libSystem.B.dylib)
                                              libSystem.B.dylib)
                                                 Kernel stack:
                                                 Thread 1d0a6000
                                                 User stack:
                                                   2 thread_start + 34 (in libSystem.B.dylib)
                                                     2 pthreadstart + 345 (in libSystem.B.dylib)
                                                       2 TimerThread + 97 (in CarbonCore)
                                                         2 TSWaitOnSemaphoreCommon + 511 (in CarbonCore)
                                                           2 TSWaitOnConditionTimedRelative + 242 (in CarbonCore)
                                                             2 pthread_cond_timedwait_relative_np + 47 (in
                                              libSystem.B.dylib)
                                                               2 semaphore_timedwait_signal_trap + 10 (in
                                              libSystem.B.dylib)
                                                 Kernel stack:
                                                 Thread 1d0a63d4
                                                 User stack:
                                              libSystem.B.dylib)
                                              libSystem.B.dylib)
                                                 Kernel stack:
                                                 Thread 29fb97a8   DispatchQueue -16711681
                                                 User stack:
                                                   1 thread_start + 34 (in libSystem.B.dylib)
                                                     1 pthreadstart + 345 (in libSystem.B.dylib)
                                                       1 TimerThread + 97 (in CarbonCore)
                                                         1 TSWaitOnSemaphoreCommon + 511 (in CarbonCore)
                                                           1 TSWaitOnConditionTimedRelative + 242 (in CarbonCore)
                                                             1 pthread_cond_timedwait_relative_np + 47 (in
                                              libSystem.B.dylib)
                                                               1 semaphore_timedwait_signal_trap + 10 (in
                                              libSystem.B.dylib)
                                                 Kernel stack:
                                                   1 semaphore_wait_continue + 0
                                                 Thread 175383d4
                                                 User stack:
                                              libSystem.B.dylib)
                                              libSystem.B.dylib)
                                                 Kernel stack:
                                                 Binary Images:
                                                     0x1000 -    0x18ff7  com.apple.WebKit.PluginHost 6531 (6531.4)
                                              <ACC2FC87-2614-566A-1288-27FE689BBEDB> /System/Library/Frameworks/
                                              WebKit.framework/WebKitPluginHost.app/Contents/MacOS/WebKitPluginHost
                                                 0x13221000 - 0x1385affb  com.macromedia.Flash Player.plugin 10.0.32
                                              (1.0.4f18472) <B19EE236-3941-C958-2E04-0B99BB5E237A> /Library/Internet
                                              Plug-Ins/Flash Player.plugin/Contents/MacOS/Flash Player
                                                 0x9050f000 - 0x90873ff7  com.apple.QuartzCore 1.6.0 (226.0)
                                              <7E29DD09-BE04-AA06-5C81-5C093F16901B> /System/Library/Frameworks/
                                                 0x94618000 - 0x94691ff3  com.apple.audio.CoreAudio 3.2.0 (3.2)
                                              <91AE891E-6015-AABE-3512-2D5EBCA0937B> /System/Library/Frameworks/
                                              HIToolbox
                                              Process:         WindowServer
                                              ApplicationServices.framework/Frameworks/CoreGraphics.framework/
                                              Resources/WindowServer
                                              UID:             88
                                                 Thread 1ce30b7c
                                                 User stack:
                                                   48 start + 52 (in WindowServer)
                                                     48 main + 9 (in WindowServer)
                                                       48 CGXGetRootAdminCredentials + 0 (in CoreGraphics)
                                                         48 CGXServerLoop + 139 (in CoreGraphics)
                                                           46 CGXRunOneServicesPass + 357 (in CoreGraphics)
                                                             31 CGXRunOneServerPass + 208 (in CoreGraphics)
                                                               31 mach_msg_overwrite_trap + 10 (in
                                              libSystem.B.dylib)
                                                             15 CGXRunOneServerPass + 262 (in CoreGraphics)
                                                               15 mach_msg_trap + 10 (in libSystem.B.dylib)
                                                           2 CGXRunOneServicesPass + 110 (in CoreGraphics)
                                                             2 _CGXRunTimerPass + 344 (in CoreGraphics)
                                                               1 CGXUpdateDisplay + 7042 (in CoreGraphics)
        1 CGLayerComposite + 242 (in CoreGraphics)
        1 CGXGLAccelComposite + 794 (in CoreGraphics)
        1 _CGXGLCompositeLayers + 1179 (in
                                              CoreGraphics)
        1 CGXGLCompositeLayer + 156 (in
                                              CoreGraphics)
        1 _CGXGLCompositeBackground + 2712 (in
                                              CoreGraphics)
        1 glBegin_Exec + 368 (in GLEngine)
        1 gldUpdateDispatch + 2100 (in
                                              ATIRadeonX1000GLDriver)
                                                               1 CGXUpdateDisplay + 3354 (in CoreGraphics)
        1 CGXAcquireDisplayDeviceSurface + 2952 (in
                                              CoreGraphics)
        1 CGXGLAccelAccess + 506 (in CoreGraphics)
        1 _CGXGLLoadDefaultState + 198 (in
                                              CoreGraphics)
        1 glTexEnvfv_Exec + 160 (in GLEngine)
                                                 Kernel stack:
                                                   32 ipc_mqueue_receive_continue + 0
                                                   14 lo64_mach_scall + 77
                                                     14 thread_setuserstack + 405
                                                       14 mach_msg_overwrite_trap + 586
                                                         14 ipc_mqueue_receive + 89
                                                           14 thread_block + 33
                                                             14 thread_block_reason + 309
                                                               14 thread_go + 1985
        14 thread_setrun + 1340
        14 machine_idle + 254
                                                   2 lo_allintrs + 302
                                                     2 interrupt + 171
                                                 Thread 179ed7a8   DispatchQueue 2
                                                 User stack:
                                                 Kernel stack:
                                                   48 kevent + 97
                                                 Thread 16cd8000
                                                 User stack:
                                                       48 layer_blit_work_queue_server + 156 (in CoreGraphics)
                                                         48 layer_blit_work_queue_thread + 714 (in CoreGraphics)
                                                 Kernel stack:
                                                 Thread 173a5000
                                                 User stack:
                                                       48 eventThread + 441 (in CoreGraphics)
                                                         48 CFRunLoopRun + 70 (in CoreFoundation)
                                                           48 CFRunLoopRunSpecific + 575 (in CoreFoundation)
                                                             48 __CFRunLoopRun + 2002 (in CoreFoundation)
                                                               48 mach_msg_trap + 10 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                           1 thread_block + 33
                                                               1 thread_go + 1985
                                                 Thread 179ef3d4
                                                 User stack:
                                                         48 layer_blit_work_queue_thread + 1023 (in CoreGraphics)
                                                 Kernel stack:
                                                 Thread 1ce6a7a8
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 1d0223d4
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 1d09d7a8
                                                 User stack:
                                                 Kernel stack:
                                                 Thread 1e5167a8
                                                 User stack:
                                              QuartzCore)
                                                 Kernel stack:
                                                   48 ipc_mqueue_receive_continue + 0
                                                 Thread 1f3f0b7c
                                                 User stack:
                                                   48 thread_start + 13 (in libSystem.B.dylib)
                                                     48 pthreadstart + 331 (in libSystem.B.dylib)
                                                 Kernel stack:
                                                 Thread 20914b7c
                                                 User stack:
                                                 Kernel stack:
                                                 Binary Images:
                                                        0x100000000 -        0x100000fff  WindowServer ??? (???)
                                              <5607962C-ED2B-5F52-8E3B-042562061DED> /System/Library/Frameworks/
                                                        0x113e00000 -        0x113f8bff7  GLEngine ??? (???)
                                              <3E2DEFB1-190A-FBAD-C48F-E90B45EED8A4> /System/Library/Frameworks/
                                              OpenGL.framework/Resources/GLEngine.bundle/GLEngine
                                                        0x114800000 -        0x114b0cff7
                                              com.apple.ATIRadeonX1000GLDriver 1.6.2 (6.0.2) <411F1412-
                                              ED0A-5F59-4A8E-2C644C8FF48D> /System/Library/Extensions/
                                              ATIRadeonX1000GLDriver.bundle/Contents/MacOS/ATIRadeonX1000GLDriver
                                                     0x7fff82fd6000 -     0x7fff83149fef  com.apple.CoreFoundation
                                              6.6 (550) <04EC0CC2-6CE4-4EE0-03B9-6C5109398CB1> /System/Library/
                                              Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                                     0x7fff85e67000 -     0x7fff86025ff7  libSystem.B.dylib ???
                                              (???) <66102D4E-6C8B-77D0-6766-2A1788B20C6F> /usr/lib/libSystem.B.dylib
                                              Process:         XPSLauncher
                                              Path:            /Applications/Xerox/PrintingScout/XPSLauncher.app/
                                              Contents/MacOS/XPSLauncher
                                              UID:             501
                                              Process:         kernel_task
                                              Path:            kernel_task
                                              UID:             0
                                              Version:         Darwin Kernel Version 10.0.0: Fri Jul 31 22:47:34 PDT
                                              2009; root:xnu-1456.1.25~1/RELEASE_I386
                                                 Thread 0
                                                 Thread 863aa0
                                                 Kernel stack:
                                                   48 vm_pageout_continue + 0
                                                 Thread 16ad3000
                                                 Kernel stack:
                                                   48 thread_stack_enqueue + 90
                                                 Thread 16ad33d4
                                                 Kernel stack:
                                                   41 thread_daemon_init + 214
                                                   7 call_continuation + 28
                                                     7 thread_daemon_init + 746
                                                       7 thread_block + 33
                                                           7 thread_go + 1985
                                                 Thread 16ad37a8
                                                 Kernel stack:
                                                   48 assert_wait_deadline + 271
                                                 Thread 16ad3b7c
                                                 Kernel stack:
                                                   48 idle_thread + 0
                                                 Thread 16ad4000
                                                 Kernel stack:
                                                   46 idle_thread + 0
                                                   1 call_continuation + 28
                                                     1 idle_thread + 23
                                                       1 thread_switch + 531
                                                           1 thread_dispatch + 1330
                                                 Thread 16ad47a8
                                                 Kernel stack:
                                                   48 IOWorkLoop::threadMain() + 0
                                                 Thread 16ad4b7c
                                                 Kernel stack:
                                                   48 thread_call_initialize + 334
                                                 Thread 16c133d4
                                                 Kernel stack:
                                                   48 aio_return + 295
                                                 Thread 16c137a8
                                                 Kernel stack:
                                                   48 aio_return + 295
                                                 Thread 16c13b7c
                                                 Kernel stack:
                                                 Thread 16c1e000
                                                 Kernel stack:
                                                   46 idle_thread + 0
                                                       2 thread_switch + 531
                                                           2 thread_dispatch + 1330
                                                 Thread 16c1e3d4
                                                 Kernel stack:
                                                   47 idle_thread + 0
                                                     1 idle_thread + 23
                                                 Thread 16c1e7a8
                                                 Kernel stack:
                                                   47 idle_thread + 0
                                                     1 idle_thread + 23
                                                 Thread 16c1eb7c
                                                 Kernel stack:
                                                   48 aio_return + 295
                                                 Thread 16c1f000
                                                 Kernel stack:
                                                   48 call_continuation + 28
                                                     48 com.apple.driver.AppleIntelCPUPowerManagement 90.0.0 + 20737
                                                 Thread 16c1f3d4
                                                 Kernel stack:
                                                     48 ifnet_detach_protocol + 1591
                                                       48 msleep + 157
                                                         48 wakeup + 334
                                                           48 lck_mtx_sleep + 87
                                                 Thread 16c1f7a8
                                                 Kernel stack:
                                                   48 idle_thread + 0
                                                 Thread 16c1fb7c
                                                 Kernel stack:
                                                   45 idle_thread + 0
                                                   2 call_continuation + 28
                                                     2 idle_thread + 23
                                                 Thread 16c233d4
                                                 Kernel stack:
                                                   48 aio_return + 295
                                                 Thread 16c237a8
                                                 Kernel stack:
                                                 Thread 16c2f3d4
                                                 Kernel stack:
                                                 Thread 16c2f7a8
                                                 Kernel stack:
                                                   47 idle_thread + 0
                                                 Thread 16c2fb7c
                                                 Kernel stack:
                                                     48 buf_strategy + 1042
                                                       48 msleep + 157
                                                         48 wakeup + 334
                                                 Thread 16c32000
                                                 Kernel stack:
                                                     48 audit_worker_init + 956
                                                       48 auditcv_wait + 50
                                                         48 msleep + 157
                                                           48 wakeup + 334
                                                 Thread 16c323d4
                                                 Kernel stack:
                                                   48 vm_pageout_internal_start + 80
                                                 Thread 16c473d4
                                                 Kernel stack:
                                                     48 ux_handler_init + 475
                                                       48 mach_msg_receive + 168
                                                         48 ipc_mqueue_receive + 101
                                                 Thread 16c477a8
                                                 Kernel stack:
                                                 Thread 16c47b7c
                                                 Kernel stack:
                                                 Thread 16c4c3d4
                                                 Kernel stack:
                                                 Thread 16c4c7a8
                                                 Kernel stack:
                                                   48 m_freem + 15868
                                                 Thread 16c4cb7c
                                                 Kernel stack:
                                                   48 vm_pageout_internal_start + 945
                                                 Thread 16c65000
                                                 Kernel stack:
                                                   48 memory_object_recover_named + 18260
                                                 Thread 16c657a8
                                                 Kernel stack:
                                                   48 ifnet_detach + 582
                                                 Thread 16cb87a8
                                                 Kernel stack:
                                                 Thread 16cbd000
                                                 Kernel stack:
                                                 Thread 16cd2000
                                                 Kernel stack:
                                                 Thread 16cd23d4
                                                 Kernel stack:
                                                 Thread 16cd27a8
                                                 Kernel stack:
                                                 Thread 16cd83d4
                                                 Kernel stack:
                                                 Thread 16cd87a8
                                                 Kernel stack:
                                                   48 com.apple.nke.applicationfirewall 2.0.11 + 23882
                                                 Thread 16cdc000
                                                 Kernel stack:
                                                 Thread 16cdc3d4
                                                 Kernel stack:
                                                 Thread 16cdc7a8
                                                 Kernel stack:
                                                 Thread 16cf0000
                                                 Kernel stack:
                                                 Thread 16cf03d4
                                                 Kernel stack:
                                                 Thread 16cf07a8
                                                 Kernel stack:
                                                   41 IOWorkLoop::threadMain() + 0
                                                     7 IOWorkLoop::threadMain() + 188
                                                       7 thread_block_parameter + 32
                                                           7 thread_go + 1985
                                                 Thread 16cf0b7c
                                                 Kernel stack:
                                                 Thread 16d11000
                                                 Kernel stack:
                                                 Thread 16d113d4
                                                 Kernel stack:
                                                 Thread 16d117a8
                                                 Kernel stack:
                                                 Thread 16d11b7c
                                                 Kernel stack:
                                                 Thread 1733a000
                                                 Kernel stack:
                                                       48 msleep + 157
                                                         48 wakeup + 334
                                                 Thread 1733a3d4
                                                 Kernel stack:
                                                       48 msleep + 157
                                                         48 wakeup + 334
                                                 Thread 1739eb7c
                                                 Kernel stack:
                                                       48 msleep + 157
                                                         48 wakeup + 334
                                                 Thread 17424000
                                                 Kernel stack:
                                                   34 thread_call_initialize + 620
                                                   14 call_continuation + 28
                                                     14 thread_call_initialize + 1030
                                                       14 thread_block_parameter + 32
                                                           14 thread_go + 1985
                                                 Thread 1745ab7c
                                                 Kernel stack:
                                                     48 com.apple.filesystems.autofs 2.1.0 + 24145
                                                       48 msleep + 157
                                                         48 wakeup + 286
                                                           48 lck_mtx_sleep_deadline + 104
                                                 Thread 17467000
                                                 Kernel stack:
                                                 Thread 1747f3d4
                                                 Kernel stack:
                                                 Thread 1748e3d4
                                                 Kernel stack:
                                                 Thread 17538000
                                                 Kernel stack:
                                                 Thread 179ec3d4
                                                 Kernel stack:
                                                 Thread 179ef000
                                                 Kernel stack:
                                                 Thread 179f5000
                                                 Kernel stack:
                                                 Thread 179f57a8
                                                 Kernel stack:
                                                 Thread 179f6b7c
                                                 Kernel stack:
                                                 Thread 17a0e7a8
                                                 Kernel stack:
                                                 Thread 17a14000
                                                 Kernel stack:
                                                 Thread 17a2f3d4
                                                 Kernel stack:
                                                 Thread 1cee7000
                                                 Kernel stack:
                                                 Thread 1e516000
                                                 Kernel stack:
                                                   33 thread_call_initialize + 620
                                                   15 call_continuation + 28
                                                     15 thread_call_initialize + 1030
                                                       15 thread_block_parameter + 32
                                                         15 thread_block_reason + 309
                                                           15 thread_go + 1985
                                                             15 thread_setrun + 1340
                                                               15 machine_idle + 254
                                                 Thread 1e61db7c
                                                 Kernel stack:
                                                   36 thread_call_initialize + 620
                                                   12 call_continuation + 28
                                                     12 thread_call_initialize + 1030
                                                       12 thread_block_parameter + 32
                                                         12 thread_block_reason + 309
                                                           12 thread_go + 1985
                                                             12 thread_setrun + 1340
                                                               12 machine_idle + 254
                                                 Thread 1f3dc3d4
                                                 Kernel stack:
                                                 Thread 2041e000
                                                 Kernel stack:
                                                           12 thread_go + 1985
                                              Model: MacPro2,1, BootROM MP21.007F.B06, 8 processors, Quad-Core Intel
                                              Xeon, 3 GHz, 16 GB, SMC 1.15f3
                                              Graphics: ATI Radeon X1900 XT, ATY,RadeonX1900, PCIe, 512 MB
                                              Memory Module: global_name
                                              AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x87),
                                              Broadcom BCM43xx 1.0 (5.10.91.19)
                                              Bluetooth: Version 2.2.1f7, 2 service, 0 devices, 1 incoming serial
                                              ports
                                              Network Service: Ethernet 1, Ethernet, en0
                                              Network Service: Ethernet 2, Ethernet, en1
                                              PCI Card: ATY,RadeonX1900, Display, Slot-1
                                              Serial ATA Device: WDC WD5000AAKS-41TMA0, 465.76 GB
                                              Parallel ATA Device: OPTIARC DVD RW AD-7170A, 636.6 MB
                                              USB Device: iPhone, 0x05ac  (Apple Inc.), 0x1292, 0xfd100000
                                              USB Device: USB Internet Phone by TigerJet, 0x06e6, 0xc200, 0x1d200000
                                              USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.),
                                              0x8206, 0x5d200000
                                              USB Device: Hub in Apple Pro Keyboard, 0x05ac  (Apple Inc.), 0x1003,
                                              0x3d200000
                                              USB Device: Apple Optical USB Mouse, 0x05ac  (Apple Inc.), 0x0304,
                                              0x3d210000
                                              USB Device: Apple Pro Keyboard, 0x05ac  (Apple Inc.), 0x020b, 0x3d230000
                                              FireWire Device: built-in_hub, Up to 800 Mb/sec
                                              • 23. Re: Fireworks Crashes / Freezes When Using the Text Tool
                                                ajz2009 Level 1
                                                So, Neil.
                                                Based on your error report, I guess the "DOWNLOAD THE NEW GLOBAL RESOURCE FILE HERE" fix offerred above did not work for you.
                                                Have you heard of any other resolutions?
                                                Thanks,  Paul
