5 Replies Latest reply on Sep 17, 2009 9:20 AM by Russell.lrg
    How to apply cornerradius to tabs in TagNavigator
    Russell.lrg
      Hello,
          I have tried to applied CSS to tabs but that doesn't work. Could anyone give me an example showing how to give cornerradius to tabs in TagNavigator?
          Thanks in advance !
      ~Russell
        • 1. Re: How to apply cornerradius to tabs in TagNavigator
          Peter deHaan Level 4
          Russell,
          I believe you need to create a custom "Tab" skin and apply the corner radius there.
          For example, here is my main file:
                  xmlns:mx="library://ns.adobe.com/flex/halo">
              <fx:Style>
                  .tabStylez {
                      skin: ClassReference("RoundTabSkin");
              </fx:Style>
              <mx:TabNavigator id="tabNav"
                               tabStyleName="tabStylez"
                               width="300" height="100"
                               x="20" y="20">
                  <mx:VBox label="Red" />
                  <mx:VBox label="Orange" />
                  <mx:VBox label="Yellow" />
                  <mx:VBox label="Green" />
                  <mx:VBox label="Blue" />
              </mx:TabNavigator>
          </s:Application>
          And here is my custom Tab skin, RoundTabSkin.mxml, which is in the same directory as my main.mxml file:
          <s:SparkSkin xmlns:fx="http://ns.adobe.com/mxml/2009"
                       minWidth="21" minHeight="21"
                       alpha.disabledStates="0.5">
              <fx:Declarations>
                  <fx:Number id="cr">10</fx:Number>
              </fx:Declarations>
              <!-- states -->
              <s:states>
                  <s:State name="up" />
                  <s:State name="over" />
                  <s:State name="down" />
                  <s:State name="disabled" stateGroups="disabledStates"/>
                  <s:State name="selectedUp" stateGroups="selectedStates" />
                  <s:State name="selectedOver" stateGroups="selectedStates" />
                  <s:State name="selectedDown" stateGroups="selectedStates" />
                  <s:State name="selectedDisabled" stateGroups="disabledStates, selectedStates" />
              </s:states>
              <!-- layer 1: fill -->
              <s:Rect left="1" right="1" top="1" bottom="0" topLeftRadiusX="{cr}" topRightRadiusX="{cr}">
                  <s:fill>
                      <s:LinearGradient rotation="90">
                          <s:GradientEntry color="0xE4E4E4" color.over="0xCACACA"
                                           color.selectedStates="0xFFFFFF"
                                           alpha="1" />
                          <s:GradientEntry color="0xA1A1A1" color.over="0x878787"
                                           color.selectedStates="0xE4E4E4"
                                           alpha="1" />
                      </s:LinearGradient>
                  </s:fill>
              </s:Rect>
              <!-- layer 2: highlight stroke -->
              <s:Rect left="1" right="1" top="1" bottom="1" alpha="0.22"  topLeftRadiusX="{cr}" topRightRadiusX="{cr}">
                  <s:stroke>
                      <s:LinearGradientStroke rotation="90">
                          <s:GradientEntry color="0xFFFFFF" alpha="1" />
                          <s:GradientEntry color="0xD8D8D8" alpha="1" />
                      </s:LinearGradientStroke>
                  </s:stroke>
              </s:Rect>
              <!-- layer 3: fill highlight -->
              <s:Rect left="1" right="1" top="1" height="10"  topLeftRadiusX="{cr}" topRightRadiusX="{cr}">
                  <s:fill>
                      <s:SolidColor color="0xFFFFFF"
                                    alpha="0.12" />
                  </s:fill>
              </s:Rect>
              <!-- layer 4: border - unselected only -->
              <s:Rect left="0" right="0" top="0" bottom="0" excludeFrom="selectedStates"  topLeftRadiusX="{cr}" topRightRadiusX="{cr}">
                  <s:stroke>
                      <s:SolidColorStroke color="0x696969" alpha="1" />
                  </s:stroke>
              </s:Rect>
              <!-- layer 5: border - selected only -->
              <s:Rect left="0" right="0" top="0" bottom="0" includeIn="selectedStates"  topLeftRadiusX="{cr}" topRightRadiusX="{cr}">
                  <s:fill>
                      <s:SolidColor color="0x696969" alpha="1" />
                  </s:fill>
              </s:Rect>
          </s:SparkSkin>
          Hope that helps,
          Peter
          • 2. Re: How to apply cornerradius to tabs in TagNavigator
            Oh, and I took almost all that skin class code from the default Tab skin at:
            %FlexSDK%\frameworks\projects\sparkskins\src\mx\skins\spark\TabSkin.mxml
            Peter
            • 3. Re: How to apply cornerradius to tabs in TagNavigator
              Russell.lrg Level 1
              Hi Peter, thank you so much ! And thank you for telling me that I can
              "steal" codes from the sdk folder. I never know that before.
              Maybe I ask one more question? The property "topLeftRadiusX" is not in
              s:Rect any more. If I use radiusX, radiusY to substitute them, the tabs will
              get radius at all four corners. Do you have a solution for it?
              2009/9/16 Peter deHaan (Adobe) <forums@adobe.com>
              at:
              Peter
              • 4. Re: How to apply cornerradius to tabs in TagNavigator
                Actually, the problem is topLeftRadiusX is new, and you're using and older version of the Flex SDK. So the solution is to download a recent nightly Flex 4 SDK build from http://opensource.adobe.com/wiki/display/flexsdk/Download+Flex+4 (4.0.0.10339 is currently the latest nightly build) and try the code again.
                Specifying topLeftRadiusX, topLeftRadiusY, topRightRadiusX, topRightRadiusY, bottomLeftRadiusX, bottomLeftRadiusY, bottomRightRadiusX, and bottomRightRadiusY (whew!) will let you control the corner radius of each corner with great precision.
                Hope that helps,
                Peter
                • 5. Re: How to apply cornerradius to tabs in TagNavigator
                  Russell.lrg Level 1
                  Thank you so much! Your answer is very helpful.  After applying the latest
                  SDK I got all the topLeftRadiusX, topLeftRadiusY, topRightRadiusX,
                  But I still encounter some problem when running the application: I go the
                  error message of
                  "Connection to file:///C:/Documents and Settings/rluo/Adobe Flash Builder
                  Beta/ComponentsLearning/bin-debug/textLayout_4.0.0.10339.swf halted - not
                  permitted from file:///C:/Documents and Settings/rluo/Adobe Flash Builder
                  Beta/ComponentsLearning/bin-debug/TagNavigator2.swf"
                  Do you know how I can get it away?
                  ~Russell
                  2009/9/17 Peter deHaan (Adobe) <forums@adobe.com>
                  http://opensource.adobe.com/wiki/display/flexsdk/DownloadFlex4(4.0.0.10339 is currently the latest nightly build) and try the code again.
                  Hope that helps,
                  Peter
