3 Replies Latest reply on Sep 17, 2009 3:00 AM by Techi Panda
    Get image height and width
    Techi Panda Level 2
      Hi scripters
      I am trying to get the width and height of my image file. Here is my code
      myPicFile = File("c:\\ar.eps");
      h = myPicFile.height;
      w = myPicFile.width;
      alert(h)
      This code throws error
      Script Alert
      undefined
      OK
      how can I get the height and widht of my image? is there any other method?
      thanks in advance
      regards
      a r u l
        • 1. Re: Get image height and width
          Adobe-InDesign CS4 Level 1
          Dear Arul,
          Here my code is in InDesign Based. I don't know we are getting the Image size directly.?
          Throught InDesign [you using the InDesign Script then] Script here I pasted the below coding...
          //============================= Getting the Image Height / Width ============================//
          myPicFile = File("E:\\HariharaSudhan\\Blue hills.jpg");
          app.place(File(myPicFile);
          //======================== Then u please select the Image File in InDesign and then you run the script ===============//
          var mySel = app.selection[0];
          var Bound = mySel.geometricBounds;
          var height = Bound[2] - Bound[0];
          var width = Bound[3] - Bound[1];
          alert("Image Height :"+ height +" "+"Image Width :"+ width );
          //============================= End  : Getting the Image Height / Width ============================//
          Please let me know if you have any queries.
          Thanks & Regards
          T.R.Harihara SudhaN
          • 2. Re: Get image height and width
            Thomas B. Nielsen Level 3
            You are mixing things up.
            myPicFile is a file Object - look in the ESTK under Help -> Core Javascript Classes -> File to see what you have available for this object type.
            If you have an image or graphic that is placed in Indesign you should use myPicFile.geometricBounds // myPicFile must be a valid graphic or image item.
            • 3. Re: Get image height and width
              Techi Panda Level 2
              Thanks T.R.Harihara SudhaN & Thomas B. Nielsen i learned.
              thanks again
              regards
              a r u l
