8 Replies Latest reply on Sep 22, 2009 1:53 PM by bringrags
    daily build question #2 - SeekableTrait's _seek stuck
    darqwan
      Hello,
      Again its a dialy build question from my side:
      context:
      progressive video, autplay = false, autorewind = false
      media plays and reaches end.
      problem:
      after media reached end and a new mediaplayer.play(), seeking does not work (_seeking is stuck to true,discarding subsequent user generated seeks. It may have to do with the seek(end_of_media) which is fired continously after media reaches end. Again I did not have the time to look further into this.
      Is this a known problem ?
      Thanks a bunch,
      Bogdan.
        • 1. Re: daily build question #2 - SeekableTrait's _seek stuck
          bringrags Level 4
          I tried to reproduce with our ExamplePlayer sample app, but I don't see the problem you mention.  It might be specific to your app or content.  Could you either post some sample code, or file a bug?
          Thanks!
          • 2. Re: daily build question #2 - SeekableTrait's _seek stuck
            darqwan Level 1
            sure, here's the code:
            package {
            import flash.display.Sprite;
            import flash.display.StageAlign;
            import flash.display.StageScaleMode;
            import org.openvideoplayer.display.MediaPlayerSprite;
            import org.openvideoplayer.display.ScaleMode;
            import org.openvideoplayer.media.URLResource;
            import org.openvideoplayer.net.NetLoader;
            import org.openvideoplayer.utils.URL;
            import org.openvideoplayer.video.VideoElement;
            import org.openvideoplayer.media.MediaPlayer;
            import org.openvideoplayer.traits.*;
            import org.openvideoplayer.events.*;
            import flash.text.TextField;
            import flash.events.*;
            * Simple OSMF application.  Centers SWF and content.
            public class osmf2 extends Sprite
            public function osmf2()
            var skend:TextField = new TextField();
            skend.text = "1. seek to end";
            skend.selectable = false;
            skend.addEventListener(MouseEvent.CLICK, evthndlSeekEnd);
            addChild(skend);
            skend.x =  200;
            skend.y = 20;
            var pb:TextField = new TextField();
            pb.text = "2. wait for end&restart playback";
            pb.selectable = false;
            pb.addEventListener(MouseEvent.CLICK, evthndlClick);
            addChild(pb);
            pb.width = 200;
            pb.x =  200;
            pb.y = 40;
            var sk:TextField = new TextField();
            sk.text = "3. seek somewhere";
            sk.selectable = false;
            sk.addEventListener(MouseEvent.CLICK, evthndlSeek);
            addChild(sk);
            sk.x =  200;
            sk.y = 60;
            stage.scaleMode = StageScaleMode.NO_SCALE;
                        stage.align = StageAlign.TOP_LEFT;
            _player = new MediaPlayer(new VideoElement
            ( new NetLoader
            , new URLResource(new URL(REMOTE_PROGRESSIVE))
            _player.autoRewind =false;
            _sprite = new MediaPlayerSprite(_player);
            _sprite.width = 100;
            _sprite.height = 100;
            _sprite.scaleMode = ScaleMode.LETTERBOX;
            addChild(_sprite);
            var _player:MediaPlayer;
            var _sprite:MediaPlayerSprite;
            private function evthndlClick(e:MouseEvent){
            _player.play();
            private function evthndlSeek(e:MouseEvent) {
            _player.seek(20);
            private function evthndlSeekEnd(e:MouseEvent) {
            _player.seek(_player.duration -1);
            private function evthndlResize(e:Event)
            private static const REMOTE_PROGRESSIVE:String
            = "http://85.204.187.204/resx/flv/H264.flv";
            The flv is the Backcountry Bombshells vidoe that you guys also have..
            http://labs.adobe.com/wiki/index.php/Flash_Player:9:Update:H.264
            Does it make sense(is it even possible ?) to file a bug for a daily build ?
            Bogdan.
            • 3. Re: daily build question #2 - SeekableTrait's _seek stuck
              bringrags Level 4
              Makes sense -- I was able to reproduce.  Seems like the MediaPlayer gets stuck in the "seeking" state at the end of playback.  I noticed that I could recover if I paused and played again.  In any case, good bug.
              Yes, please file a bug against the daily build (in fact that's easier for us to diagnose, as we're all working out of trunk).
              Thanks!
              • 5. Re: daily build question #2 - SeekableTrait's _seek stuck
                darqwan Level 1
                sorry I forgot to mention this here, but I filed the bug earlier today - FM-89, so atm, FM-90 is a duplicate.
                Bogdan.
                • 6. Re: daily build question #2 - SeekableTrait's _seek stuck
                  darqwan Level 1
                  Is there an estimate on fixing this ?  I kind of rely on this fix and I've noticed that there isnt much going on in jira atm..
                  Bogdan.
                  • 7. Re: daily build question #2 - SeekableTrait's _seek stuck
                    darqwan Level 1
                    Hello Brian,
                    I decided to implement the workaround you suggested - pause/play. I did a test first and found out that it's actually not working.. I got the latest sources and the problem is still there (hoped it got fixed with the newest code changes).
                    I'm in a really tight spot atm as I didnt estimate the amount of issues I ended up having with OSMF (I really hope that others that decided to go with OSMF dont have my deadline)...
                    Bogdan.
                    • 8. Re: daily build question #2 - SeekableTrait's _seek stuck
                      bringrags Level 4
                      I've committed a fix to public trunk (changelist 10512), and marked the bug as resolved.  Please resubmit if it's not fixed for you.
