8 Replies Latest reply on Jun 17, 2008 2:52 PM by Dan Bracuk
    SQL Between dates
    wkolcz
      I am trying to pull information between 2 argument dates.
      Select offHours, tsCode, toDate
      FROM timeSheetDays
      WHERE uniqname = '#arguments.uniqname#'
      AND TODate BETWEEN #arguments.startDate# and #arguments.endDate#
      It comes out as:
      Select offHours, tsCode, toDate FROM timeSheetDays WHERE uniqname = 'wkolcz' AND TODate BETWEEN 2008-06-1 and 2008-06-31
      But I am not getting any results. What am I missing? I am using SQL server.
        • 1. Re: SQL Between dates
          Level 7
          What type of field is 'TODate'? Is it a date field, a string field, a
          number field? You may be having a problem with data matching. I do not
          know if SQL server will automatically convert a date string (like you
          are providing) to a date value.
          You would probably be better served using <cfqueryparam...> to make sure
          the data types match.
          I.E. TODate BETWEEN <cfqueryParam value="#arguments.startDate#"
          cfsqltype="cf_sql_date"> AND <cfqueryParam value="#arguments.endDate#"
          Of course you would want to make sure the sql type parameter matches the
          actual type of the database column.
          • 2. Re: SQL Between dates
            paross1 Level 2
            What is the datatype of the TODate column? Are #arguments.startDate# and #arguments.endDate# date/time objects (doubtful)? Assuming that TODate is a date/time, you may need to CAST or CONVERT the target variables to date/time objects so that you aren't comparing apples to oranges.
            Phi;
            • 3. Re: SQL Between dates
              wkolcz Level 1
              That is what I thought. The toDate is a date/time. How can I cast the arguments as date. I tried CAST(#arguments.startDate# AS Date) but it exploded.
              Oddly TODATE >= #arguments.startDate# works, but <= #arguments.endDate doesn't.
              • 4. Re: SQL Between dates
                Level 7
                IN CFML it would be createODBCDate() or better yet the <cfqueryparam
                ...> tags I mentioned in my previous reply.
                • 5. Re: SQL Between dates
                  paross1 Level 2
                  DATE is not a valid datatype for MS SQL (how about datetime or smalldatetime). How about setting the value of #arguments.startDate# and #arguments.endDate# to something that matches one of the style arguments that the MS SQL CONVERT() function recognizes. Or, as Ian has suggested, try using cfqueryparam with the appropriate cfsqltype for a MS SQL datetime object, such as CF_SQL_TIMESTAMP.
                  Phil
                  • 6. Re: SQL Between dates
                    -==cfSearching==- Level 4
                    BTW, assuming it is not a typo ... the value "2008-06-31" is not a valid date anyway. Verifying the variables contain valid date strings, and properly converting them to datetime objects (as explained in the previous responses) should resolve your problem.
                    • 7. Re: SQL Between dates
                      -==cfSearching==- wrote:
                      > ... should resolve your problem.
                      Of course I am making the assumption that BETWEEN is the correct operator to be using here. If the "ToDate" values included a non-zero time (ie 2008-06-17 21:53:18) then BETWEEN may not be the correct operator to use in your query.
                      • 8. Re: SQL Between dates
                        Dan Bracuk Level 5
                        If it were me, I'd use createdate and the necessary string functions to create date variables in the calling template and pass these date variables to the function.
                        On a related notes, for timestamp fields, it is often better to do this:
                        where somefield >= date1 and somefield < date2
                        than it is to use between because of the time portion of the field.
